  3. Gateway update?
Gateway update?
7 Posts 2 Posters 2.5k Views 3 Watching
  • 1kohm1
    1kohm1
    1kohm
    Here's my debug from Ethernet (Arduino Uno + shield) gateway:
    0;255;3;0;9;TSM:INIT
    0;255;3;0;9;TSM:RADIO:OK
    0;255;3;0;9;TSM:GW MODE
    0;255;3;0;9;TSM:READY
    IP: 10.0.0.104
    0;255;3;0;9;TSP:MSG:READ 21-21-0 s=1,c=1,t=0,pt=7,l=5,sg=0:26.0
    0;255;3;0;9;TSP:MSG:READ 21-21-0 s=1,c=1,t=0,pt=7,l=5,sg=0:25.9
    0;255;3;0;9;TSP:MSG:READ 8-8-0 s=0,c=1,t=37,pt=7,l=5,sg=0:50.87
    0;255;3;0;9;TSP:MSG:READ 8-8-0 s=2,c=1,t=0,pt=7,l=5,sg=0:22.0
    0;255;3;0;9;TSP:MSG:READ 8-8-0 s=0,c=1,t=37,pt=7,l=5,sg=0:61.50
    0;255;3;0;9;TSP:MSG:READ 8-8-0 s=2,c=1,t=0,pt=7,l=5,sg=0:21.9
    0;255;3;0;9;TSP:MSG:READ 8-8-0 s=1,c=1,t=1,pt=7,l=5,sg=0:40.7
    0;255;3;0;9;TSP:MSG:READ 8-8-0 s=0,c=1,t=37,pt=7,l=5,sg=0:51.34
    0;255;3;0;9;TSP:MSG:READ 3-3-0 s=13,c=1,t=0,pt=7,l=5,sg=0:27.7
    0;255;3;0;9;TSP:MSG:READ 8-8-0 s=0,c=1,t=37,pt=7,l=5,sg=0:37.04
    My nodes are sending data.
    Want to add new node and here's the problem:
    0 MCO:BGN:INIT NODE,CP=RNNNA--,VER=2.1.0
    3 TSM:INIT
    6 TSF:WUR:MS=0
    13 !TSM:INIT:TSP FAIL
    15 TSM:FAIL:CNT=1
    16 TSM:FAIL:PDT
    10019 TSM:FAIL:RE-INIT
    10021 TSM:INIT
    10028 !TSM:INIT:TSP FAIL
    10031 TSM:FAIL:CNT=2
    10032 TSM:FAIL:PDT
    20035 TSM:FAIL:RE-INIT
    20037 TSM:INIT
    20043 !TSM:INIT:TSP FAIL
    It seems that I have newer version on node (2.1.0) than gateway (2.0.0).
    How to fix that?
    Should I update gateway - how?
    If yes, should I update also all remaning nodes - how?
    • 1kohm1 1kohm
      IP: 10.0.0.104
      3 TSM:INIT
      6 TSF:WUR:MS=0
      15 TSM:FAIL:CNT=1
      16 TSM:FAIL:PDT
      10021 TSM:INIT
      10032 TSM:FAIL:PDT
      20037 TSM:INIT
      How to fix that?
      @1kohm to update the nodes, re-upload the original sketch to the nodes.
      Mixing nodes within the same major version (2.x can coexist) should be OK , so you don't need to update everything.
      TSM:INIT:TSP FAIL means that the Arduino is unable to communicate with its radio. Double-check the wiring and if the wiring is correct, try another radio module to determine if the current module is broken.
      • 1kohm1
        1kohm1
        1kohm
        radio was the issue (placed oposite.., by bad)
        Now, I've uploaded node ver.2.0.0.
