716 Posts 111 Posters 703.1k Views 93 Watching
  • nitroburnN nitroburn
    @sundberg84: sadly I only did it for the jModule boards but realize now I should have done it with your board as well since I could have got 4x as many for the same price. I realized after I could have got significantly more of those as well, or just have spent less. Might have had to trim a little bit from the dimensions though as I don't know about clearances using the full 100x100 without room to split the boards, but I could be wrong due to them being square Actually, after just checking pcbway's site it says, "Leave min clearance of 1.6mm between boards for break-routing. For V-score panelization, set the space between boards to be zero." so I could have got 120 boards for $25 as they are actually 48.66x49.86 per board. Or combined different boards together as I think 120 would be overkill :) I never realized how inexpensive it is compared to etching your own. It would be crazy to etch at these prices.
    Thanks for the great starting point and learning experience.
    @Nca78: Yeah, PCBways base price is $5 for 10 100x100 as well but they don't seem to charge for vcut (doesn't change quote) and allow 0mm spacing so no need to cut. I used EMS to ship and was here in 3 days without taxes or fees unlike DHL has every single time I use them. $15 just to collect $0.10 in tax.
    @nitroburn said in 💬 Easy/Newbie PCB for MySensors:
    So yesterday I tried to submit my PCBs to PCBWay, they accept similar design if you don't check panelizing options, but my interest is to lower prices by combining different PCBs on the same board. I don't need them to cut anything, but they just refused and changed to panelized version. In the end it was 137$ compared to less than 70 with Seeed.
    So PCBWay is great to have many similar boards (but who really needs 50-60 items of the same board ?) but if you want to save costs by combining multiple boards it's not an option.
    S nitroburnN 2 Replies Last reply
    • Nca78N Nca78
      Samuel235
      @Nca78 - This is exactly why i was shocked when someone got away with it. They get personally checked every time and soon as they pick something up where they can see two separate boards there then they refuse it unless you paid the extra for the panelising.
      MySensors 2.1.1
        Draw some fake routes across the boards, maybe they will not notice it 😀
        • Nca78N Nca78
          nitroburnN
          nitroburnN
          nitroburn
          @Nca78
          @Nca78 said in 💬 Easy/Newbie PCB for MySensors:
          I combined different PCBs and right on the form for submitting them for a quote it explains you just select how many different designs you want per board, so if you fit 3 different designs but with 8 total boards from the 100x100, you just enter 3 designs and submit all 3 gerbers individually zipped inside a main zip file. In my case, I selected 2 designs and submitted both as single not panalized. You can always just copypaste them together in eagle or something and avoid them saying anything about it.
          Only extra thing I did was submit the board size as the 2 designs added together then in the requirements specified there were 2 designs one being X * Y and the other X * Y. I don't know if they would have accepted me requesting they then put the designs onto one board more then once, but I assume that is what they would do for the panalization. It definitely doesn't have to be the same design on 1 board. Order 10 pcs, fit 4 designs or 2 designs 2 time and end up with 40 total PCBs. But I do notice if you have 2 designs done 8 times total and you want the boards pre-separated then you would say 8. But yeah, that does raise the price. Weird because I swear it wasn't doing it like that before.
          I guess I just got lucky and had a nice person review my files and they combined and separated them for me for free. In the future I'm just going to throw a panel together myself and submit as 1 design and maybe not even bother to have them score the boards, I'll do it myself and then it's definitely 1 design. They must have felt bad I was ordering 30x23 boards wasting the rest of the 100x100 so they threw them together. Its a 10 second copy and paste so I'll just do it myself next time and not bother with them charging more. Could also be they counted it as 1 design because the sizes were nearly identical.
          • maghacM
            maghacM
            maghac
            A completely unrelated question: what is that header called that @jens-persson used on the MySX connector (see the pic that I reposted above)? I soldered the longer, jumper-style, headers instead so I can connect dupont wires.
            Are there any benefits to using this other type of header? (And what does the corresponding male connector look like)?
            Nca78N 1 Reply Last reply
            • maghacM maghac
              @maghac said in 💬 Easy/Newbie PCB for MySensors:
              It's just header with round pins. No interest in using them IMHO, better stick to the standard square shaped headers as they are the more common. You cannot use standard square shaped headers with those so it's a bit limiting.
                2rDK
                Please note, that when using the link to ITEAD, the order is not actually completed. The order is received by ITEAD, you get an order confirmation and everything, but the order is actually not processing before you upload the gerber files.
                This may be a beginners mistake, as it is the first time i'm using this service. I had the understanding that when you pressed the shopping cart above, and chose a service the gerber-part of the transaction would be handled automatic.
                I dont know if this is a misunderstanding on my side, I may have misunderstood the instructions on this site. It also may be an error on ITEAD's side as they didn't process the order correctly.
                What is your experience with this ?
                My problem is solved now, as I wrote and asked ITEAD for status. They made me aware of the issue and I emailed them the gerbers.
                This is in no way a critique of the project. I really appreciate the hours of work put into it.
                  @R2DK, sounds strange.
