  3. Raspberry PI + MQTT Gateway + Domoticz -> Connection refused
6 Posts 3 Posters 6.4k Views 3 Watching
  • A Offline
    A Offline
    artipi
    Hello to all,
    i am happy to be here! This is great Platform, thanks for that:)
    To my Problem:
    I have installed a Raspberry with Domoticz and followed the Instructions on : https://www.mysensors.org/build/raspberry
    to create my Gateway.
    My Steps:
    cd MySensors
    ./configure --my-gateway=mqtt --my-controller-ip-address=127.0.0.1 --my-mqtt-publish-topic-prefix=mysensors-out --my-mqtt-subscribe-topic-prefix=mysensors-in --my-mqtt-client-id=mygateway1
    make
    sudo ./bin/mysgw -d
    And after that i am getting this Errors:
    pi@raspberrypi:~ $ cd MySensors/
    mysgw: Starting gateway...
    mysgw: TSF:LRT:OK
    mysgw: TSM:INIT
    mysgw: TSF:WUR:MS=0
    mysgw: TSM:INIT:TSP OK
    mysgw: TSM:INIT:GW MODE
    mysgw: MCO:REG:NOT NEEDED
    mysgw: MCO:BGN:STP
    mysgw: MCO:BGN:INIT OK,TSP=1
    mysgw: failed to connect
    Can someone help me?
    Thanks, Arthur.
    • A artipi
      Hello to all,
      To my Problem:
      My Steps:
      cd MySensors
      make
      sudo ./bin/mysgw -d
      mysgw: TSF:LRT:OK
      mysgw: TSM:INIT
      mysgw: TSF:WUR:MS=0
      mysgw: MCO:BGN:STP
      Thanks, Arthur.
      Welcome to the MySensors community @artipi !
      Domoticz is a mqtt client and wants to connect to a mqtt broker.
      The Mqtt gateway is also a mqtt client that wants to connect to a broker.
      So you need a mqtt broker that both clients can connect to.
      Luckily, Domoticz has instructions for installing mosquitti, which is a mqtt broker. It might already be installed on your system. If it is, you can instruct the gateway to connect to it by using --my-port=1883 in the configure command.
      If mosquitto isn't installed, you can install it by following these instructions: https://www.domoticz.com/wiki/MQTT#Installing_Mosquitto
      • A Offline
        A Offline
        artipi
        Thanks very much! Mosquitto was the solution!:)
        • A Offline
          A Offline
          artipi
          Just another question:
          How to test incomming messages to broker from msgw??
            You can install any mqtt client on computer, connect to mqtt broker and subscribe to topic # and you should be able to see all incoming messages. Or you can start playing with the ethernet gateway first (this way you can use myscontroller to monitor the gateway) and later move to mqtt.
            • A Offline
              A Offline
              artipi
              Ok, thanks.
