1.1k Posts 105 Posters 795.9k Views 98 Watching
  • mfalkviddM
    #200
    Testing a flow meter.
    It works pretty well, but at high flow rates (90 pulses per second) the esp8266 resets. Not sure if the reset is caused by too many interrupts or if the sensor uses too much power.
    • dbemowskD
      dbemowskD
      #201
      Though not fully finished, I am prototyping a new in-wall switch/scene controller with an integrated 128x64 OLED display. The design is made to fit my decora wall switch design that I had posted a while back. Here is a mock up of how I think the keypad and screen will be layed out.
      For the screen, I am hoping to display the current room temperature and possibly the outside temp. I can also scroll messages across the screen if needed. I can also do some custom graphics and icons.
      I have tested the display connected to my uno with the Adafruit sample code and think it does a nice job. This is not my video, but it is the same sample code that I used to test it.
      https://www.youtube.com/watch?v=ldq0-IXl_GM
      I'll post more as I get further along.
      • sinczeS
        sinczeS
        sincze
        MySensors Evangelist
        wrote on last edited by sincze
        #202
        Well as you can see, my prototyping skills are not at the level of @dbemowsk (always interested in the under side of the boards, mine look .. yeah a mess?), however I managed to create this enclosure (once closed looks nice enough).
        It should control the programmable LED lights in my livingroom (900 pieces).The board is powered 5v from the same power supply as the LED's. In addition it needs to measure the lux in the livingroom to decide if it is dark enough to turn on the lights.
        Initial tests looked okay, however after finding 56 effects in the Doll House of @Yveaux I decided to use that FX library as well. However the Arduino Mega is out of RAM to accomodate a full controll of the 900 LEDS. It will only control around 650 LEDS with that FX library.
        After being in contact with @Yveaux we decided to use an ESP solution. I have a spare NodeMCU v3 that can house the ESP gateway sketch and will have enough memory to controll the LEDs. Well now I have to look for a nice prototyping thing/case for the NodeMCU and add a level shifter as well. The LED's control line wants to be controlled by at least 3,7v.
        This is the nice thing about these kind of projects.. "There is always something to do"
        dbemowskD 1 Reply Last reply
        • sinczeS sincze
          dbemowskD
          dbemowskD
          @sincze I've done and seen a lot worse than this. Good job. Any particular reason you chose to use a Arduino Mega?
          sinczeS 1 Reply Last reply
          • dbemowskD dbemowsk
            sinczeS
            sinczeS
            sincze
            @dbemowsk Well first I started with my all time favourite... the Nano, as I have prototyping boards available.;-) but even with some simple light shows it did not have enough memory to hold de states of each individual 900 LEDs.
            I moved to the Mega. as it has more memory. My sketch worked fine so I started to build the node in its box. I also looked at the Github for the Doll House inspiration. I found the library that had 56 effects. So I thought why not use that one... Migrated my sketch, did a few tests with 300 LEDS, completed the enclosure and only than found out It could not controll all the 900 leds, due to memory issue. Insufficient RAM.
            But as this forum is a learning curve for me please feel free to share your thoughts. I always look at examples from others and see what I can do with it myself. I don't have fancy PCB equipment, justs a soldering iron and my own Aliexpress wearhouse with components ;-)
            • sinczeS sincze
              dbemowskD
              dbemowskD
              @sincze I should have known. All you had to say was memory and it would have made sense, or should I say sincze. LOL. With needing to hold states of 900 LEDs, I am going to guess that they are WS2812 LED strips.
              sinczeS H 2 Replies Last reply
                #206
                @dbemowsk I like your buttons-OLED a lot. It would be nice to have available a generic module like this with a screen and buttons and which "just works" to use on different projects. Nice work!
