  3. nRF5 action!
nRF5 action!
  • M Mike_Lemo
    ATmega8
    ATmega168/328
    ATmega1280
    How is it possible to make it copatible with the NRF52?
    #465
    @Mike_Lemo it (the tone library) would need to be ported
      Mike_Lemo
      @Mike_Lemo it would need to be ported
      No idea what you are talking about.
      • M Mike_Lemo
          Some further evidence in support of this hypothesis (from: https://github.com/mysensors/ArduinoHwNRF5):
            Mike_Lemo
              Mike_Lemo
              Someone managed to get NFC to work with this IC on the arduino IDE?
                • Nca78N
                  • Nca78N Nca78
                    • TerrenceT
                      TerrenceT
                      Terrence
                      Some Nordic guidance might help.
                        #475
                        results in a loss of control by the sketch itself to something within MySensors that wants to establish communication between the node and the gateway. Not even sure how that is happening. In any case, it is just overcomplicating the debugging, and I really don't want that right now because it is effectively hanging what I'm trying to do. :angry:
                          d00616D
                          d00616D
                          d00616
                          • M Mike_Lemo
                            From what I understand the NRF52832 has some kind of enforcer that allows different serial hardwares to be assigned to different pins
                            d00616D
                            d00616D
                            d00616
                            You have to install the "MySensors nRF5 Boards" package. In the examples section for this package, you can find two files (MyNRF5Board.h + MyNRF5Board.cpp). Add these files to your sketch and compile it using "MyNRF5Board nRF52822" as you board.
                            The registers are documented in the Infocenter and the bitfields.
                            To access the registers, you have to add '#include <nrf.h>' to your code. Mostly the hardware is accesses by NRF_HWNAME->REGISTER
                            Doing PWM is a little bit complex. The code is different for nRF51 and nRF52. Look into wiring_analog_nRF51.c and (wiring_analog_nRF51.c)[https://github.com/sandeepmistry/arduino-nRF5/blob/c98a190eb34c0247eb8e0764a6367c7f9e51d2fc/cores/nRF5/wiring_analog_nRF52.c#L214]
                            If you clone this code, for nRF52 you have to use another timer, like TIMER2, because you can't define the interrupt routine twice.
                            • Nca78N
                              So I'm trying to program the S4AT modules and I have the ugly message
                              ** Programming Started **
                              auto erase enabled
                              Info : nRF51822-QFAA(build code: H0) 256kB Flash
                              Error: failed erasing sectors 0 to 13
                              I tried to use JLink programs but it says it cannot connect to the module, so I cannot unlock (ends with timeout message) and I cannot erase (fails with -1 return value)...
                              d00616D 1 Reply Last reply
                              • Nca78N Nca78
                                auto erase enabled
                                d00616D
                                d00616D
                                d00616
                                Nca78N NeverDieN sebiS 3 Replies Last reply
                                • d00616D d00616
                                  wrote on last edited by Nca78
                                  #480
                                  Thank you it works ! :heart: :heart: :heart:
                                  That's probably when trying to use this function that I managed to unlock&erase the EByte module "by mistake" :)
                                  The only problem now is the range seems to be very bad :(
                                  Less than 10m with just a brick wall and it fails to completely send the presentation messages.
                                  EBytes nrf52832 module works well in the same conditions, same for their nrf24 modules.
                                  [Edit] in fact not that bad, it works ok when changing the orientation of the module. Could be due to the funky wiring but my bet is it on the tiny antenna design. My gateway is an old through hole nrf24 clone so range should not be a problem in an appartment with a PA/LNA gateway.
                                  • d00616D d00616
                                    In this case I'm going to try a different Ebyte module. Maybe the one I'm using is defective or somehow became damaged.
                                    • d00616D d00616
                                      #482
                                      I'm happy to report this also worked when, just now, I programmed a new Ebyte module. Like d00616 said earlier, it's a much faster way to do a mass erase. :)
                                      Unfortunately, and in contrast with the nRF52 DK, the new Ebyte module I just programmed is behaving the same as the Ebyte I've been experimenting with. No change.
                                      • Nca78N
                                        • d00616D d00616
                                          Mike_Lemo
                                          Thanks for the caring replay.
                                          Nca78N d00616D 2 Replies Last reply
