  3. 💬 Button size radionode with sensors swarm extension
atsha204aflashhumidityrf69lightuv lightbatterymysensortemperatureota
189 Posts 28 Posters 76.6k Views 25 Watching
  • Y yury
    @Abdu-Sahin said in 💬 Button size radionode with sensors swarm extension:
    Battery life is important
    sent you a message in the chat...
    Abdu Sahin
    wrote on last edited by Abdu Sahin
    #90
    @yury
    You can email me if you like.
    My email is uk.asahin at gmail com
    TerrenceT 1 Reply Last reply
    • A Abdu Sahin
      @yury
      TerrenceT
      TerrenceT
      Terrence
      @Abdu-Sahin I was interested in reading your conversation about battery life etc. I hope you will continue the conversation on the forum instead of in private.
      • Miroslav KadanÄ›M
        Miroslav KadaněM
        Miroslav KadanÄ›
        It is possible to buy only PCB ? Upload PCB to OSH Park, or send PCB in eagle. I do not have Altium Designer... Thx
        KoreshK 1 Reply Last reply
        • Miroslav KadanÄ›M Miroslav KadanÄ›
          KoreshK
          KoreshK
          Koresh
          @Miroslav-KadanÄ› I've just uploaded latest gerbers (rfm reset pin was connected to controller, connection of si1132 was fixed, reverse battery polarity protection was added). You can place PCB order at any factory. :wink:
          • C
            C
            chbla
            Maybe a stupid question but how do you connect the FTDI adapter? I only know the ISP pins
            C 1 Reply Last reply
            • getlargeG
              getlargeG
              getlarge
              @yury @koresh
              Few months ago, I've ordered some of your nodes, which work perfectly by the way, but I needed something that could speed up testing of any sensors.
              So following our conversation on Github with Yury, I've created a PCB based on your Button size node, with a field for an extension board. The aim is to have a versatile board, and extensions that could handle virtually any sensors, like NodeManager project, but for hardware ;)
              And it's also a first time experiment in the land of PCBs
              Apart 2 errors ( maybe more in the future !), it seems to be well routed, as tests been proving, but i still not tried the FOTA function.
              Errors was a badly routed button and it seems that, after the RFM chip is soldered, communication with USBasp gets bad! Is it because SCK and MISO route ( from pin headers to atmega328 ) goes through the RFM chip before atmega ?
              You were mentioning some mods in dualoptiboot in order to flash M25P40, https://forum.mysensors.org/topic/3160/ota-flash-types-for-mysensors/43.
              Would it be possible to share these ?
              And just out of curiosity, how did you manage to solder SI7021 and TSL2561 ?
              By now, it seems like a mystery for me...
              • getlargeG getlarge
                @yury @koresh
                KoreshK
                KoreshK
                Koresh
                wrote on last edited by Koresh
                #96
                @getlarge said in 💬 Button size radionode with sensors swarm extension:
                Did you solder R4 (from your schematic https://github.com/getlarge/Cosmonode/blob/master/Cosmonode_sch.pdf)? I can't find it on the boards photo.
                PS
                Will share compiled bootloader and sources soon.
                • getlargeG
                  getlargeG
                  getlarge
                  @Koresh said in 💬 Button size radionode with sensors swarm extension:
                  Sorry, picture's quality is not too good!
                  R4 ( 10Kohm) is soldered. I read about that pullup resistor that is needed to sync with atmega SCK. Any other hint on what could cause that ?
                  Maybe, that was a mistake when i changed the fuse? but I didn't have problem before with these settings.
                  So I'll have to be patient to use M25P40!
                  • C chbla
                    C
                    C
                    chbla
                    @chbla said in 💬 Button size radionode with sensors swarm extension:
                    Can anyone quickly tell me how to do it correctly? I thought it didn't work but I'm unsure.
                    • C chbla
                      KoreshK
                      KoreshK
                      Koresh
                      @chbla This board has standard FTDI header (see attached screenshot).
                      But it also has all of ISP pins (mosi, miso, sck, rst)
                      • H
                        H
                        hiddenuser
                        wrote on last edited by hiddenuser
                        #100
                        @Koresh Might be a dumb question I am planning to work on this board, where do I find the complete part list.
                        • H
                          H
                          hiddenuser
                          Does any one have links to dirty pcb or OSH Park? Thanks a lot
                          Miroslav KadaněM 1 Reply Last reply
                            ^^^warning: it's an infiltration bot.
                            H 1 Reply Last reply
                            • H hiddenuser
                              Miroslav KadaněM
                              Miroslav KadaněM
                              Miroslav KadanÄ›
                                H
                                H
                                hiddenuser
                                @NeverDie Not sure if you are referring to me?
                                  [[topic:post-is-deleted]]
                                  H
                                  H
                                  hiddenuser
                                  @Miroslav-KadanÄ› Thanks!!
                                  • H
                                    H
                                    hiddenuser
                                    I do not have an electronics background. I wend through the pdf files and order the parts and looks like I got the wrong resistor and capacitor or wrong part. Looks like I have to wait for an expert to comment let me know which resistor/capacitor goes where what part size. I would love to hear from someone ;)
                                    • KoreshK Koresh
                                      @Cliff-Karlsson The local factory starts assembly today (button size node, insertable switch node, wall socket insertable node and mini relay box). ETA is one-two week (max).
                                      This board is avaliable with two radios - rfm69hw and rfm69cw (with adapter shown below). Price will be the same. Which radio is preferred for you? If you plan to use this board with battery I suggest to use rfm69cw module to extend battery life (it has lower but enouogh power and works down to ~2V).
                                      Miroslav KadaněM
                                      Miroslav KadaněM
                                      Miroslav KadanÄ›
                                      wrote on last edited by Miroslav KadanÄ›
                                      #107
                                      @koresh it is possible to buy this adapter (RFM69HCW -> RFM69CW) or download pcb files ?
                                      Thx
                                        Thx
                                        @miroslav-kadaně said in 💬 Button size radionode with sensors swarm extension:
                                        @koresh it is possible to buy this adapter or download pcb files ?
                                        Thx
                                        Go to this link and press the download button: https://www.openhardware.io/view/299/Button-size-radionode-with-sensors-swarm-extension
                                          Thx
                                          Miroslav KadaněM
                                          Miroslav KadaněM
                                          Miroslav KadanÄ›
                                          #109
                                          @neverdie thx, but i need adapter from RFM69HCW to RFM69CW
                                          12.5k
