  3. 💬 Button size radionode with sensors swarm extension
atsha204aflashhumidityrf69lightuv lightbatterymysensortemperatureota
189 Posts 28 Posters 75.1k Views 25 Watching
    ^^^warning: it's an infiltration bot.
    H 1 Reply Last reply
    • H hiddenuser
      Does any one have links to dirty pcb or OSH Park? Thanks a lot
      Miroslav KadaněM
      Miroslav KadaněM
      Miroslav KadanÄ›
        H
        H
        hiddenuser
        @NeverDie Not sure if you are referring to me?
        • Miroslav KadanÄ›M Miroslav KadanÄ›
          [[topic:post-is-deleted]]
          H
          H
          hiddenuser
          @Miroslav-KadanÄ› Thanks!!
          • H
            H
            hiddenuser
            I do not have an electronics background. I wend through the pdf files and order the parts and looks like I got the wrong resistor and capacitor or wrong part. Looks like I have to wait for an expert to comment let me know which resistor/capacitor goes where what part size. I would love to hear from someone ;)
            • KoreshK Koresh
              @Cliff-Karlsson The local factory starts assembly today (button size node, insertable switch node, wall socket insertable node and mini relay box). ETA is one-two week (max).
              This board is avaliable with two radios - rfm69hw and rfm69cw (with adapter shown below). Price will be the same. Which radio is preferred for you? If you plan to use this board with battery I suggest to use rfm69cw module to extend battery life (it has lower but enouogh power and works down to ~2V).
              Miroslav KadaněM
              Miroslav KadaněM
              Miroslav KadanÄ›
              wrote on last edited by Miroslav KadanÄ›
              #107
              @koresh it is possible to buy this adapter (RFM69HCW -> RFM69CW) or download pcb files ?
              Thx
                Thx
                @miroslav-kadaně said in 💬 Button size radionode with sensors swarm extension:
                @koresh it is possible to buy this adapter or download pcb files ?
                Thx
                Go to this link and press the download button: https://www.openhardware.io/view/299/Button-size-radionode-with-sensors-swarm-extension
                Miroslav KadaněM 1 Reply Last reply
                  Thx
                  Miroslav KadaněM
                  Miroslav KadaněM
                  Miroslav KadanÄ›
                  #109
                  @neverdie thx, but i need adapter from RFM69HCW to RFM69CW
                  • Y
                    Y
                    yury
                    Re: 💬 Button size radionode with sensors swarm extension
                    2 cr2032 winter upgrade - works nice
                    Keep working at -20 Celsius in a fridge. voltage dropped from 6 Volts to 5V and keeps pretty stable while sending temperature reading every 2 minutes for 2 days now.
                    • KoreshK
                      KoreshK
                      Koresh
                      wrote on last edited by Koresh
                      #111
                      There are so many reasons to use two CR2032 batteries in series with power converter instead of one lager battery like 2450
                      -CR2032 are much more widespread batteries
                      -Wider temperature range
                      -Stable voltage during all battery lifetime (using voltage converter)
                      -Stable radio power during battery lifetime
                      -Batteries give less current during transmitting so they are not "shocked" by high current.
                      So I plan to create version with two CR2032 batteries holder (like on the Yury's photo) and the ultra high efficiency DC-DC converter based on the tps62745 (400 nA quiescent current, 90% efficiency)
                      :wink:
                        #112
                        The main problem is finding a button holder that can hold two CR2032's in series. So far I've only found two. One is made by Linx, but it's definitely not ideal:
                        The other works fine, but it has a larger footprint, so I'm not presently using it. It may work well on your board, though, because your board is square, so you can use the diagonal:
                        On the other hand, maybe you could bend down the tabs and use it as a through-hole?
                        I did one where I simply cut-off the tabs and then soldered it to the board. That works, but it leaves me with an uneasy feeling as to how long it might last in that configuration. Maybe it's worth re-visiting.
                        Y 1 Reply Last reply
                          Y
                          Y
                          yury
                          @neverdie said in 💬 Button size radionode with sensors swarm extension:
                          worth
                          uh... apparently, yes. dual dip cr2032 is hard to find item on ali.
                          • KoreshK Koresh
                            :wink:
                            Miroslav KadaněM
                            Miroslav KadaněM
                            Miroslav KadanÄ›
                            @koresh Hello,
                            can you please update pcbdoc and schdoc files ?
                            And add a pcb adapter from RFM69HCW to RFM69CW ?
                            Thx Mirek
                            KoreshK 1 Reply Last reply
                              @koresh Hello,
                              Thx Mirek
                              KoreshK
                              KoreshK
                              Koresh
                              @miroslav-kadanÄ›
                              Hello Mirek. All source files are actual, I used exactly the same files to produce latest stable version. I never share source files until I test the board. So I will share updated files (like on the latest screenshot or better) after the board will be checked and tested :wink:
                              PS
                              I've added rfm converter board.
                              • C
                                C
                                chbla
                                With the default sensor and sketch I only get integer values - shouldn't this be decimals with 2 digits after the . ?
                                Not sure if I have a different lib or missed something
                                • C
                                  C
                                  chbla
                                  • C
                                    C
                                    chbla
                                    What's the typical time you get with the default node, coin cell and the sketch on github?
                                    https://gist.github.com/solars/6116b78ea7ee581ecfafddb8da4a9610
                                    It drained within only 1 day for me
                                      is it sleeping 5 seconds only?
                                      C 1 Reply Last reply
                                        C
                                        C
                                        chbla
                                        @gohan said in 💬 Button size radionode with sensors swarm extension:
                                        You are right, that was my mistake after testing it. However, the consumption still seems high.
                                        For example I'm right now testing a BME280 which I want to use in the future, with the following sketch:
                                        https://gist.github.com/solars/a5302f1cb60d90f89d7e37d5e23f8c4d
                                        It's connected to SDA/SCL and GND/V - somehow the voltage it receives with a fresh battery is already quite low, and it also doesn't last very long.
                                          you need to try to measure current while the sensor is sleeping as it should be a few uA maximum
