  3. nRF5 action!
nRF5 action!
    #443
    //#define MY_RADIO_NRF24
    #define MY_RADIO_NRF5_ESB
    //#include <MySensors.h>
    int oldBatteryPcnt = 0;
    uint16_t counter=0;
    uint16_t volts=0;
    uint16_t theHwCPUVoltage()
    #if defined(NRF_ADC)
      // NRF51:
      // 20uS@260uA
      NRF_LPCOMP->ENABLE = 0;
      // Enable and configure ADC
      NRF_ADC->ENABLE = 1;
      NRF_ADC->EVENTS_END = 0;
      NRF_ADC->TASKS_START = 1;
      while(!NRF_ADC->EVENTS_END);
      NRF_ADC->TASKS_STOP = 1;
      NRF_ADC->ENABLE = 0;
      // Restore LPCOMP state
      return (sample*3600)/255;
    #elif defined(NRF_SAADC)
      // NRF52:
      // Sampling time 3uS@700uA
      int32_t sample;
      NRF_SAADC->RESULT.MAXCNT = 1;
      NRF_SAADC->TASKS_START = 1;
      NRF_SAADC->EVENTS_END = 0;
      NRF_SAADC->TASKS_SAMPLE = 1;
      NRF_SAADC->TASKS_STOP = 1;
      // unknown MCU
      return 0;
      while (true) {
        volts=theHwCPUVoltage();
        Serial.print("counter=");
        Serial.print(counter++);
        Serial.println(volts);
    //#else
    //	analogReference(INTERNAL);
    //#endif
        For this, you can use the implemented hwCPUVoltage() function.
        I tried this function call on an nRF52 DK, and it seems to work. I then tried it on an Ebyte module, treated as an nRF52 DK "board", and it reported zero voltage. So, probably I just need to do a pin mapping so that it reads the voltage on the proper pin. But which pin/mapping would it be? I thought that Vcc wouldn't really be mappable to anything but Vcc. I guess whichever analog pin (if that's what it is?) is connected to Vcc on the nRF52 DK is the pin I need to find and re-map to its equivalent pin on the Ebyte module. Hmmm.... I'll have to look into which one that would be.
        d00616D
        d00616D
        d00616
          mtiutiuM 1 Reply Last reply
              Mike_Lemo
              @NeverDie Dam you why would you make it so wide? can it fit on a single bread board?
              • M Mike_Lemo
                #449
                Sorry, you'll need two.
                  mtiutiuM
                  mtiutiuM
                  mtiutiu
                  #450
                  • mtiutiuM mtiutiu
                    Here: https://www.aliexpress.com/item/NRF52832-Bluetooth-4-2-module-Bluetooth-5-program-PCBA-serial-transmission-cost-effective/32818791344.html?spm=a2g0s.9042311.0.0.jWh9gH
                    Nca78N 1 Reply Last reply
                      @NeverDie I guess you don't need to make a breakout board for those, your spare NModules will do if you use the "PA/LNA" radio footprint ;)
                      • Nca78N Nca78
                        @Nca78
                        Thanks! Good to know.
                        • Nca78N
                          Just realized it has 2 extra I/O on the side, and the SWD are only pads on top, which makes 8 I/O available, it's much more interesting than the NRF51822 version.
                          • Nca78N Nca78
                            @Nca78
                            Is there even a way to program the nRF51822 version? I'd have to check, but I don't recall the two SWD pins being on its pinout.
                              @Nca78
                              @Nca78
                              They are on the pinout, so you only have 4 I/Os available.
                              • d00616D d00616
                                d00616D 1 Reply Last reply
                                  Mike_Lemo
                                  From what I understand the NRF52832 has some kind of enforcer that allows different serial hardwares to be assigned to different pins
                                      Mike_Lemo
                                      Does anybody know why the function tone() doesn't work for the nrf52?
                                      mfalkviddM d00616D 2 Replies Last reply
                                      • M Mike_Lemo
                                          Mike_Lemo
                                          BUZZER_PIN = 26
                                          BUZZER_TONE = 3000
