  3. fody weather station, wind sensor
windwinddirectiongusthyt221weatherwindspeedfodyhytht01dweather station
36 Posts 7 Posters 15.0k Views 7 Watching
  • F Offline
    F Offline
    flopp
    wrote on last edited by flopp
    Anyone heard of this before?
    https://www.kjell.com/se/sortiment/hem-kontor-fritid/fritid/termometrar-vaderstationer/vaderstationer/fody-tempus-pro-vaderstation-med-bluetooth-smart-p96552
    For 400 SEK(~€40) you get temp, hum, wind and rain on the outdoor unit and temp, hum and pressure on the indoor unit.
    Worth its price.
    I will open up the outdoor unit and try to connect to it with an Arduino.
    Other name for this is Alecto WS-48000
    • F Offline
      F Offline
      flopp
      I have now opened the outdoor unit.
      Anyone that have a code for collection data from 8 IR receivers?
      I need to find out what voltage the IR emitter is using, so I don't burn it.
      EDIT: google says 1,4-1,6 volt
      For wind it is simple to use interrupt
      Temperature and Humidity I don't know what kind of sensor it is, that one I can easily change to e.g. si7021/SHT21
      For wind direction it is using IR.
      wheel to control where IR is pointing
      For wind speed it is reed switch
      Control board
      Temperature and Humidity, about 2 cm high
      A 1 Reply Last reply
      • F flopp
        Control board
        A Offline
        A Offline
        AWI
        @flopp the Ir 'emitter' is probably a led so you need a current of a few milli amps. Start low (1 kOhm in series) and find out when it starts to function.
        F 1 Reply Last reply
        • A AWI
          F Offline
          F Offline
          flopp
          @AWI
          EDIT: give it 3,3 or 5 volt, use 512 ohm works.
          • F Offline
            F Offline
            flopp
            EDIT: I use digital input with pullup to see what sensor that receives the light
            So far I have a code for reading the direction and sending it to Controller.
            I will continue to add code for WindSpeed, Temp, Hum and Rain
            • F Offline
              F Offline
              flopp
              It was a HT-01D sensor for measuring temp/hum. It is I2C and address is 0x28.
              I found code for HYT 221 that worked fine.
              https://github.com/stylesuxx/Arduino-HYT-221-I2C
                I was looking at another product but your seems more easily hackable :)
                • D Offline
                  For anyone interested, I am in the process of designing a fully 3D printable weather station. The plan for the 3D printable parts will be:
                  • rain gauge
                  • combined wind speed and wind direction sensors
                  • radiation shield that will house sensors for temp, humidity, barometric pressure and possibly a lux sensor.
                  • central brain box for holding the MySensors electronics to control everything.
                  I am just finishing the wind speed and direction sensor parts today. I will post pics later. I have a post in this category for the rain gauge that will be part of the station. I am designing all the parts myself. I still need to figure out a few more parts plus the MySensors electronics and code. I'll post everything as I get the different parts done.
                  • F Offline
                    F Offline
                    flopp
                    gohanG 1 Reply Last reply
                    • F flopp
                      @flopp are you still using old library version? Are you going to make it a battery powered node or else? I noticed you didn't use any sleep in the code
                        F Offline
                        F Offline
                        flopp
                        @gohan said in fody weather station, wind sensor:
                        Yes, this is for 1.5
                        Are you going to make it a battery powered node or else?I noticed you didn't use any sleep in the code
                        This is powered from a PC, not battery. I want data very often that's why it is not battery powered. I can also change the code if something is wrong.
                        • F Offline
                          F Offline
                          flopp
                          S 1 Reply Last reply
                          • F flopp
                            @flopp - any more images? :)
                            • S sundberg84
                              F Offline
                              F Offline
                              flopp
                              @sundberg84
                              Can upload some later today.
                              I found that I have some problem with the NRf, so I need to open it up.
                              Will upload new code later today, as well.
                              • F Offline
                                F Offline
                                flopp
                                • F Offline
                                  F Offline
                                  flopp
                                  some pictures
                                  0_1493054883191_20170424_160412832_iOS.jpg 0_1493054891231_20170424_160402858_iOS.jpg 0_1493054901570_20170424_160025939_iOS.jpg 0_1493054908764_20170424_160020368_iOS.jpg
                                  • F Offline
                                    F Offline
                                    flopp
                                    I am using this water proof connector for USB connection.
                                    https://www.aliexpress.com/item/Free-Shipping-3-Sets-All-New-4-Pin-Waterproof-Electrical-Wire-Connector-Plug-HID-Male-female/32264045957.html
                                    in sweden you can buy it at Biltema
                                    • F Offline
                                      F Offline
                                      flopp
                                      I have not verify all the code yet.
                                      Wind direction is correct.
                                      Temp is little bit higher then another temp that I have on shadow so maybe the radiation shield is not working 100%
                                      Hum: my other sensor that I have outdoor broke a few weeks ago, so nothing to compare with
                                      Wind Speed: I want to verify with an RPM tool. I get some extra indication from reeed switch.
                                      Every second indication is below 1000 micros which is 1 millisecond, which is 1000m/s
                                      Rain: lucky or unlucky I have not had any rain when the mast was up and running
                                        Maybe you need a better heat shield, did you try some aluminum foil?
                                          F Offline
                                          F Offline
                                          flopp
                                          Good idea :)
                                          Should I have the foil inside the shield or outside?
                                          Any pics if you done it yourself?
                                          I think I need some air through the shield so it can cool down.
                                          12.1k