        TSM:INIT
        TSM:RADIO:OK
        TSP:ASSIGNID:OK (ID=4)
        TSM:FPAR
        TSP:MSG:SEND 4-4-255-255 s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=bc:
        TSP:MSG:READ 0-0-4 s=255,c=3,t=8,pt=1,l=1,sg=0:0
        TSP:MSG:PAR OK (ID=0, dist=1)
        TSM:FPAR:OK
        TSM:ID
        TSM:CHKID:OK (ID=4)
        TSM:UPL
        TSP:PING:SEND (dest=0)
        TSP:MSG:SEND 4-4-0-0 s=255,c=3,t=24,pt=1,l=1,sg=0,ft=0,st=ok:1
        TSP:MSG:READ 0-0-4 s=255,c=3,t=25,pt=1,l=1,sg=0:1
        TSP:MSG:PONG RECV (hops=1)
        TSP:CHKUPL:OK
        TSM:UPL:OK
        TSM:READY
        TSP:MSG:SEND 4-4-0-0 s=255,c=3,t=15,pt=6,l=2,sg=0,ft=0,st=ok:0100
        TSP:MSG:SEND 4-4-0-0 s=255,c=0,t=17,pt=0,l=5,sg=0,ft=0,st=ok:2.0.0
        TSP:MSG:SEND 4-4-0-0 s=255,c=3,t=6,pt=1,l=1,sg=0,ft=0,st=ok:0
        TSP:MSG:READ 0-0-4 s=255,c=3,t=15,pt=6,l=2,sg=0:0100
        TSP:MSG:READ 0-0-4 s=255,c=3,t=6,pt=0,l=1,sg=0:M
        TSP:MSG:SEND 4-4-0-0 s=255,c=3,t=11,pt=0,l=25,sg=0,ft=0,st=ok:Double Relay & Button tes
        TSP:MSG:SEND 4-4-0-0 s=255,c=3,t=12,pt=0,l=3,sg=0,ft=0,st=ok:0.3
        TSP:MSG:SEND 4-4-0-0 s=8,c=0,t=3,pt=0,l=0,sg=0,ft=0,st=ok:
        TSP:MSG:SEND 4-4-0-0 s=9,c=0,t=3,pt=0,l=0,sg=0,ft=0,st=ok:
        Request registration...
        TSP:MSG:SEND 4-4-0-0 s=255,c=3,t=26,pt=1,l=1,sg=0,ft=0,st=ok:2
        TSP:MSG:READ 0-0-4 s=255,c=3,t=27,pt=1,l=1,sg=0:1
        Node registration=1
        Init complete, id=4, parent=0, distance=1, registration=1
        Debug looks perfect..., but cannot see the node in Domoticz i Devices tab :(
        I can see the node under Hardware -> MySensorsGateway only:
        I want to test gas meter IN-Z61.
        • 1kohm1 1kohm
          TSM:INIT
          TSM:RADIO:OK
          TSM:FPAR
          TSM:FPAR:OK
          TSM:ID
          TSM:CHKID:OK (ID=4)
          TSM:UPL
          TSP:CHKUPL:OK
          TSM:UPL:OK
          TSM:READY
          Node registration=1
          @1kohm great work.
          For some reason, Domoticz does not show the sensor in the devices list until the sensor has sent its first value. (presentation is not enough, a message needs to be sent). Could that be the case for you?
          • 1kohm1
            1kohm1
            1kohm
            so my node is sending data every 3 seconds
            TSP:MSG:SEND 7-7-0-0 s=1,c=1,t=24,pt=5,l=4,sg=0,ft=0,st=ok:2
            volume:0.002
            TSP:MSG:SEND 7-7-0-0 s=1,c=1,t=35,pt=7,l=5,sg=0,ft=0,st=ok:0.002
            Domoticz see the updated vaule, but not in Devices :(
            • 1kohm1
              1kohm1
              1kohm
              Want to present the device as S_GAS
                  sendSketchInfo("Gas Meter", "1.1");
                  // Register this device as Waterflow sensor
                  present(CHILD_ID, S_GAS);
              Sketch I use:
               * Version 1.0 - Henrik Ekblad
               * Version 1.1 - GizMoCuz
               * Use this sensor to measure volume and flow of your house watermeter.
               * You need to set the correct pulsefactor of your meter (pulses per m3).
               * The sensor starts by fetching current volume reading from gateway (VAR 1).
               * Reports both volume and flow back to gateway.
               * Unfortunately millis() won't increment when the Arduino is in
               * sleepmode. So we cannot make this sensor sleep if we also want
               * to calculate/report flow.
