1.1k Posts 105 Posters 795.9k Views 98 Watching
  • R reinhold
    @gohan I'm using the SSD1306Ascii library, which does not use a display buffer and does not support graphics, only text. The drawback is that to prevent screen flickering, you have to manually clean each line of text to the EOL. Otherwise letters that are not overwritten by new text will not be cleared. See my PR for NodeManager how it works. With my approach, there is absolutely no screen flicker, the display updates properly and the memory requirements are minimal (the library docs say its 53 bytes)
    dbemowskD
    dbemowskD
    #290
    I now have revision 1.0 of my OLED keypad posted on OpenHardware.io. My first revision of the board allows for either the 6 pin SPI or 4 pin I2C versions of the SSD1306 OLED display. The 9 button configuration allows for several different combinations of buttons depending on the needs of the user.
    https://www.openhardware.io/view/546
    • sinczeS
      sinczeS
      sincze
      MySensors Evangelist
      I found out that the brinks solution I build some time ago could be upgraded with a nice additional feature. 'Filter detection'.
      I created a cheat sheet as my device was equiped with RJ11 connector and 3 wires. I needed to convert it to RJ12 with filter detection.
      A nice black conversion box Output wires are the same colour as the original RJ 1 wire. With 2 extra wires 3,3v or 5v for the digital 'one' on the arduino.
      • andrewA andrew
        0_1512830079874_small_20171119_155404.jpg 0_1512830092134_small_20171119_163354.jpg 0_1512830107562_small_20171119_163849.jpg 0_1512830119867_small_20171119_164745.jpg 0_1512830130032_small_20171119_165717.jpg 0_1512830150237_small_20171203_092353.jpg 0_1512830159490_small_20171203_163658.jpg 0_1512830169403_small_20171207_194213.jpg
        andrewA
        andrewA
        andrew
        @andrew said in What did you build today (Pictures) ?:
        so, it is ready. I mean ready to SW development :) both the schematic and pcb design is now confirmed and fortunately theory meets the practice :)
        it is assembled, programmed, tested, everything works as expected.
        I did not mount it to the wall so far (I'll need a controller and real actuators first), but there was no issue with the communication between two nrf modules (both with PCB antenna) from cca 6 meter distance + 2 walls (10 cm brick) in between.
        the touch panel's firmware will be enhanced as well as the controller's firmware, at the moment the touch sensing is reliable and a PoC code run on both of them for testing/debugging purposes. for the controller board I'm collecting additional information for the development on the following link:
        https://forum.mysensors.org/topic/8831/which-sensor-and-msg-type-for-switch-dimmer-node-sender-only
        YveauxY jeremushkaJ 2 Replies Last reply
        • andrewA andrew
          @andrew Nice work man!
          Where did you source the gray enclosure from?
          andrewA 1 Reply Last reply
          • YveauxY Yveaux
            andrewA
            andrewA
            andrew
            @yveaux said in What did you build today (Pictures) ?:
            thanks! the cover is also part of the original livolo (well, in fact a chinese clone of livolo) touch switch.
            • andrewA
              andrewA
              andrew
              https://www.youtube.com/watch?v=l2aiqRqlwKo
              sinczeS 1 Reply Last reply
              • andrewA andrew
                sinczeS
                sinczeS
                sincze
                András Kabai
                Nice video András ;-)
                • sinczeS sincze
                  András Kabai
                  andrewA
                  andrewA
                  andrew
                  @sincze thanks, Sandor ;)
                    Added a buzzer to my nRF51822 coincell device to make a locator beacon. Attach the device to an object you tend to lose and it will make sounds when you activate it, allowing you to find it.
                    The buzzer is driven by a load switch, so that none of the nRF51822 pins are overloaded:
                      andrewA
                      andrewA
                      andrew
                      @neverdie I hope that you made the prototyping with the cnc ;)
                      • sinczeS
                        sinczeS
                        sincze
                        Finally, the last day of my holiday I managed to upload the Mysensors Sketch into the NodeMCU to control my 900 LEDS. It will also read the lux intensity in the livingroom. So if it is dark the lights will switch on.
                        All is based on @Yveaux Mysensors ESP Gateway port. On a rainy saterday last year @Yveaux and I found out we did not have to modify anything on the voltag level for driving the LEDS. ;)
                        The sketch includes all the Doll_House animations (around 55) that can be skipped through using an old 433mhz remote (or via interface directly ofcourse) Next stop... Installing 15 meters of LED in the livingroom. pffff ;-)
                        And putting everything inside this little box @Yveaux printed for me.