                dbemowskD 2 Replies Last reply
                  dbemowskD
                  dbemowskD
                  @neverdie I am hoping to soon have all of my boards posted on openhardware.io. I am just waiting for a reply on a thread I posted last night on what OHL to use when I upload them. I currently have a power supply board, the controller board that you see in the pics above, and a universal switch board that allows you to build it into everything from a single paddle switch to an 8 button scene controller. All of this fits a standard decora style US wall switch box. I designed the controller to be somewhat universal which is what gave me the flexibility for this design. I had thought about a similar design with this OLED display in which the buttons were layed out in an up, down, left, right and center select (U, D, L, R, S) configuration. If I ever get around to designing a board for this, I might see if it is possible for me to fit the buttons in a multi-configuration layout similar to my original button board where you can choose to make the 6 button layout like in my pics, or the U, D, L, R, S layout.
                    dbemowskD
                    dbemowskD
                    @neverdie As far has having a generic module, the display and button board, or even my original button board can be used with other things. The key is just knowing the connections, and you could plug these on to any header in that configuration. Below is the layout of my controller board, but if you layed out headers in the configurations I have on this board, you could use any of my switch boards.
                    • dbemowskD
                      dbemowskD
                      Since this is still in mockup stage, this is the other button configuration I was thinking about with an up, down, left, right, and center select.
                      • sundberg84S
                        sundberg84S
                        Assembling and testing rev 5 tonight.
                        • dbemowskD
                          dbemowskD
                          So last night I got the display connected and I now have the Adafruit sample code running on it:
                          https://youtu.be/knaLySC4X6I
                          Tonight I will be installing the buttons and hopefully working on some test code for the buttons and the screen. Here is my proposal for the switch wiring. The red traces are for the columns, and the blue are for the rows.
                          One thing that I would like to do with this is to possibly display some animated graphics for the current weather condition. Seeing the falling stars at the end of the Adafruit test code made me think of rain or snow falling. Something like that might go outside the limits of the pro minis memory, but hey, never hurts to try.
                          • dbemowskD
                            dbemowskD
                            So I have all of the keys soldered in and wired. I did some simple tests to see how things were working. I tested with a font size of 2, and again with a font size of 4.
                            Font size 2.
                            https://youtu.be/7tu7ZgkpF-0
                            Font size 4
                            https://youtu.be/acMMex0eIVs
                            • B
                              B
                              boozz
                              Today I build a basic node for temperature (DS18B20) and analog input. Most of my nodes feature a DS18B20 connection as it only 'costs' a 4k7 resistor and a connector.
                              PCB is etched.
                                BulldogLowellB
                                BulldogLowellB
                                BulldogLowell
                                @dbemowsk said in What did you build today (Pictures) ?:
                                Hey Nice Work!
                                I see you are using I2C, vs SPI... that may be why your display is so much slower than the demo in the Adafruit video.
                                Can't wait to see the final board!
                                • B boozz
                                  PCB is etched.
                                  @boozz What are those 3 pin male connectors called?
                                  andrewA B 2 Replies Last reply
                                    andrewA
                                    andrewA
                                    andrew
                                    @neverdie said in What did you build today (Pictures) ?:
                                    I guess that is molex 3 pin tht pcb connector, like this https://uk.rs-online.com/web/p/pcb-headers/4838477/
                                    • D
                                      Dalhoj
                                      Hi
                                      Its been a long time since I made something Mysensors.
                                      But now I made my first WIFI node with led dimmer. Using the ESP8266 NodeMCU.
                                      I use the VeraPlus and made a new Mysensors Device, and put in the IP of the NodeMCU.
                                      This is not my last wifi node. I am thinking of making a motion/temp sensor next :-)
                                      and the box.
                                      • andrewA
                                        andrewA
                                        andrew
                                        one step further...
                                        ISP works, FTDI works, test code works, and looks like a genuine board :)
                                        now comes the hard part :D
                                        NeverDieN mtiutiuM 2 Replies Last reply
                                        • andrewA andrew
                                          one step further...
                                          @andrew
                                          What is that spring loaded contraption? Is it for holding your PCB while you solder it? If so, I can see how that would be handy.
                                          andrewA 1 Reply Last reply