               * http://www.mysensors.org/build/pulse_water
              //#define MY_RADIO_NRF5_ESB
              //#define MY_RADIO_RFM95
              #define DIGITAL_INPUT_SENSOR 7                  // The digital input you attached your sensor.  (Only 2 and 3 generates interrupt!)
              #define PULSE_FACTOR 1000                       // Nummber of blinks per m3 of your meter (One rotation/liter)
              #define SLEEP_MODE false                        // flowvalue can only be reported when sleep mode is false.
              #define MAX_FLOW 40                             // Max flow (l/min) value to report. This filters outliers.
              #define CHILD_ID 1                              // Id of the sensor child
              unsigned long SEND_FREQUENCY =
                  3000;           // Minimum time between send (in milliseconds). We don't want to spam the gateway.
              MyMessage flowMsg(CHILD_ID,V_FLOW);
              MyMessage volumeMsg(CHILD_ID,V_VOLUME);
              MyMessage lastCounterMsg(CHILD_ID,V_VAR1);
              double ppl = ((double)PULSE_FACTOR)/1000;        // Pulses per liter
              volatile double flow = 0;
              bool pcReceived = false;
              unsigned long oldPulseCount = 0;
              unsigned long newBlink = 0;
              double oldflow = 0;
              double volume =0;
              double oldvolume =0;
              unsigned long lastSend =0;
              unsigned long lastPulse =0;
                  // initialize our digital pins internal pullup resistor so one pulse switches from high to low (less distortion)
                  pinMode(DIGITAL_INPUT_SENSOR, INPUT_PULLUP);
                  pulseCount = oldPulseCount = 0;
                  request(CHILD_ID, V_VAR1);
                  lastSend = lastPulse = millis();
                  attachInterrupt(digitalPinToInterrupt(DIGITAL_INPUT_SENSOR), onPulse, FALLING);
                  unsigned long currentTime = millis();
                  if (SLEEP_MODE || (currentTime - lastSend > SEND_FREQUENCY)) {
                      lastSend=currentTime;
                      if (!pcReceived) {
                          //Last Pulsecount not yet received from controller, request it again
                          return;
                      if (!SLEEP_MODE && flow != oldflow) {
                          oldflow = flow;
                          Serial.print("l/min:");
                          Serial.println(flow);
                          // Check that we dont get unresonable large flow value.
                          if (flow<((unsigned long)MAX_FLOW)) {
                              send(flowMsg.set(flow, 2));                   // Send flow value to gw
                      // No Pulse count received in 2min
                      if(currentTime - lastPulse > 120000) {
                          flow = 0;
                      // Pulse count has changed
                      if ((pulseCount != oldPulseCount)||(!SLEEP_MODE)) {
                          oldPulseCount = pulseCount;
                          Serial.print("pulsecount:");
                          Serial.println(pulseCount);
                          send(lastCounterMsg.set(pulseCount));                  // Send  pulsecount value to gw in VAR1
                          double volume = ((double)pulseCount/((double)PULSE_FACTOR));
                          if ((volume != oldvolume)||(!SLEEP_MODE)) {
                              oldvolume = volume;
                              Serial.print("volume:");
                              Serial.println(volume, 3);
                              send(volumeMsg.set(volume, 3));               // Send volume value to gw
                  if (SLEEP_MODE) {
                      sleep(SEND_FREQUENCY);
                  if (message.type==V_VAR1) {
                      unsigned long gwPulseCount=message.getULong();
                      pulseCount += gwPulseCount;
                      flow=oldflow=0;
                      Serial.print("Received last pulse count from gw:");
                      pcReceived = true;
              void onPulse()
                  if (!SLEEP_MODE) {
                      unsigned long interval = newBlink-lastBlink;
                      if (interval!=0) {
                          if (interval<500000L) {
                              // Sometimes we get interrupt on RISING,  500000 = 0.5sek debounce ( max 120 l/min)
                              return;
                          flow = (60000000.0 /interval) / ppl;
                      lastBlink = newBlink;
                  pulseCount++;
              • 1kohm1
                1kohm1
                1kohm
                topic to close.
                I've neede to allow new hardware to add in Domoticz.
