716 Posts 111 Posters 703.2k Views 93 Watching
  • ferroF ferro
    @martins - you can use NRF2RFM69 if you want to use RFM69 with Newbie PCB board. I'm using it too, works fine with 3.3V arduino. For 5V arduino you will need to add level logic converter too.
    martinsM
    martinsM
    martins
    @ferro
    Pity because that would double the cost of the sensor board:
    Order PCBs for Easy/Newbie PCB for MySensors : $15
    Order PCBs for NRF2RFM69 : $15
    Martin
    • ferroF ferro
      @Amput said in 💬 Easy/Newbie PCB for MySensors:
      Could anyone explain me, why position (polarity) of condensers 4.7uF on REV 8(blue) and REV 9 (red) are different?
      It's a bug in v8 fixed in v9, so v9 is correct, see link this post
      AmputA
      AmputA
      Amput
      @ferro said in 💬 Easy/Newbie PCB for MySensors:
      Thx for answer :-).
      • martinsM martins
        @SUNDBERG84 - Do you have a board/design for the RFM69 radio ?
        Rergards,
        Martin
        sundberg84S
        sundberg84S
        @martins - No, not at the moment. It has been asked before but I have never got my head around it.
        As i told before, you are happy to develop it yourself. I have some other things in my list but in the future maybe :)
        • meanmrgreenM
          meanmrgreenM
          meanmrgreen
          wrote on last edited by meanmrgreen
          #273
          • meanmrgreenM
            meanmrgreenM
            meanmrgreen
            • N
              N
              N00phi
              Hi
              I've tried to order the capaciter and voltage regulator from our local electronics supplier. The choice is too big. Could anyone please help a "newbie" to select the right parts for a raw powered 5V version
              • 4.7uF capacitor
              • voltage regulator
              • 0.1 and 10uF cap
                http://www.distrelec.ch/ can't select the parts because of missing size and especially for the voltage regulator the exact type.
              • N N00phi
                Hi
                • 4.7uF capacitor
                • voltage regulator
                • 0.1 and 10uF cap
                sundberg84S
                sundberg84S
                @N00phi - I usually just select the ones at www.mysensors.org/store but if you have a specific site you wish to order from I can choose for you.
                N 1 Reply Last reply
                • sundberg84S sundberg84
                  N
                  N
                  N00phi
                  @sundberg84 It would be absolutely great if you could do so! I would order at http://www.distrelec.ch ...
                  • N N00phi
                    sundberg84S
                    sundberg84S
                    @N00phi for the capacitors: http://www.distrelec.ch/search?q=electrolytic+capacitor&filter_Rated+voltage~~VDC=50&filter_Diameter+housing~~mm=4&filter_Diameter+housing~~mm=5 (choose the axial types which is the one with two legs).
                    As for the voltage regulator I use LE33ACZ 5V-3.3V which i cant find on that site.
                    dbemowskD N 2 Replies Last reply
                      dbemowskD
                      dbemowskD
                      @sundberg84 said in 💬 Easy/Newbie PCB for MySensors:
                      Just for clarification, there is axial lead and radial lead components. The axial leads have both wires coming out of one side (as @sundberg84 mentions it looks like two legs). Radial leads have one wire coming out each side. I almost never use radial lead capacitors.
                        N
                        N
                        N00phi
                        wrote on last edited by N00phi
                        #280
                        @sundberg84 Thank you! One more question.. on the photo, there is a flat broun capacitor, what are the specifications for that one? Is it 0,1uF? But thats not an aluminium electrolytic capacitor, is it?
                        Oh, and the voltage regulator is available on aliexpress, found that one.
                        Nca78N 1 Reply Last reply
                        • N N00phi
                          @N00phi said in 💬 Easy/Newbie PCB for MySensors:
                          Yes it's the 0.1uF capacitor. It's a ceramic disc capacitor, but you won't have to search for the type of capacitor on aliexpress, low value capacitors are most of the time (always ?) ceramic disks if they are not of SMD type.
                          • cmrockwellC
                            cmrockwellC
                            cmrockwell
                            I would like to use this PCB with a 3.3V I2C sensor (data line and power must be <3.6V) and AC power. Is there a recommended way to accomplish this?
                            • cmrockwellC cmrockwell
                              sundberg84S
                              sundberg84S
                              @cmrockwell - Sorry, Im not following...
                              AC Power? You need some AC-DC converter then and this is not the intend of the PCB, sorry.
                              cmrockwellC 1 Reply Last reply
                                cmrockwellC
                                cmrockwellC
                                cmrockwell
                                @sundberg84
                                Sorry, I wasn't clear. I just meant running from a DC power supply, not batteries. It seems that the intended use is to have 5V Vcc when running from a power supply, but I would like a 3.3V Vcc. Thanks for your help. I have 10 of these PCBs in hand.
                                Nca78N sundberg84S 2 Replies Last reply
                                  @sundberg84
                                  @cmrockwell You can use a 3.3V / 8MHz pro-mini board and power everything with 3.3V.
                                    @sundberg84
                                    sundberg84S
                                    sundberg84S
                                    @cmrockwell - yes, the pcb is designed like @cmrockwell said. You can use either 3.3v or below (batteries) or a 5v regulated voltage. If you choose the 3.3v/bat version you need a 3.3v pro mini.
                                      cmrockwellC
                                      cmrockwellC
                                      cmrockwell
                                      @sundberg84
                                      OK, I figured out how to do what I wanted. I am planning to connect a regulated power supply that provides ~3.3VDC. The main thing I had to figure out was how to configure the PCB when neither a battery booster nor a regulator are needed. I think either shorting the REG pin and shorting the regulator or shorting the BAT pin and shorting the battery booster would each achieve the desired result.
                                        @sundberg84
                                        sundberg84S
                                        sundberg84S
                                        @cmrockwell - well done!
                                        Yes, digging deeper into it you can probably hack it many ways with jumpers and wires.
                                          If I want to use a mini pro 3.3v and a 18650 battery that I have lying around, should I use something like THIS or do you think there is a better/more efficient way?
