  3. nRF5 action!
nRF5 action!
  • M Mike_Lemo
    Does anybody know why the function tone() doesn't work for the nrf52?
      Mike_Lemo
      BUZZER_PIN = 26
      BUZZER_TONE = 3000
      • M Mike_Lemo
        BUZZER_PIN = 26
        BUZZER_TONE = 3000
        ATmega8
        ATmega168/328
        ATmega1280
          ATmega8
          ATmega168/328
          ATmega1280
          Mike_Lemo
          ATmega8
          ATmega168/328
          ATmega1280
          How is it possible to make it copatible with the NRF52?
          • M Mike_Lemo
            ATmega8
            ATmega168/328
            ATmega1280
            #465
            @Mike_Lemo it (the tone library) would need to be ported
              Mike_Lemo
              @Mike_Lemo it would need to be ported
              No idea what you are talking about.
              • M Mike_Lemo
                  Some further evidence in support of this hypothesis (from: https://github.com/mysensors/ArduinoHwNRF5):
                    Mike_Lemo
                      Mike_Lemo
                      Someone managed to get NFC to work with this IC on the arduino IDE?
                        • Nca78N
                          • Nca78N Nca78
                            • TerrenceT
                              TerrenceT
                              Terrence
                              Some Nordic guidance might help.
                                #475
                                results in a loss of control by the sketch itself to something within MySensors that wants to establish communication between the node and the gateway. Not even sure how that is happening. In any case, it is just overcomplicating the debugging, and I really don't want that right now because it is effectively hanging what I'm trying to do. :angry:
                                  d00616D
                                  d00616D
                                  d00616
                                  • M Mike_Lemo
                                    From what I understand the NRF52832 has some kind of enforcer that allows different serial hardwares to be assigned to different pins
                                    d00616D
                                    d00616D
                                    d00616
                                    You have to install the "MySensors nRF5 Boards" package. In the examples section for this package, you can find two files (MyNRF5Board.h + MyNRF5Board.cpp). Add these files to your sketch and compile it using "MyNRF5Board nRF52822" as you board.
                                    The registers are documented in the Infocenter and the bitfields.
                                    To access the registers, you have to add '#include <nrf.h>' to your code. Mostly the hardware is accesses by NRF_HWNAME->REGISTER
                                    Doing PWM is a little bit complex. The code is different for nRF51 and nRF52. Look into wiring_analog_nRF51.c and (wiring_analog_nRF51.c)[https://github.com/sandeepmistry/arduino-nRF5/blob/c98a190eb34c0247eb8e0764a6367c7f9e51d2fc/cores/nRF5/wiring_analog_nRF52.c#L214]
                                    If you clone this code, for nRF52 you have to use another timer, like TIMER2, because you can't define the interrupt routine twice.
                                    • Nca78N
                                      So I'm trying to program the S4AT modules and I have the ugly message
                                      ** Programming Started **
                                      auto erase enabled
                                      Info : nRF51822-QFAA(build code: H0) 256kB Flash
                                      Error: failed erasing sectors 0 to 13
                                      I tried to use JLink programs but it says it cannot connect to the module, so I cannot unlock (ends with timeout message) and I cannot erase (fails with -1 return value)...
                                      d00616D 1 Reply Last reply
                                      • Nca78N Nca78
                                        auto erase enabled
                                        d00616D
                                        d00616D
                                        d00616
                                        Nca78N NeverDieN sebiS 3 Replies Last reply
                                        • d00616D d00616
                                          wrote on last edited by Nca78
                                          #480
                                          Thank you it works ! :heart: :heart: :heart:
                                          That's probably when trying to use this function that I managed to unlock&erase the EByte module "by mistake" :)
                                          The only problem now is the range seems to be very bad :(
                                          Less than 10m with just a brick wall and it fails to completely send the presentation messages.
                                          EBytes nrf52832 module works well in the same conditions, same for their nrf24 modules.
                                          [Edit] in fact not that bad, it works ok when changing the orientation of the module. Could be due to the funky wiring but my bet is it on the tiny antenna design. My gateway is an old through hole nrf24 clone so range should not be a problem in an appartment with a PA/LNA gateway.
