716 Posts 111 Posters 719.0k Views 93 Watching
  • keldandorinK keldandorin
    @sundberg84 Is there any way to say if booster is a bad one or not before ordering them?
    The one I ordered was the one on shoping list from aliexpress. Will try I capacitator and see if I can get a new booster from kjell&Comany tomorrow just to try. Build a setup on bread bord where I powered radio with 2 AA and got the same result. Got a fju places where I like to put some sensors with no power so realy need to get this working :). Could the radiomodules be bad to?
    sundberg84S
    sundberg84S
    @keldandorin - could be a weak clone radio yes.
    Just to get your hopes up, I got booster driven nodes all around the place with Nrf24l01+ radio and they works great!
    I change battery every 1-1.5 years but as I said, the experience is that the radio - booster needs a good teamwork :)
    keldandorinK 1 Reply Last reply
    • sundberg84S sundberg84
      keldandorinK
      keldandorinK
      keldandorin
      wrote on last edited by keldandorin
      #431
      @sundberg84 Sounds good, Thats what I'm looking for. Have never worked with tinkers like this befor so everything is new. But this place is great thx for taking time.
      • pellusfromtellusP
        pellusfromtellusP
        pellusfromtellus
        Sorry, I'm a bit slow and maybe a little off-topic: A quicky:
        Can I read somewhere how payment is done when ordering from openhardware.io? On the start page for openhardware.io there is no clue. I've also tried to search this section (easy-newbie-pcb-for-mysensors) for "payment".
        Yes, I've read that the "order" is more like a forward of orderinformation to the supplier, but do I really need to order first and after that ask what payment solution is present?
        A complete rookie! Love this stuff! My path: Domoticz/Zwave and now a big MySensors-fan! :)
        • pellusfromtellusP pellusfromtellus
          sundberg84S
          sundberg84S
          @pellusfromtellus - to get a 100% right answer we ping @hek but I recommend paypal!
            @pellusfromtellus
            I think most of them handle paypal/card. You can press the "Order" button to find out. Nothing is binding until payment has been done.
            • Paul RobertsonP
              Paul RobertsonP
              Paul Robertson
              Is there a drilling and outline file available?
              • Paul RobertsonP Paul Robertson
                sundberg84S
                sundberg84S
                @Paul-Robertson - hi!
                Yes, but this is Eagles output gerber files.
                Drill: SundbergMys9.TXT
                Outline can be found in all other files:
                https://www.pcbway.com/project/share/How_to_generate_Gerber_from_Eagle.html
                0_1505990995661_upload-c5e3c1d3-3dfb-46dc-9e10-e2d5dbfaca0d
                • sinczeS
                  sinczeS
                  sincze
                  MySensors Evangelist
                  Damn. Just missing the 0,1uF capacitor ..... to complete the 5v build. This will be my smallest build yet ;-) using PCB v9
                  dbemowskD 1 Reply Last reply
                  • sinczeS sincze
                    dbemowskD
                    dbemowskD
                    • H
                      H
                      hiddenuser
                      IS it possible to use TP4056 (https://www.aliexpress.com/item/5-pcs-Micro-USB-5V-1A-18650-TP4056-Lithium-Battery-Charger-Module-Charging-Board-With-Protection/32728720869.html?spm=a2g0s.9042311.0.0.A0lkC7) this instead of using the step up booster?
                      Thanks!!
                        If you want to use a lipo battery, you need a voltage regulator
                        • H hiddenuser
                          Thanks!!
                          sundberg84S
                          sundberg84S
                          @hiddenuser - well not out of the box as mentioned by gohan. Im not really sure what you want to do. Its not possible to use this instead of step-up booster since it outputs 5v and the step-up needs to output 3.3v. But with a voltage regulator in between maybe? As I said - don really understand so maybe you can explain some more about your project?
                          gohanG 1 Reply Last reply
                            @sundberg84 that tp4056 outputs just the lipo battery voltage
                            • H
                              H
                              hiddenuser
                              Thanks @sundberg84 and @gohan
                              I have used made the board for 3.3v set up as per the instruction. I have usd the output from tp4056 into the Battery connector of the board I have a step board from https://www.aliexpress.com/item/New-Electric-Unit-1-PC-NEW-DC-0-8-3-3V-to-DC-3-3V-StepUP/32724361266.html According to the specification given in the same link it is supposed to stabilize to 3.3v above 3v but the sensor reports something else back to the gateway.
                              sundberg84S gohanG 2 Replies Last reply
                              • H hiddenuser
                                sundberg84S
                                sundberg84S
                                @hiddenuser - well, what would a battery measurer be if it reported a constant 3.3v boosted voltage? ;)
                                It all depends on how everything is connected (pictures?) but if you have connected it as battery instryctions the radio and voltage divider that measured the incoming battery are not a part of the booster circuit. This to prevent noice to the radio and to be able to actually measure the battery voltage and not step-up voltage which is the idea behind the board.
                                • H hiddenuser
                                  @hiddenuser I'm missing how can you use a booster to get 3.3v from a lipo battery
                                  H 1 Reply Last reply
                                  • D
                                    dakipro
                                    hey, has anyone maybe made a fritzing drawing/component of the board?
                                    I know, I'm lazy as f but.. since the board is that easy, documenting with it could be easy as well :)
                                    • markjgabbM
                                      markjgabbM
                                      markjgabb
                                      @sundberg84 interesting question...or maybe stupid question not sure...
                                      i have a tonn of 3v pro mini's but im thinking of mains powering some for motion sensors.... would i set it up as battery, and then just use a voltage regulator on where the step up usually would be? or is there a better way to handle it?
                                        there is a voltage regulator footprint on the pcb made for that
                                        • markjgabbM
                                          markjgabbM
                                          markjgabb
                                          ahhh thats cool... so use regulated instead and it will pull down the voltage for antenna over that side
                                          ...and the board can handle the voltage anyway so it should be fine....
                                          12.5k
