1.1k Posts 105 Posters 836.5k Views 98 Watching
  • sundberg84S
    sundberg84S
    Today I made a pogo pin programming board for my Logger. (The logger works except one last thing... Rev 5 here we come!)
    • nagelcN
      nagelcN
      nagelc
      I've been playing with an Adafruit AudioFX board and cobbled together this annunciator. Eventually it will be a MySensors node to play alarms or other sounds. It is using a cheap portable speaker to play the sounds. I got it to work with my doorbell button node today.
      annunciator test
      • sundberg84S
        sundberg84S
        Last fix done on my Logger... I will send it to pcb house today and probably publish a beta on openhardware. Probably nothing special but for me as hobby pcb maker this has been a challenge and great knowledge increase in using oscilloscope and new components.
        Tomorrow Black Friday!! (I work in retail so that's a high focus now...)
          #96
          Yesterday received the PCB. Today assembled for testing this battery-powered nRF52-based passive infrared motion detector:
          YveauxY I 2 Replies Last reply
            #97
            Battery powered MySensors Washing machine & dryer monitor, using LDR's to monitor LEDs on front of the appliances.
            Each time a LED toggles, the node wakes from interrupt and sends a message. Easy peasy!
            When a device is ready, I'll get a message on my mobile phone :smile:
            0_1511607742913_upload-656fdf4c-6707-4a8b-a58c-ef7e74fe1b9f
            0_1511607798459_upload-0183f0a1-571d-45e6-8ecc-b4a33fd9c4e9
            Still need to stuff it in an enclosure...
            gohanG bjacobseB dbemowskD 3 Replies Last reply
            • YveauxY Yveaux
              @Yveaux said in What did you build today (Pictures) ?:
              Yes, definitely very low WAF 😁
                sundberg84S
                sundberg84S
                #99
                @gohan - you mean HIGH waf? :) I really like the design... (if the first picture is only what you see)
                • sundberg84S sundberg84
                  Ofcourse! WAF is overrated anyhow...
                  • YveauxY Yveaux
                    sundberg84S
                    sundberg84S
                    @Yveaux - Yes, as long as you don't tell her ;)
                    N 1 Reply Last reply
                    • YveauxY Yveaux
                      bjacobseB
                      bjacobseB
                      bjacobse
                      #102
                      @Yveaux
                      I think I have similar washing machine, doesn't the LED blink if leave the laundry inside the machine after it had ended washing?
                      Just curious, if you anyway have had the lid/cover removed from washing machine, why not solder wires parallel to LED and connect to an optocoupler that feeds signal direct to Arduino, and also take 5V supply from the washing machine, and then you can avoid using batteries
                      Nca78N YveauxY 2 Replies Last reply
                      • bjacobseB bjacobse
                        @Yveaux
                        @bjacobse it's pretty different to remove the top that's usually easily removable to put inside furniture, and to unmount front panel and then solder stuff on the PCB. High WAF probably includes ensuring the warranty is not void :D
                          @Yveaux
                          @bjacobse said in What did you build today (Pictures) ?:
                          @Yveaux
                          The sensor is placed on a led that lights when the machine is finished. I would prefer a led that is lit when it is washing and goes out when finished, but my machine hasn't any.
                          Now I simply removed the cover to hide the wire. The electronics and led are hidden behind a lot of metal aan plastic. I didn't want to take the washer apart and the dryer too.
                          Just a simple solution working for multiple devices.
                          bjacobseB 1 Reply Last reply
                          • YveauxY Yveaux
                            @Yveaux
                            bjacobseB
                            bjacobseB
                            bjacobse
                            @Yveaux
                            Ah this make good sense, I didn't think the electronics was hidden and difficult to get to
                              @Yveaux
                              It's German quality :smirk:
                              • bjacobseB
                                bjacobseB
                                bjacobse
                                Finally got my LoRaWAN RAk831 with RPI gateway online
                                • YveauxY Yveaux
                                  dbemowskD
                                  dbemowskD
                                  @Yveaux So I never fully understood the reasoning behind putting sensors on a washer or dryer. So you start your clothes washing or drying before you leave for somewhere. Is there a reason to know that it's finished when you are away? There is nothing you can do about it until you get home, at which time you could reasonably assume that it is finished. If you are home, can't you just go and check it after some time? Why would you need a message on your phone?
                                  Just curious.
                                  YveauxY Nca78N bjacobseB 3 Replies Last reply
                                  • dbemowskD dbemowsk
                                    Just curious.
                                    @dbemowsk just to keep the machines running continuously ;-)
                                    And I need to go up 3 stairs to just check on them :hankey:
                                    dbemowskD 1 Reply Last reply
                                    • YveauxY Yveaux
                                      dbemowskD
                                      dbemowskD
                                      @Yveaux Makes some sense. Another reason would probably be....."Because you can"... LOL
                                        Just curious.
                                        @dbemowsk said in What did you build today (Pictures) ?:
                                        Just curious.
                                        Or if someone else than you starts the machine before leaving for the full day, and you come back much earlier and if you don't have a warning you don't necessarily think about checking the washing machine when you arrive home. Here with the warm temperature if I leave the laundry in the washing machine for 4-5 hours without opening, I'm good for a new wash because it will smell pretty bad :(
                                          Just curious.
                                          bjacobseB
                                          bjacobseB
                                          bjacobse
                                          @dbemowsk
                                          My wife actually fairly often forget to check when the washingmachine is finished, and notice it a few hours later, when kids are a sleep and there is quiet in the house, I will imagine receiving an SMS when washing machine is ready to be emptied will help her, as she is checking her phone often,, even when kids are using all her time
                                          12.5k
