  3. 💬 Button size radionode with sensors swarm extension
atsha204aflashhumidityrf69lightuv lightbatterymysensortemperatureota
189 Posts 28 Posters 75.1k Views 25 Watching
  • Y yury
    @chbla said in 💬 Button size radionode with sensors swarm extension:
    multimeter
    You should be fine even with a cheap multi-meter as long as it has uA scale.
    should be around 7-10 uA and if you do not send JDEC to sleep it is 17 -19 uA.
    to send JDEC to sleep\wakeup I use
    _flash.wakeup();
    _flash.sleep();
    light sensor should be sent to sleep explicitly also.
    C
    C
    chbla
    @yury said in 💬 Button size radionode with sensors swarm extension:
    multimeter
    _flash.wakeup();
    _flash.sleep();
    Right - but this is all in your sketch right? This is what I used:
    https://gist.github.com/solars/a5302f1cb60d90f89d7e37d5e23f8c4d
    • C
      C
      chbla
      @Koresh would it be possible to sell this without the sensor part and RFM69? How many orders would it need?
      I don't have the possibility to produce it myself, don't need the sensors part and have a lot of RFM69s lying around..
      Thank you,
      Christoph
      • A
        anovak
        I downloaded gerber files.
        Error Message from PCB Manufacturer:
        The NC drill layer does not match with the pads of copper layer.
        Thank you,
        Attila
        KoreshK 1 Reply Last reply
        • A anovak
          Thank you,
          Attila
          KoreshK
          KoreshK
          Koresh
          @anovak
          Hello. Do you mean main board or rfm69 adapter? It is very strange. I produced exactly these gerbers many time. :thinking_face:
          • KoreshK
            KoreshK
            Koresh
            Finally I have a little time to continue this project...
            High efficient dc-dc converter works nice and double cr2032 are good. Lets go to the furher tests! :face_with_cowboy_hat:
            • A
              anovak
              Thanks. The problem was solved.
              Manufactured at very low cost on pcbway, they are manufactured with "Min Track / Spacing: 5 / 5mil".
              Do you have any idea where they are manufactured cheaper?
              • KoreshK
                KoreshK
                Koresh
                New version with double battery holder and power convertor works nice.
                Power consumption in sleep mode is less than 9uA :smiley:
                I will test it soon..
                alexsh1A 1 Reply Last reply
                • KoreshK Koresh
                  alexsh1A
                  alexsh1A
                  alexsh1
                  @koresh You only have two sensors BH1750 and Si7021. Did you try to have all four sensors and measure consumption?
                  • A
                    anovak
                    Which pcb manufacturer do you recommend?
                    I asked for a quote from Pcbway but it was expensive.
                    The reason was:
                    Change the 'Min Track / Spacing' value from 6 / 6mil to 5 / 5mil.
                    Sorry for my bad English.
                    • A anovak
                      The reason was:
                      KoreshK
                      KoreshK
                      Koresh
                      @anovak Unfortunately you can reduce the price of the board only if you order more boards.
                      • A
                        anovak
                        What price can be made in 10 items?
                        gohanG 1 Reply Last reply
                        • A anovak
                          @anovak if you mean 10K maybe you can have a discount :sweat_smile:
                          • A
                            anovak
                            10 would be needed for the current project
                            At pcbway, the total cost of production and shipping costs is $ 34.
                            Is there someone who does it at a lower price?
                            Business account required.
                            I apologize for asking this question in this topic.
                            What type of transformer do you use and where to get it for the Mini Relay Box?
                            O KoreshK 2 Replies Last reply
                            • A anovak
                              O
                              O
                              Omemanti
                              @anovak do you want them completely assembled?
                              Yesterday I ordered 2 plain PCB's from seeedstudios, cost me 20 dollars incl, shipping. paid more for shipping than for the PCB's themselves. :)
                              but for the size, these units are you can get 6 or more in one design.
                              • A
                                anovak
                                Only PCBs are needed.
                                • A anovak
                                  KoreshK
                                  KoreshK
                                  Koresh
                                  wrote on last edited by Koresh
                                  #143
                                  @anovak I use in mini relay box the same transormer as in wall switch insertable node. Please read this comment https://forum.mysensors.org/topic/3938/wall-socket-insertable-node/57
                                    A Former User
                                    Can we buy it fully assembled and what would it cost?
                                    Y 1 Reply Last reply
                                    • ? A Former User
                                      Y
                                      Y
                                      yury
                                      @kenci
                                      Yes, in a week or so. Even with plastic enclosure ))
                                        A Former User
                                        @yury what would the price be for the fully assembled board?
                                        • ? A Former User
                                          Y
                                          Y
                                          yury
                                          @kenci
                                          EUR 18 the board with SI7021 and BH1750. extra 1EUR for enclosure if someone need it.
