  3. 💬 Button size radionode with sensors swarm extension
atsha204aflashhumidityrf69lightuv lightbatterymysensortemperatureota
189 Posts 28 Posters 76.6k Views 25 Watching
  • A Abdu Sahin
    @yury
    I like to try both 865 HW/W versions. I need sensors with long battery life and good RF distance coverage for my project. I've noticed some people suggested using only 'W' version for battery powered nodes, but from my initial experience I didn't have good distance with 'W' version.
    Y
    Y
    yury
    @Abdu-Sahin said in 💬 Button size radionode with sensors swarm extension:
    )) either good battery life or good coverage though... or good coverage and 2-3 AA batteries. CW is 20 mA when sending signal and HCW is about 100 mA. CR2032 battery will be drained by HCW pretty fast.
    HW/W versions have bigger footprints (Module Size:19.7X16mm) and not compatible with the "Button size".
    HCW/CW (Module Size:16X16mm) are equivalents for HW/W.
    A 1 Reply Last reply
    • Y yury
      Abdu Sahin
      @yury
      I think I can start with CW version as start. Battery life is important for me.
      Y 1 Reply Last reply
      • A Abdu Sahin
        @yury
        Y
        Y
        yury
        sent you a message in the chat...
        • Y yury
          Abdu Sahin
          wrote on last edited by Abdu Sahin
          #90
          @yury
          You can email me if you like.
          My email is uk.asahin at gmail com
          TerrenceT 1 Reply Last reply
          • A Abdu Sahin
            @yury
            TerrenceT
            TerrenceT
            Terrence
            @Abdu-Sahin I was interested in reading your conversation about battery life etc. I hope you will continue the conversation on the forum instead of in private.
            • Miroslav KadanÄ›M
              Miroslav KadaněM
              Miroslav KadanÄ›
              It is possible to buy only PCB ? Upload PCB to OSH Park, or send PCB in eagle. I do not have Altium Designer... Thx
              KoreshK 1 Reply Last reply
              • Miroslav KadanÄ›M Miroslav KadanÄ›
                KoreshK
                KoreshK
                Koresh
                @Miroslav-KadanÄ› I've just uploaded latest gerbers (rfm reset pin was connected to controller, connection of si1132 was fixed, reverse battery polarity protection was added). You can place PCB order at any factory. :wink:
                • C
                  C
                  chbla
                  Maybe a stupid question but how do you connect the FTDI adapter? I only know the ISP pins
                  C 1 Reply Last reply
                  • getlargeG
                    getlargeG
                    getlarge
                    @yury @koresh
                    Few months ago, I've ordered some of your nodes, which work perfectly by the way, but I needed something that could speed up testing of any sensors.
                    So following our conversation on Github with Yury, I've created a PCB based on your Button size node, with a field for an extension board. The aim is to have a versatile board, and extensions that could handle virtually any sensors, like NodeManager project, but for hardware ;)
                    And it's also a first time experiment in the land of PCBs
                    Apart 2 errors ( maybe more in the future !), it seems to be well routed, as tests been proving, but i still not tried the FOTA function.
                    Errors was a badly routed button and it seems that, after the RFM chip is soldered, communication with USBasp gets bad! Is it because SCK and MISO route ( from pin headers to atmega328 ) goes through the RFM chip before atmega ?
                    You were mentioning some mods in dualoptiboot in order to flash M25P40, https://forum.mysensors.org/topic/3160/ota-flash-types-for-mysensors/43.
                    Would it be possible to share these ?
                    And just out of curiosity, how did you manage to solder SI7021 and TSL2561 ?
                    By now, it seems like a mystery for me...
                    • getlargeG getlarge
                      @yury @koresh
                      KoreshK
                      KoreshK
                      Koresh
                      wrote on last edited by Koresh
                      #96
                      @getlarge said in 💬 Button size radionode with sensors swarm extension:
                      Did you solder R4 (from your schematic https://github.com/getlarge/Cosmonode/blob/master/Cosmonode_sch.pdf)? I can't find it on the boards photo.
                      PS
                      Will share compiled bootloader and sources soon.
                      • getlargeG
                        getlargeG
                        getlarge
                        @Koresh said in 💬 Button size radionode with sensors swarm extension:
                        Sorry, picture's quality is not too good!
                        R4 ( 10Kohm) is soldered. I read about that pullup resistor that is needed to sync with atmega SCK. Any other hint on what could cause that ?
                        Maybe, that was a mistake when i changed the fuse? but I didn't have problem before with these settings.
                        So I'll have to be patient to use M25P40!
                        • C chbla
                          C
                          C
                          chbla
                          @chbla said in 💬 Button size radionode with sensors swarm extension:
                          Can anyone quickly tell me how to do it correctly? I thought it didn't work but I'm unsure.
                          • C chbla
                            KoreshK
                            KoreshK
                            Koresh
                            @chbla This board has standard FTDI header (see attached screenshot).
                            But it also has all of ISP pins (mosi, miso, sck, rst)
                            • H
                              H
                              hiddenuser
                              wrote on last edited by hiddenuser
                              #100
                              @Koresh Might be a dumb question I am planning to work on this board, where do I find the complete part list.
                              • H
                                H
                                hiddenuser
                                Does any one have links to dirty pcb or OSH Park? Thanks a lot
                                Miroslav KadaněM 1 Reply Last reply
                                  ^^^warning: it's an infiltration bot.
                                  H 1 Reply Last reply
                                  • H hiddenuser
                                    Miroslav KadaněM
                                    Miroslav KadaněM
                                    Miroslav KadanÄ›
                                      H
                                      H
                                      hiddenuser
                                      @NeverDie Not sure if you are referring to me?
                                        [[topic:post-is-deleted]]
                                        H
                                        H
                                        hiddenuser
                                        @Miroslav-KadanÄ› Thanks!!
                                        • H
                                          H
                                          hiddenuser
                                          I do not have an electronics background. I wend through the pdf files and order the parts and looks like I got the wrong resistor and capacitor or wrong part. Looks like I have to wait for an expert to comment let me know which resistor/capacitor goes where what part size. I would love to hear from someone ;)
                                          12.5k