                          #301
                          today I've almost finished a speaker build :) (it'll be a gift for family)
                          First, I would like to thx Paul Carmody who created the original design of these speakers : Overnight Sensation :clap: :+1:
                          https://sites.google.com/site/undefinition/diy-overnightsensations
                          I have just changed size and format (of course I kept the internal air volume which is very important)
                          1. I designed&printed a simple circle jig for my router.
                          2. So speaker drivers can be flush on front plate
                          3. Assembled the box
                          4. Crossover, port tube, foam
                            with a special place to fit some electronics like
                          • rpi (for Volumio/LMS client, or a voice assistant)
                          • cheap dac & 2x50w amp from aliexpress
                          1. Now vinyling. I need to change these ugly black screws too.
                          Of course, I'm too excited (and not very patient ), so I've tested how they sound... Loud! Crystal sound with very nice boomboom :muscle:
                          Not finished, but in good way :)
                          zboblamontZ F 2 Replies Last reply
                          • scalzS scalz
                            zboblamontZ
                            zboblamontZ
                            zboblamont
                            @scalz I have to guess this is a centre speaker?
                            Some tidy inductors there on the crossover...
                            How times have changed, now you can PRINT a router jig, used to make them with a piece of plywood for circles smaller that the router radius... Centre was drilled and fitted with threaded rod so you could cut back the front of the baffle but also chamfer the back face of the speaker baffle before cutting out the opening...
                            Tidy enough, great when they get fired up....
                            scalzS 1 Reply Last reply
                            • Nca78N
                              Today I (finally) finished a full working version of that old Livolo 3 buttons switch. I removed the RGB led on the central button as it's not visible, but the basic switch functionality with buttons/relays and blue/red status leds runs fine.
                              It's running with MYSBootloader, it's really convenient to update without having to switch of the fuse and unmount everything.
                              A (quick) video, touch sensibility is perfect now, I'm really happy with it !
                              https://www.youtube.com/watch?v=G6yEdSyoMYw
                              • scalzS scalz
                                F
                                F
                                fredswed
                                @scalz That looks very neat and tempting indeed! A pair of Overnight Sensation has long been in the plans for my next (and first) speaker build. Where did you get the components?
                                • zboblamontZ zboblamont
                                  #305
                                  @zboblamont
                                  well actually it's setup as a standalone stereo speaker. I asked my brother (it's a gift for him) if he would prefer separated speakers (better for stereo). But he prefers like this, standalone with no wires, and his room won't be wide so it should be ok.
                                  Yes, i know for the jigs in plywood, but i have a 3d printer, caliper; drawing, print and voilà :)
                                  I like using cad software for checking assemblies in 3d etc, very handy, and it's more precise than my brain :).
                                  @fredswed yeah, it sounds very nice. when you hear it, then you know you made the good choice. Better than buying any of these 60 to >200$ smart speakers. I compared them with some others hifi speakers (jbl..) for fun, and still very impressive. Some of my friends are jealous. They want one, or more. Same for my others bro. They sound pretty loud imho, and would like to try a pair like that for fun
                                  I ordered most of the parts at loudspeakerfreaks or audiohobby. if you live in USA, then it's better to give a try to parts express I think.
                                  I finished the vinyling yesterday (my bro didn't want I roundish the corner). I now just need to add a rpi inside and connectors etc on back, not bad :)
                                  sundberg84S zboblamontZ 2 Replies Last reply
                                  • scalzS scalz
                                    @zboblamont
                                    sundberg84S
                                    sundberg84S
                                    @scalz - im using volumio (finished image for RPI) and happy with this. Just a tip...
                                    Buildthread (Swedish)
                                    • sundberg84S sundberg84
                                      #307
                                      same here with a few additional plugins ;) Agreed, volumio is sexy sw.
                                      your speaker looks nice :+1:
                                      I read and learnt a lot how to make diy speakers. It was very interesting learning curve, lot of parameters I didn't know before (and one of the most important rule is : tune your enclosure regarding speaker drivers specs, not the oppposite (there are software for calculating everything) Now I understand better the curves etc and where commercial stuff cheats. pretty cool
                                      • scalzS scalz
                                        sundberg84S
                                        sundberg84S
                                        #308
                                        @scalz - this was my first project and I agree with you (because I didnt calculate much before). If you are looking for the best sound its incredible important... for me and this build I wanted a small enclosure in the kitchen but the sound is pretty impressive for such a small thing so Im happy even though I know it could have sounded better.
                                        • scalzS scalz
                                          @zboblamont
                                          zboblamontZ
                                          zboblamontZ
                                          zboblamont
                                          @scalz Whatever, so long as your brother enjoys what he asked for, job done.
                                          Do I interpret your comment on "roundish the corner" as rounding over the front baffle edges? Sonically it can make a difference for imaging, but with drives this close I doubt it would be noticeable anyway, and would be a pain to vinyl let alone veneer....
                                          Almost 50 years I've been building speakers as a hobby....
                                          I'll finish them one day ;)
