  3. nRF5 action!
nRF5 action!
      For this, you can use the implemented hwCPUVoltage() function.
      I tried this function call on an nRF52 DK, and it seems to work. I then tried it on an Ebyte module, treated as an nRF52 DK "board", and it reported zero voltage. So, probably I just need to do a pin mapping so that it reads the voltage on the proper pin. But which pin/mapping would it be? I thought that Vcc wouldn't really be mappable to anything but Vcc. I guess whichever analog pin (if that's what it is?) is connected to Vcc on the nRF52 DK is the pin I need to find and re-map to its equivalent pin on the Ebyte module. Hmmm.... I'll have to look into which one that would be.
      d00616D
      d00616D
      d00616
        mtiutiuM 1 Reply Last reply
            Mike_Lemo
            @NeverDie Dam you why would you make it so wide? can it fit on a single bread board?
            • M Mike_Lemo
              #449
              Sorry, you'll need two.
                mtiutiuM
                mtiutiuM
                mtiutiu
                #450
                • mtiutiuM mtiutiu
                  Here: https://www.aliexpress.com/item/NRF52832-Bluetooth-4-2-module-Bluetooth-5-program-PCBA-serial-transmission-cost-effective/32818791344.html?spm=a2g0s.9042311.0.0.jWh9gH
                  Nca78N 1 Reply Last reply
                    @NeverDie I guess you don't need to make a breakout board for those, your spare NModules will do if you use the "PA/LNA" radio footprint ;)
                    • Nca78N Nca78
                      @Nca78
                      Thanks! Good to know.
                      • Nca78N
                        Just realized it has 2 extra I/O on the side, and the SWD are only pads on top, which makes 8 I/O available, it's much more interesting than the NRF51822 version.
                        • Nca78N Nca78
                          @Nca78
                          Is there even a way to program the nRF51822 version? I'd have to check, but I don't recall the two SWD pins being on its pinout.
                            @Nca78
                            @Nca78
                            They are on the pinout, so you only have 4 I/Os available.
                            • d00616D d00616
                              d00616D 1 Reply Last reply
                                Mike_Lemo
                                From what I understand the NRF52832 has some kind of enforcer that allows different serial hardwares to be assigned to different pins
                                    Mike_Lemo
                                    Does anybody know why the function tone() doesn't work for the nrf52?
                                    mfalkviddM d00616D 2 Replies Last reply
                                    • M Mike_Lemo
                                        Mike_Lemo
                                        BUZZER_PIN = 26
                                        BUZZER_TONE = 3000
                                        • M Mike_Lemo
                                          BUZZER_PIN = 26
                                          BUZZER_TONE = 3000
                                          ATmega8
                                          ATmega168/328
                                          ATmega1280
