  3. 💬 Button size radionode with sensors swarm extension
atsha204aflashhumidityrf69lightuv lightbatterymysensortemperatureota
189 Posts 28 Posters 75.1k Views 25 Watching
    is it sleeping 5 seconds only?
    C 1 Reply Last reply
      C
      C
      chbla
      @gohan said in 💬 Button size radionode with sensors swarm extension:
      You are right, that was my mistake after testing it. However, the consumption still seems high.
      For example I'm right now testing a BME280 which I want to use in the future, with the following sketch:
      https://gist.github.com/solars/a5302f1cb60d90f89d7e37d5e23f8c4d
      It's connected to SDA/SCL and GND/V - somehow the voltage it receives with a fresh battery is already quite low, and it also doesn't last very long.
        you need to try to measure current while the sensor is sleeping as it should be a few uA maximum
          C
          C
          chbla
          @gohan I only have a normal multimeter - what's the best way to do this?
          I came across https://www.eevblog.com/projects/ucurrent/ a while ago, is it worth it?
          Y 1 Reply Last reply
            There is a project in openhardware for a current meter if you want to build one, or you could buy a newer multimeter if the one you have can not measure uA
            • C chbla
              Y
              Y
              yury
              @chbla said in 💬 Button size radionode with sensors swarm extension:
              multimeter
              You should be fine even with a cheap multi-meter as long as it has uA scale.
              should be around 7-10 uA and if you do not send JDEC to sleep it is 17 -19 uA.
              to send JDEC to sleep\wakeup I use
              _flash.wakeup();
              _flash.sleep();
              light sensor should be sent to sleep explicitly also.
              gohanG C 2 Replies Last reply
              • Y yury
                multimeter
                _flash.wakeup();
                _flash.sleep();
                @yury not really, I have bought an Aneng cheap multimeter, but if I connect it with uA scale selected it will go out of range during node boot and cut the circuit making measurement impossible (unless you do something fancy that would make it unpractical)
                  Y
                  Y
                  yury
                  my cheap one survives 20mA surge (RFM69 CW version) of initial communications and displays good reading afterwards. if you burned fuse inside, try replacing it temporarily with some thin wire for this uA tests.
                    I have another cheap one that works. I didn't blow the fuse since turning it off and on it works again, it must be a software limitation
                    • Y yury
                      multimeter
                      _flash.wakeup();
                      _flash.sleep();
                      C
                      C
                      chbla
                      @yury said in 💬 Button size radionode with sensors swarm extension:
                      multimeter
                      _flash.wakeup();
                      _flash.sleep();
                      Right - but this is all in your sketch right? This is what I used:
                      • C
                        C
                        chbla
                        @Koresh would it be possible to sell this without the sensor part and RFM69? How many orders would it need?
                        I don't have the possibility to produce it myself, don't need the sensors part and have a lot of RFM69s lying around..
                        Thank you,
                        Christoph
                        • A
                          anovak
                          I downloaded gerber files.
                          Error Message from PCB Manufacturer:
                          The NC drill layer does not match with the pads of copper layer.
                          Thank you,
                          Attila
                          KoreshK 1 Reply Last reply
                          • A anovak
                            Thank you,
                            Attila
                            KoreshK
                            KoreshK
                            Koresh
                            @anovak
                            Hello. Do you mean main board or rfm69 adapter? It is very strange. I produced exactly these gerbers many time. :thinking_face:
                            • KoreshK
                              KoreshK
                              Koresh
                              Finally I have a little time to continue this project...
                              High efficient dc-dc converter works nice and double cr2032 are good. Lets go to the furher tests! :face_with_cowboy_hat:
                              • A
                                anovak
                                Thanks. The problem was solved.
                                Manufactured at very low cost on pcbway, they are manufactured with "Min Track / Spacing: 5 / 5mil".
                                Do you have any idea where they are manufactured cheaper?
                                • KoreshK
                                  KoreshK
                                  Koresh
                                  New version with double battery holder and power convertor works nice.
                                  Power consumption in sleep mode is less than 9uA :smiley:
                                  I will test it soon..
                                  alexsh1A 1 Reply Last reply
                                  • KoreshK Koresh
                                    alexsh1A
                                    alexsh1A
                                    alexsh1
                                    @koresh You only have two sensors BH1750 and Si7021. Did you try to have all four sensors and measure consumption?
                                    • A
                                      anovak
                                      Which pcb manufacturer do you recommend?
                                      I asked for a quote from Pcbway but it was expensive.
                                      The reason was:
                                      Change the 'Min Track / Spacing' value from 6 / 6mil to 5 / 5mil.
                                      Sorry for my bad English.
                                      • A anovak
                                        The reason was:
                                        KoreshK
                                        KoreshK
                                        Koresh
                                        @anovak Unfortunately you can reduce the price of the board only if you order more boards.
                                        • A
                                          anovak
                                          What price can be made in 10 items?
                                          gohanG 1 Reply Last reply