                  Should just be a one-click operation to order... and you shouldn't have to do any gerber uploads.
                  Could you PM me who you were in contact with over at ITEAD?
                  • sundberg84S
                    sundberg84S
                    We have sold pcbs from itead before and this is the first time I hear this. As @hek said it should be a 1 click operation but something maybe went wrong just this time?
                      mickecarlsson
                      This happened to me too, I ordered from the link, and thought I was Ok with the order. Yesterday I did find out that my order was waiting for the gerber files, so I downloaded, zipped and uploaded the to itead. I also mailed them about it. Got a reply that they should check the gerber files.
                      • M mickecarlsson
                        sundberg84S
                        sundberg84S
                        @mickecarlsson - I think @hek are looking into this... if I look at my Sales stat there are mostly ordered/aborted from Itead without known reason so they have not been comfirmed. The lastest revision from EasyPCB is over 7 months old and works great with PCBway... so if the gerber files are bad I hope I would have been notised before.
                          I have mailed the person responsible for the integration. Hope to get some answers tomorrow.
                            mickecarlsson
                            wrote on last edited by mickecarlsson
                            #380
                            Allright, now it looks like I am getting them :+1:
                            PCBs have been finished and are ready to be sent out.
                            • markjgabbM
                              markjgabbM
                              markjgabb
                              same hear...i ordered from itead...i had to upload the gerbers myself....
                              • D
                                dakipro
                                I have some issues with battery powered version with this board, maybe someone can point out what I did wrong. I have several of these boards working great (rev 8 says on them, the radio cap is however properly connected). I recently noticed that battery powered sensors do not work if battery is under 2.7v (on one pro mini it goes under 2.3v) even thought I have 3.3v booster. I have one dht22 sensor, measuring resistors and cap, bat jumper, basically my board looks exactly like example on the openharware, this one https://www.openhardware.io//uploads/568ed84b60aa3f8965fbf095/image/Rev8 Bat.jpg
                                Also did the battery hack, removed led and removed onboard regulator.
                                I have rechecked several times, changed several radios and several arduinos, but they just wont work reliably on lover battery power then 2.8v . Is that the limit?
                                I cannot debug using serial adapter, as when I connect it, then pro works fine as it gets 3.3v from the pc.
                                But here is some debug measurements I did on 2.5v batteries: vcc - gnd pins on pro mini show 3.3v. Pins out of booster do show 3.3v. So do pins on the dht22.
                                Pins on the radio show 2.5v, so do D2-gnd show 2.5v (or -2.5v i forgot). Why does pin2 have 2.5v, I have desoldered it so it is not connected to anything, I guess that is some feedback voltage from the radio (as dht22 gets 3.3v) Can this pin (or voltage measurement a0) somehow disturb the pro mini?
                                Do you have some suggestions on how I can debug what is going on?
                                The led on arduino goes red for 3-4s, then goes off for 2s then again red for 3s, then off...
                                I have two identical boards, and only thing that is determining the lov limit is pro mini modules. Some of them go to 2.7v (on both boards) and on of them goes down to 2.3v on both boards. I do not understand why when they do get 3.3v on the vcc from the booster?
                                What is the lowest voltage the batteries can go (with the 3.3v booster)?
                                • D dakipro
                                  sundberg84S
                                  sundberg84S
                                  #383
                                  @dakipro - hi!
                                  No, the limit should be (if you have a genuine radio) 1,9v. Im not sure what kind of voltages a clone will manage, but my nodes goes below 2.8v!
                                  This should not be a problem - you can power the node from the "normal" way and just connect RX/TX and GND from the ftdi to the arduino ftdi header. I have done this several times.
                                  D2-gnd show 2.5v
                                  The IRQ line from the radio is 2.5v since thats what the radio gets. Im not exactly sure what this does, but in SPI which is what the radio are using, its either HIGH or LOW so 2.5v sounds right since the radio has that voltage. This should not disturb the arduino! This is changed in REV9 so you can disconnect D2 from the radio if wanted. You should not use D2 for any sensor below Rev9.
                                  Sounds like the radio is transmitting... if this goes on and on it can mean the radio isnt getting connected/ack or establish a way to the gateway.
                                  You need to check the debut output (see above)!
                                  Could you describe the issue? Are the node lost from the controller?
                                  1.9v is the minimum to the radio.
                                  0,8v is the minimum for the booster.
                                  keldandorinK 1 Reply Last reply
                                  • D
                                    dakipro
                                    Thank you for your answer, the tip about debugging helped a lot.
                                    I now checked on one board and it looks that some pro minis are having problems when battery voltage goes bellow certain level (f.eks. 2.7v).
