  3. Unable to get started
7 Posts 5 Posters 2.5k Views 1 Watching
    Marcus Schmidke
    Hello all.
    I cannot wait to get started and since I already own some arduinos and some radio modules, I tried to get the "door sensor" example running. But unfortunately it doesn't work at all.
    I've searched the forum, but even more unfortunately, all matching threads I found end before there was a solution ...
    This is what I did:
    • I connected two Arduinos and two radios and triple checked the wires
    • I uploaded the "serial gateway" example to one of them, the "door sensor" example to the other
    • I started both and looked at the serial monitors
    On the sensor node I have the following output:
    Sensor Node:
    req node id
    send: 255-255-0-0 s=255,c=3,t=3,pt=0,l=0,st=fail:
    sensor started, id 255
    req node id
    req node id
    req node id
    send: 255-255-0-0 s=255,c=3,t=3,pt=0,l=0,st=ok:
    req node id
    req node id
    req node id
    req node id
    req node id
    Note there is one "st=ok" and lots of "st=fail".
    I've read about "assigning id not working without controller" and so on so I do not wonder why assigning an ID does not work. I will do further investigations in that direction (assigning a static id and so on).
    But my question is: why are there such a lot of failed transmissions and only a few are working?
    I will order some capacitors and try again, but since I've powered the Arduinos by a battery driven notebook I did not expect that much noise on the power line, or am I wrong?
    Marcus.
    • D
      dzairo
      ehm.. on first set node ID manually ..
      sensor_node.begin(NULL,25);
      with this set node ID manually to 25 ..
      try it ..
      regards.
        Adding capacitors will do wonders to your failed ack:s.
        • D
          dzairo
          ... ehm .. I also have this idea .. but can't find example photo from this forum..
          • K
            K
            kalle
            http://www.mysensors.org/build/connect_radio#connecting-a-decoupling-capacitor
            • raditvR
              raditvR
              raditv
              I think node ID is given by controller on serial gateway.
                Marcus Schmidke
                Oha, you are right.
                The capacitor was the solution. I never thought that a battery-powered notebook could be a bad power source. Sorry for asking before having tried it ...
                Thank you!!
                Marcus.
