  3. nRF5 action!
nRF5 action!
  • d00616D d00616
    I tried this function call on an nRF52 DK, and it seems to work. I then tried it on an Ebyte module, treated as an nRF52 DK "board", and it reported zero voltage.
    d00616D 1 Reply Last reply
      Mike_Lemo
      From what I understand the NRF52832 has some kind of enforcer that allows different serial hardwares to be assigned to different pins
          Mike_Lemo
          Does anybody know why the function tone() doesn't work for the nrf52?
          mfalkviddM d00616D 2 Replies Last reply
          • M Mike_Lemo
              Mike_Lemo
              BUZZER_PIN = 26
              BUZZER_TONE = 3000
              • M Mike_Lemo
                BUZZER_PIN = 26
                BUZZER_TONE = 3000
                ATmega8
                ATmega168/328
                ATmega1280
                  ATmega8
                  ATmega168/328
                  ATmega1280
                  Mike_Lemo
                  ATmega8
                  ATmega168/328
                  ATmega1280
                  How is it possible to make it copatible with the NRF52?
                  • M Mike_Lemo
                    ATmega8
                    ATmega168/328
                    ATmega1280
                    #465
                    @Mike_Lemo it (the tone library) would need to be ported
                      Mike_Lemo
                      @Mike_Lemo it would need to be ported
                      No idea what you are talking about.
                      • M Mike_Lemo
                          Some further evidence in support of this hypothesis (from: https://github.com/mysensors/ArduinoHwNRF5):
                            Mike_Lemo
                              Mike_Lemo
                              Someone managed to get NFC to work with this IC on the arduino IDE?
                                • Nca78N
                                  • Nca78N Nca78
                                    • TerrenceT
                                      TerrenceT
                                      Terrence
                                      Some Nordic guidance might help.
                                        #475
                                        results in a loss of control by the sketch itself to something within MySensors that wants to establish communication between the node and the gateway. Not even sure how that is happening. In any case, it is just overcomplicating the debugging, and I really don't want that right now because it is effectively hanging what I'm trying to do. :angry:
                                          d00616D
                                          d00616D
                                          d00616