                                    Testing results:
                                    "good pro mini" works up to 2.0v , on 1.9v it shows fallowing errors
                                    send: 4-4-0-0 s=1,c=0,t=7,pt=0,l=0,sg=0,st=fail:
                                    find parent
                                    send: 4-4-255-255 s=255,c=3,t=7,pt=0,l=0,sg=0,st=bc:
                                    send: 4-4-0-0 s=2,c=0,t=6,pt=0,l=0,sg=0,st=fail:
                                    temp: nan
                                    nan
                                    send: 4-4-0-0 s=255,c=3,t=0,pt=1,l=1,sg=0,st=fail:62
                                    send: 4-4-0-0 s=2,c=1,t=0,pt=7,l=5,sg=0,st=fail:0.00
                                    send: 4-4-0-0 s=1,c=1,t=1,pt=7,l=5,sg=0,st=fail:0.0
                                    "bad pro mini" works fine above 2.7, on 2.6 it logs
                                    84973 MCO:SLP:MS=15000,SMS=1,I1=255,M1=255,I2=255,M2=255
                                    85047 !MCO:SLP:TNR
                                    85874 TSM:FAIL:RE-INIT
                                    85897 TSM:INIT
                                    85919 TSM:INIT:TSP OK
                                    85942 TSM:INIT:STATID=3
                                    85968 TSF:SID:OK,ID=3
                                    85991 TSM:FPAR
                                    86042 TSF:MSG:SEND,3-3-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                                    88117 !TSM:FPAR:NO REPLY
                                    88141 TSM:FPAR
                                    88193 TSF:MSG:SEND,3-3-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                                    90269 !TSM:FPAR:NO REPLY
                                    90294 TSM:FPAR
                                    90345 TSF:MSG:SEND,3-3-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                                    92422 !TSM:FPAR:NO REPLY
                                    92446 TSM:FPAR
                                    92497 TSF:MSG:SEND,3-3-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                                    94574 !TSM:FPAR:FAIL
                                    94595 TSM:FAIL:CNT=4
                                    94617 TSM:FAIL:PDT
                                    95066 MCO:SLP:MS=4999
                                    95088 !TSF:SND:TNR
                                    95610 MCO:SLP:TPD
                                    What I see on the log parser is that the "No potential parents replied to find parent request" pops out as the biggest issue, suggesting that radio communication is not doing well.
                                    I am testing using the small bench power supply (the Chinese ones with the oled screen) so the current should not be the problem. Why would pro mini be the problem, when it is getting 3.3v directly from same stepup?
                                    The radio and all other components are exactly the same in all the tests i just swap the minis, I think radio would have failed with both minis if it is the radio... or perhaps the signal to the radio is not good/stable enough? No idea to be honest :)
                                    If that matters: they are all getting 2.7v (or what I set) on pin 2 even though I have physically cut the connection to the radio irq (with the knife, on the board, they are not touching anything else on the board).
                                    p.s. now that I write this, i realize that another difference is the sketch on them, "the good one" is "vanilla" mysensors 1.5 code and all the bad ones are latest mysensors using the node-manager library. I do not know enough about chip programming, but as a web developer I would think that the code should not determine minimum voltage needed on board? (or there are some routines in some strange combination doing some magic... hm...)
                                    • D
                                      dakipro
                                      Well I just tested with latest example from mysensors library, and we can exclude my latest p.s., nothing to do with using the node-manager (as expected).
                                      Only difference is the pro minis (but again, they should all get 3.3v via popup)?
                                      and on the "good" node I have mysensors 1.5 while on the others I use 2.1.
                                      • D dakipro
                                        sundberg84S
                                        sundberg84S
                                        @dakipro - It looks like when the voltage drops, you are having issues with your radio (No reply and ST=Fail).
                                        This should not be a problem, since this is powered directly from the batteries and you say there are 2.8v left.
                                        The first thing that comes to my mind is that as the voltage drops, the booster needs to work harder and introduces more noice into the board. As the noice increase, the radio gets in trouble.
                                        The other I can imagine is that you have a bad clone which cant handle lower voltages.
                                        Both problems are a bit tricky to diagnose. First I would try some different radios, if possible from different batches. Second I would look more close to the booster. They vary greatly in quality and some are just really bad. Sometimes a cheramic capacitor might help (from output to gnd on the booster). You could also just disconnect the booster and see if it works (the pro mini shoudl be able to handle down to 2.8v).
                                        • D
                                          dakipro
                                          After several hours of debugging and changing all possible components, i built exactly same circuit on prototype board and with exactly same (active) components I was able to go down to 1.9, sometimes to 1.8, while on the easyboard only down to 2.6. I also used exactly the same booster on both prototype and on the easyboard.
                                          But then a breakthrough, I have found one passive component that was different between the two mentioned boards! It was the radio freaking capacitor, on the "good" board it was 47uf, and on the problematic board had 4.7uf!
                                          I changed radio cap to 47uf and I am now able to go on both boards down to 2.3v. Which is ok, not the 1.9v but it is good enough (for now :) ) So those 42.3uf were missing for radio to go ~0.5v lower in voltage I guess.
                                          The one thing I am missing on the prototyping board is the voltage measurement circuit, so I guess that gives some 0.4v lowest threshold or something, i will test these days on the prototyping board, just to verify.
                                          Thank you @sundberg84 for attention and help :)
                                          Are you able to provide 1.9v on battery input on some easy board with the dht22? Like the one from the photos on the openhardware?
                                          sundberg84S dbemowskD 2 Replies Last reply
