716 Posts 111 Posters 703.1k Views 93 Watching
  • sundberg84S sundberg84
    @keldandorin - could be a weak clone radio yes.
    Just to get your hopes up, I got booster driven nodes all around the place with Nrf24l01+ radio and they works great!
    I change battery every 1-1.5 years but as I said, the experience is that the radio - booster needs a good teamwork :)
    keldandorinK
    keldandorinK
    keldandorin
    wrote on last edited by keldandorin
    #431
    @sundberg84 Sounds good, Thats what I'm looking for. Have never worked with tinkers like this befor so everything is new. But this place is great thx for taking time.
    • pellusfromtellusP
      pellusfromtellusP
      pellusfromtellus
      Sorry, I'm a bit slow and maybe a little off-topic: A quicky:
      Can I read somewhere how payment is done when ordering from openhardware.io? On the start page for openhardware.io there is no clue. I've also tried to search this section (easy-newbie-pcb-for-mysensors) for "payment".
      Yes, I've read that the "order" is more like a forward of orderinformation to the supplier, but do I really need to order first and after that ask what payment solution is present?
      A complete rookie! Love this stuff! My path: Domoticz/Zwave and now a big MySensors-fan! :)
      • pellusfromtellusP pellusfromtellus
        sundberg84S
        sundberg84S
        @pellusfromtellus - to get a 100% right answer we ping @hek but I recommend paypal!
          @pellusfromtellus
          I think most of them handle paypal/card. You can press the "Order" button to find out. Nothing is binding until payment has been done.
          • Paul RobertsonP
            Paul RobertsonP
            Paul Robertson
            Is there a drilling and outline file available?
            • Paul RobertsonP Paul Robertson
              sundberg84S
              sundberg84S
              @Paul-Robertson - hi!
              Yes, but this is Eagles output gerber files.
              Drill: SundbergMys9.TXT
              Outline can be found in all other files:
              https://www.pcbway.com/project/share/How_to_generate_Gerber_from_Eagle.html
              0_1505990995661_upload-c5e3c1d3-3dfb-46dc-9e10-e2d5dbfaca0d
              • sinczeS
                sinczeS
                sincze
                MySensors Evangelist
                Damn. Just missing the 0,1uF capacitor ..... to complete the 5v build. This will be my smallest build yet ;-) using PCB v9
                dbemowskD 1 Reply Last reply
                • sinczeS sincze
                  dbemowskD
                  dbemowskD
                  • H
                    H
                    hiddenuser
                    IS it possible to use TP4056 (https://www.aliexpress.com/item/5-pcs-Micro-USB-5V-1A-18650-TP4056-Lithium-Battery-Charger-Module-Charging-Board-With-Protection/32728720869.html?spm=a2g0s.9042311.0.0.A0lkC7) this instead of using the step up booster?
                    Thanks!!
                      If you want to use a lipo battery, you need a voltage regulator
                      • H hiddenuser
                        Thanks!!
                        sundberg84S
                        sundberg84S
                        @hiddenuser - well not out of the box as mentioned by gohan. Im not really sure what you want to do. Its not possible to use this instead of step-up booster since it outputs 5v and the step-up needs to output 3.3v. But with a voltage regulator in between maybe? As I said - don really understand so maybe you can explain some more about your project?
                        gohanG 1 Reply Last reply
                          @sundberg84 that tp4056 outputs just the lipo battery voltage
                          • H
                            H
                            hiddenuser
                            Thanks @sundberg84 and @gohan
                            I have used made the board for 3.3v set up as per the instruction. I have usd the output from tp4056 into the Battery connector of the board I have a step board from https://www.aliexpress.com/item/New-Electric-Unit-1-PC-NEW-DC-0-8-3-3V-to-DC-3-3V-StepUP/32724361266.html According to the specification given in the same link it is supposed to stabilize to 3.3v above 3v but the sensor reports something else back to the gateway.
                            sundberg84S gohanG 2 Replies Last reply
                            • H hiddenuser
                              sundberg84S
                              sundberg84S
                              @hiddenuser - well, what would a battery measurer be if it reported a constant 3.3v boosted voltage? ;)
                              It all depends on how everything is connected (pictures?) but if you have connected it as battery instryctions the radio and voltage divider that measured the incoming battery are not a part of the booster circuit. This to prevent noice to the radio and to be able to actually measure the battery voltage and not step-up voltage which is the idea behind the board.
                              • H hiddenuser
                                @hiddenuser I'm missing how can you use a booster to get 3.3v from a lipo battery
                                H 1 Reply Last reply
                                • D
                                  dakipro
                                  hey, has anyone maybe made a fritzing drawing/component of the board?
                                  I know, I'm lazy as f but.. since the board is that easy, documenting with it could be easy as well :)
                                  • markjgabbM
                                    markjgabbM
                                    markjgabb
                                    @sundberg84 interesting question...or maybe stupid question not sure...
                                    i have a tonn of 3v pro mini's but im thinking of mains powering some for motion sensors.... would i set it up as battery, and then just use a voltage regulator on where the step up usually would be? or is there a better way to handle it?
                                      there is a voltage regulator footprint on the pcb made for that
                                      • markjgabbM
                                        markjgabbM
                                        markjgabb
                                        ahhh thats cool... so use regulated instead and it will pull down the voltage for antenna over that side
                                        ...and the board can handle the voltage anyway so it should be fine....
                                          dbemowskD
                                          dbemowskD
                                          @gohan The only voltage regulator that I know of on the board is mainly for the radio. Unless you are talking the one on the pro mini.
                                          @markjgabb If you want to do them from mains power, you might wan t to look at the HLK modules like these
                                          https://www.ebay.com/itm/1Pcs-Power-Supply-Step-Down-Buck-Isolated-Hlk-Pm03-220V-To-3-3V-Module-New-Ic-N/332047987473?epid=571729397&hash=item4d4f9a3311:g:nyMAAOSw4GVYPa8q
                                          Otherwise an old phone charger should work.
