nRF5 action!
Just realized it has 2 extra I/O on the side, and the SWD are only pads on top, which makes 8 I/O available, it's much more interesting than the NRF51822 version.
@Nca78
Is there even a way to program the nRF51822 version? I'd have to check, but I don't recall the two SWD pins being on its pinout.@NeverDie said in nRF5 Bluetooth action!:
@Nca78
Is there even a way to program the nRF51822 version? I'd have to check, but I don't recall the two SWD pins being on its pinout.They are on the pinout, so you only have 4 I/Os available.
I tried this function call on an nRF52 DK, and it seems to work. I then tried it on an Ebyte module, treated as an nRF52 DK "board", and it reported zero voltage.
From what I understand the NRF52832 has some kind of enforcer that allows different serial hardwares to be assigned to different pins
#define SDA...(Something else I don't know ) 12 -
BUZZER_PIN = 26
BUZZER_TONE = 3000 -
BUZZER_PIN = 26
BUZZER_TONE = 3000@Mike_Lemo if you mean the stuff described at https://www.arduino.cc/en/Reference/Tone it's because it only supports the following mcus:
ATmega8
ATmega168/328
ATmega1280 -
ATmega8
ATmega168/328
ATmega1280@mfalkvidd said in nRF5 Bluetooth action!:
ATmega8
ATmega168/328
ATmega1280How is it possible to make it copatible with the NRF52?
ATmega8
ATmega168/328
@Mike_Lemo it (the tone library) would need to be ported
@Mike_Lemo it would need to be ported
No idea what you are talking about.
Some further evidence in support of this hypothesis (from: https://github.com/mysensors/ArduinoHwNRF5):
0_1501606355303_MyNRF5Board.cpp -
Radio is internally connected inside the nrf52 chip so I don't see how a module could have a different mapping ? -
Radio is internally connected inside the nrf52 chip so I don't see how a module could have a different mapping ?@Nca78 said in nRF5 Bluetooth action!:
Some Nordic guidance might help.
