  3. Mqtt + sensors
Mqtt + sensors
3 Posts 2 Posters 1.8k Views 3 Watching
  • A
    alop
    I have now trying the setup where I have on raspberry 3 mosquitto as MQTT running and mysensors gateway also setup there. As controller I'm using home assistant.
    I can see that mqtt receives data from gateway.
    But how do I send data from my sensors (atmega328p) over nrf24l01+ to gateway?
    What do I need to add in the skatch?
    gateway:
    mysgw: Starting gateway...
    mysgw: MCO:BGN:INIT GW,CP=RNNG----,VER=2.2.0-beta
    mysgw: TSF:LRT:OK
    mysgw: TSM:INIT
    mysgw: TSF:WUR:MS=0
    mysgw: TSM:INIT:TSP OK
    mysgw: TSM:INIT:GW MODE
    mysgw: MCO:REG:NOT NEEDED
    mysgw: MCO:BGN:STP
    mysgw: MCO:BGN:INIT OK,TSP=1
    mysgw: connected to 127.0.0.1
    mysgw: MQTT connected
    skatch:
     * Version 1.0 - Henrik EKblad
     * Example sketch showing how to measue light level using a LM393 photo-resistor
     * http://www.mysensors.org/build/light
    #define MY_NODE_ID 66
    #define MY_MQTT_TOPIC_PREFIX "mygateway"
    #define CHILD_ID_LIGHT 15
    int lastLightLevel;
        sendSketchInfo("Light Sensor", "1.0");
        int16_t lightLevel = (1023-analogRead(LIGHT_SENSOR_ANALOG_PIN))/10.23;
        Serial.println(lightLevel);
            send(msg.set(lightLevel));
            lastLightLevel = lightLevel;
        sleep(SLEEP_TIME);
    • A alop
      gateway:
      mysgw: TSF:LRT:OK
      mysgw: TSM:INIT
      mysgw: TSF:WUR:MS=0
      mysgw: MCO:BGN:STP
      skatch:
      int lastLightLevel;
          sleep(SLEEP_TIME);
      @alop what happens when you run the node?
      A 1 Reply Last reply
        alop
        @mfalkvidd no communication
        653955 TSF:SID:OK,ID=66
        653958 TSM:FPAR
        653977 TSF:MSG:SEND,66-66-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
        655984 !TSM:FPAR:NO REPLY
        655986 TSM:FPAR
        656006 TSF:MSG:SEND,66-66-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
        658014 !TSM:FPAR:NO REPLY
        658016 TSM:FPAR
        658035 TSF:MSG:SEND,66-66-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
        This here is another try to solve issues as in this post LINK
