716 Posts 111 Posters 706.2k Views 93 Watching
  • cmrockwellC
    cmrockwellC
    cmrockwell
    I would like to use this PCB with a 3.3V I2C sensor (data line and power must be <3.6V) and AC power. Is there a recommended way to accomplish this?
    • cmrockwellC cmrockwell
      sundberg84S
      sundberg84S
      @cmrockwell - Sorry, Im not following...
      AC Power? You need some AC-DC converter then and this is not the intend of the PCB, sorry.
      cmrockwellC 1 Reply Last reply
      • sundberg84S sundberg84
        cmrockwellC
        cmrockwellC
        cmrockwell
        @sundberg84
        Sorry, I wasn't clear. I just meant running from a DC power supply, not batteries. It seems that the intended use is to have 5V Vcc when running from a power supply, but I would like a 3.3V Vcc. Thanks for your help. I have 10 of these PCBs in hand.
        Nca78N sundberg84S 2 Replies Last reply
          @sundberg84
          @cmrockwell You can use a 3.3V / 8MHz pro-mini board and power everything with 3.3V.
            @sundberg84
            sundberg84S
            sundberg84S
            @cmrockwell - yes, the pcb is designed like @cmrockwell said. You can use either 3.3v or below (batteries) or a 5v regulated voltage. If you choose the 3.3v/bat version you need a 3.3v pro mini.
              cmrockwellC
              cmrockwellC
              cmrockwell
              @sundberg84
              OK, I figured out how to do what I wanted. I am planning to connect a regulated power supply that provides ~3.3VDC. The main thing I had to figure out was how to configure the PCB when neither a battery booster nor a regulator are needed. I think either shorting the REG pin and shorting the regulator or shorting the BAT pin and shorting the battery booster would each achieve the desired result.
                @sundberg84
                sundberg84S
                sundberg84S
                @cmrockwell - well done!
                Yes, digging deeper into it you can probably hack it many ways with jumpers and wires.
                  If I want to use a mini pro 3.3v and a 18650 battery that I have lying around, should I use something like THIS or do you think there is a better/more efficient way?
                    sundberg84S
                    sundberg84S
                    @gohan - im not that good in efficiency in boosters and converting voltage. Im sure that would work! The main thing is 1) deliver correct voltage and 2) if they are to noicy they will interfere with the radio and make the communication fail.
                    • P
                      P
                      popunonkok
                      I having trouble to order this board from DirtyPCB.
                      Both the link in the beginning of this thread (Rev8) and the link in the OpenHarware page just directs me to an empty DirtyPCB order page, with no board preloaded. It wants me to upload files.
                      Does anyone know how to order from DirtyPcb without uploading the boardfiles?
                      • P popunonkok
                        sundberg84S
                        sundberg84S
                        #292
                        @popunonkok - the link to DirtyPCB is not posted or maintained by me. If you want the latest revisions please go to order under openhardware.io = https://www.openhardware.io/order/4/PCB10X. DirtyPCB is not an option there so if you want to use them you need to download the gerberfiles for the project = https://www.openhardware.io/view/4/EasyNewbie-PCB-for-MySensors#tabs-design and upload them according to their instructions = http://dirtypcbs.com/store/pcbs/about (see order)
                        • P
                          P
                          popunonkok
                          Iv just orderd Rev8.
                          I have a primary question, might have a couple more later on.
                          In the info about the board it says:
                          "BAT: Short this if you are using batteries as power supply. It will activate booster circuit and feed the radio directly from the batteries and not voltage regulator"
                          It says about the same on the image of the board.
                          My question is. Why would I want to powewr the radio directly from battery and not from the Booster? Wouldent that make the radio not to function like it sould when the voltage dropps?
                          • P popunonkok
                            sundberg84S
                            sundberg84S
                            @popunonkok - if you search the forum and this thread about noice in the boosters you will find a big search result. The boosters is, to be honest, pretty bad. They generate alot of noice which interfere with the radio which is pretty sensitive. By "learning by doing" we have figured out that if you are using a booster the best way is to provice power to the radio directly from the batteries to avoid the noice... the radio will pretty much fail if you dont.
                            The radio can handle down to 1.9 v so this will be your minimum voltage for the circiut.
                            • P
                              P
                              popunonkok
                              Hmmm... Ok...
                              I had only read that the boosters helpt to drain the battery completely, had missed that they "messed" with the radio.
                              It will be really interesting to see what kind of battery life I can get out of 2 or 4 AA batteries on different types of nodes.
                              When I look at the Specs for the Pro Mini board the supply voltage is 3.35 - 12v.
                              I guess that means that without a Booster 2 AA batteries wont be able to run the Pro mini for a long time at all.
                              • P popunonkok
                                Hmmm... Ok...
                                sundberg84S
                                sundberg84S
                                #296
                                @popunonkok - you are correct, they are good for they "suck all the juice" out of the batteries. Without modifications the Pro Mini 3.3v have a lowerst voltage of 2.8V (called Brown out detection) Because of that when you use 2xAA you need the booster to keep a stable 3.3v and most of the booster can convert everyhing down to 0.9v back to 3.3v. The radio can handle down to 1.9v and that will be your lowerst point.
                                I have nodes reading temp and humidity with a dht22 every 15min, running this setup and they last around 1 year each.
                                You need to search the forum and https://www.mysensors.org/build/battery for power saving with battery. The most common first step is to remove the voltage regulator and the led. Then you sleep the node when it isnt active.
                                On this image you see the led removed (red arrow). I think its easier to remove the resistor (black circle, marked 102) but its the same result. Voltage regulater (red circle) is removed as well. Note that many sites say cut the trace but its much easier to desolder them.
                                Using the internal voltage regulator (3.35 - 12v) will kill the node in weeks/days if you run them on 2-4xAA because of the high current drain. My aim building a newbie/easy PCB is a sleepcurrent of 0,1mA or 100uA.
                                • chrlyraC
                                  chrlyraC
                                  chrlyra
                                  hi there,
                                  Thanks for the easypcb! I'm trying to build a small solar powered weather station (like these: https://forum.mysensors.org/topic/841/solar-powered-mini-weather-station), but just found that the battery that came with the solar panel only provides 1.2v. The booster works ok and I can power the arduino, but it's no enough for the radio :-(. Since powering the radio from the booster is not a option, I'm at a dead end. Or there's a way to still using this battery/solar panel?
                                  sundberg84S gohanG 2 Replies Last reply
                                  • chrlyraC chrlyra
                                    hi there,
                                    sundberg84S
                                    sundberg84S
                                    @chrlyra - you need 1.9V minimum for the radio. There are more advanced boosters you could try which probably is better and less noice... but this PCB was not designed for that purpose so sorry, I cant help you.
                                    • chrlyraC chrlyra
                                      hi there,
                                      @chrlyra
                                      There is another project called solar harvester that uses a supercap to store energy
                                      • dbemowskD
                                        dbemowskD
                                        So a question I have always wondered about the voltage regulator is do you really need to desolder it if you connect your incoming power to the 3.3v pin and not the RAW pin? I would have thought the regulator would only drain power if it was converting the RAW power down to 3.3v.
                                        sundberg84S Nca78N 2 Replies Last reply
                                        • dbemowskD dbemowsk
                                          sundberg84S
                                          sundberg84S
                                          @dbemowsk - your logic sounds right, but i think it will draw power anyway... only way to figure out is to measure or google :)
