  3. nRF5 action!
nRF5 action!
    For this, you can use the implemented hwCPUVoltage() function.
    I tried this function call on an nRF52 DK, and it seems to work. I then tried it on an Ebyte module, treated as an nRF52 DK "board", and it reported zero voltage. So, probably I just need to do a pin mapping so that it reads the voltage on the proper pin. But which pin/mapping would it be? I thought that Vcc wouldn't really be mappable to anything but Vcc. I guess whichever analog pin (if that's what it is?) is connected to Vcc on the nRF52 DK is the pin I need to find and re-map to its equivalent pin on the Ebyte module. Hmmm.... I'll have to look into which one that would be.
    d00616D
    d00616D
    d00616
      mtiutiuM 1 Reply Last reply
          Mike_Lemo
          @NeverDie Dam you why would you make it so wide? can it fit on a single bread board?
          • M Mike_Lemo
            #449
            Sorry, you'll need two.
              mtiutiuM
              mtiutiuM
              mtiutiu
              #450
              • mtiutiuM mtiutiu
                Here: https://www.aliexpress.com/item/NRF52832-Bluetooth-4-2-module-Bluetooth-5-program-PCBA-serial-transmission-cost-effective/32818791344.html?spm=a2g0s.9042311.0.0.jWh9gH
                Nca78N 1 Reply Last reply
                  @NeverDie I guess you don't need to make a breakout board for those, your spare NModules will do if you use the "PA/LNA" radio footprint ;)
                  • Nca78N Nca78
                    @Nca78
                    Thanks! Good to know.
                    • Nca78N
                      Just realized it has 2 extra I/O on the side, and the SWD are only pads on top, which makes 8 I/O available, it's much more interesting than the NRF51822 version.
                      • Nca78N Nca78
                        @Nca78
                        Is there even a way to program the nRF51822 version? I'd have to check, but I don't recall the two SWD pins being on its pinout.
                          @Nca78
                          @Nca78
                          They are on the pinout, so you only have 4 I/Os available.
                          • d00616D d00616
                            d00616D 1 Reply Last reply
                              Mike_Lemo
                              From what I understand the NRF52832 has some kind of enforcer that allows different serial hardwares to be assigned to different pins
                                  Mike_Lemo
                                  Does anybody know why the function tone() doesn't work for the nrf52?
                                  mfalkviddM d00616D 2 Replies Last reply
                                  • M Mike_Lemo
                                      Mike_Lemo
                                      BUZZER_PIN = 26
                                      BUZZER_TONE = 3000
                                      • M Mike_Lemo
                                        BUZZER_PIN = 26
                                        BUZZER_TONE = 3000
                                        ATmega8
                                        ATmega168/328
                                        ATmega1280
                                          ATmega8
                                          ATmega168/328
                                          ATmega1280
                                          Mike_Lemo
                                          ATmega8
                                          ATmega168/328
                                          ATmega1280
                                          How is it possible to make it copatible with the NRF52?
