  3. 💬 Button size radionode with sensors swarm extension
atsha204aflashhumidityrf69lightuv lightbatterymysensortemperatureota
189 Posts 28 Posters 76.6k Views 25 Watching
    I have another cheap one that works. I didn't blow the fuse since turning it off and on it works again, it must be a software limitation
    • Y yury
      @chbla said in 💬 Button size radionode with sensors swarm extension:
      multimeter
      You should be fine even with a cheap multi-meter as long as it has uA scale.
      should be around 7-10 uA and if you do not send JDEC to sleep it is 17 -19 uA.
      to send JDEC to sleep\wakeup I use
      _flash.wakeup();
      _flash.sleep();
      light sensor should be sent to sleep explicitly also.
      C
      C
      chbla
      @yury said in 💬 Button size radionode with sensors swarm extension:
      multimeter
      _flash.wakeup();
      _flash.sleep();
      Right - but this is all in your sketch right? This is what I used:
      https://gist.github.com/solars/a5302f1cb60d90f89d7e37d5e23f8c4d
      • C
        C
        chbla
        @Koresh would it be possible to sell this without the sensor part and RFM69? How many orders would it need?
        I don't have the possibility to produce it myself, don't need the sensors part and have a lot of RFM69s lying around..
        Thank you,
        Christoph
        • A
          anovak
          I downloaded gerber files.
          Error Message from PCB Manufacturer:
          The NC drill layer does not match with the pads of copper layer.
          Thank you,
          Attila
          KoreshK 1 Reply Last reply
          • A anovak
            Thank you,
            Attila
            KoreshK
            KoreshK
            Koresh
            @anovak
            Hello. Do you mean main board or rfm69 adapter? It is very strange. I produced exactly these gerbers many time. :thinking_face:
            • KoreshK
              KoreshK
              Koresh
              Finally I have a little time to continue this project...
              High efficient dc-dc converter works nice and double cr2032 are good. Lets go to the furher tests! :face_with_cowboy_hat:
              • A
                anovak
                Thanks. The problem was solved.
                Manufactured at very low cost on pcbway, they are manufactured with "Min Track / Spacing: 5 / 5mil".
                Do you have any idea where they are manufactured cheaper?
                • KoreshK
                  KoreshK
                  Koresh
                  New version with double battery holder and power convertor works nice.
                  Power consumption in sleep mode is less than 9uA :smiley:
                  I will test it soon..
                  alexsh1A 1 Reply Last reply
                  • KoreshK Koresh
                    alexsh1A
                    alexsh1A
                    alexsh1
                    @koresh You only have two sensors BH1750 and Si7021. Did you try to have all four sensors and measure consumption?
                    • A
                      anovak
                      Which pcb manufacturer do you recommend?
                      I asked for a quote from Pcbway but it was expensive.
                      The reason was:
                      Change the 'Min Track / Spacing' value from 6 / 6mil to 5 / 5mil.
                      Sorry for my bad English.
                      • A anovak
                        The reason was:
                        KoreshK
                        KoreshK
                        Koresh
                        @anovak Unfortunately you can reduce the price of the board only if you order more boards.
                        • A
                          anovak
                          What price can be made in 10 items?
                          gohanG 1 Reply Last reply
                          • A anovak
                            @anovak if you mean 10K maybe you can have a discount :sweat_smile:
                            • A
                              anovak
                              10 would be needed for the current project
                              At pcbway, the total cost of production and shipping costs is $ 34.
                              Is there someone who does it at a lower price?
                              Business account required.
                              I apologize for asking this question in this topic.
                              What type of transformer do you use and where to get it for the Mini Relay Box?
                              O KoreshK 2 Replies Last reply
                              • A anovak
                                O
                                O
                                Omemanti
                                @anovak do you want them completely assembled?
                                Yesterday I ordered 2 plain PCB's from seeedstudios, cost me 20 dollars incl, shipping. paid more for shipping than for the PCB's themselves. :)
                                but for the size, these units are you can get 6 or more in one design.
                                • A
                                  anovak
                                  Only PCBs are needed.
                                  • A anovak
                                    KoreshK
                                    KoreshK
                                    Koresh
                                    wrote on last edited by Koresh
                                    #143
                                    @anovak I use in mini relay box the same transormer as in wall switch insertable node. Please read this comment https://forum.mysensors.org/topic/3938/wall-socket-insertable-node/57
                                      A Former User
                                      Can we buy it fully assembled and what would it cost?
                                      Y 1 Reply Last reply
                                      • ? A Former User
                                        Y
                                        Y
                                        yury
                                        @kenci
                                        Yes, in a week or so. Even with plastic enclosure ))
                                          A Former User
                                          @yury what would the price be for the fully assembled board?
                                          12.5k
