  3. How to great variables
variablesmycontroller.orgarduino
2 Posts 2 Posters 1.1k Views 2 Watching
  • W
    W
    wint0178
    I'm running a MyController v 2.0 server on Rasp Pi v4. The server is setup on a DDNS so that I can send data from gateways and notes in remote locations back to the server and gain access world wide. I have had some success using the available MySensors example sketches in Adruino libraries in getting the BME680, for example, connected and transmitting data, but I am trying to add in other Adafruit boards and am getting cought up on defining the variables. As an example, I noticed that the BME680 has a gas sensor along with temp, press, and humidity. So, using the available example, I tried to create a variable for the gas value AND for the two values that are available on the CCS811 board as follows:
    //create mysensors varibles, send as V_custom not as a JSON
    MyMessage temperatureMSG(TEMP_CHILD_ID, V_TEMP);
    MyMessage humidityMSG(HUM_CHILD_ID, V_HUM);
    MyMessage pressureMSG(BARO_CHILD_ID, V_PRESSURE);
    MyMessage gasMSG(GAS_CHILD_ID, V_GAS);
    MyMessage coMSG(CO_CHILD_ID, V_CO);
    MyMessage tvocMSG(TVOC_CHILD_ID, V_TVOC);
    But, I get the error (FYI, I cut most of the top of the compiling log believing it is not helpful here):
    Using library MySensors at version 2.3.2 in folder: /Users/bjw58994/Documents/Arduino/libraries/MySensors
    Using library SPI at version 1.0 in folder: /Users/bjw58994/Library/Arduino15/packages/esp8266/hardware/esp8266/2.7.4/libraries/SPI
    Using library ESP8266WiFi at version 1.0 in folder: /Users/bjw58994/Library/Arduino15/packages/esp8266/hardware/esp8266/2.7.4/libraries/ESP8266WiFi
    Using library EEPROM at version 1.0 in folder: /Users/bjw58994/Library/Arduino15/packages/esp8266/hardware/esp8266/2.7.4/libraries/EEPROM
    Using library Wire at version 1.0 in folder: /Users/bjw58994/Library/Arduino15/packages/esp8266/hardware/esp8266/2.7.4/libraries/Wire
    Using library Adafruit Unified Sensor at version 1.1.14 in folder: /Users/bjw58994/Documents/Arduino/libraries/Adafruit_Unified_Sensor
    Using library Adafruit BME680 Library at version 2.0.4 in folder: /Users/bjw58994/Documents/Arduino/libraries/Adafruit_BME680_Library
    Using library Adafruit BusIO at version 1.15.0 in folder: /Users/bjw58994/Documents/Arduino/libraries/Adafruit_BusIO
    Using library Adafruit CCS811 Library at version 1.1.3 in folder: /Users/bjw58994/Documents/Arduino/libraries/Adafruit_CCS811_Library
    Using library RadioHead at version 1.122.1 in folder: /Users/bjw58994/Documents/Arduino/libraries/RadioHead
    exit status 1
    Compilation error: 'GAS_CHILD_ID' was not declared in this scope
    Ultimately, I don't understand how to define or pick a variable, I thought it was user defined, but this makes me think perhaps they are already defined in a library somewhere. Any help in directing me to either the correct structure/sytax of the variables or the location they are defined would be great. Thanks!
    • W wint0178
      exit status 1
      Nice work so far @wint0178, great that you try expanding on the examples. Sorry for the late reply.
      If you look at https://github.com/mysensors/MySensorsArduinoExamples/blob/bba998bce09bc5139eb4ca7a05b0279f4083ff88/examples/PressureSensor/PressureSensor.ino#L90 you see where the existing child ids are defines. You just add another one for the gas sensor, with a unique number (incrementing by 1 is an easy way).
      Try that and report back on your result. If something is unclear, just post a followup.
