716 Posts 111 Posters 703.2k Views 93 Watching
  • sundberg84S sundberg84
    @mr_sensor - I can not see any errors on the pictures you posted.
    Can you measure the voltage on Booster-Vout and also on this pad.
    Mr_sensor
    @sundberg84 said in 💬 Easy/Newbie PCB for MySensors:
    I did measure the parts you mentioned. Booster is 3,36 v and the other pad is 0,00 the input strait from the batteries is 2,80 v
    Also, Just for my info, does it matter how the resistors or capacitors are soldered on the board? My biggest problem is always determine the right resistors value and the right way to solder them (+ -). On the pcb some of them are coded (very handy for me as a beginner) with a G but not all of them?
    So my worry was that I maybe have soldered the "battery measurer" ones in the wring direction? Could that be the problem here?
      Resistors can be soldered either way, but if you read 0v on that capacitor pin it mean you have a problem between the battery and the capacitor, so you have to backtrack the connection that is missing
        Mr_sensor
        @gohan said in 💬 Easy/Newbie PCB for MySensors:
        I measured the capacitor again and get a 0,10 output.
          What are the resistor values you used? 0.1v is quite low
            Mr_sensor
            Maybe I used the wrong capacitor it says 1uf (50v) but now I see it has to be 0,1uf could that be the problem here?
            • sundberg84S
              sundberg84S
              #508
              Capacitor value does not change the voltage. The resistors does... I would double check that you use the right resistors. For example it's easy to use a resistor marked 1k instead of 1M. With 3.3v you should have around 1v on the capacitor.
                you are also missing the capacitor on the booster output for better stability
                  Mr_sensor
                  Ok, I assumed it was not needed when using a battery. Which one to use there?
                    It is needed if you use a booster. Look at project page for details.
                    • M Mr_sensor
                      sundberg84S
                      sundberg84S
                      @mr_sensor a advice is to measure the resistance again over the resistors.
                        Mr_sensor
                        @sundberg84 Well I tried that but did not get the measurement straight from the pcb si I decided t solder a new board using the right capacitor this time (0,1uf instead of 1uf) made sure using the right resistors as well and adding a capacitor after the booster. Than with the same mini pro from the other board tested again and wow it is working as intended.
                        Child ID 2Battery Voltage: 3.44 V
                        Battery Percent: 102 %
                        2930 TSF:MSG:SEND,2-2-0-0,s=255,c=3,t=0,pt=1,l=1,sg=0,ft=0,st=OK:102
                        2938 MCO:SLP:MS=60000,SMS=0,I1=255,M1=255,I2=255,M2=255
                        2945 TSF:TDI:TSL
                        2947 MCO:SLP:WUP=-1
                        2949 TSF:TRI:TSB
                        3065 TSF:MSG:SEND,2-2-0-0,s=1,c=1,t=0,pt=7,l=5,sg=0,ft=0,st=OK:998.0
                        T: 998.00
                        3178 TSF:MSG:SEND,2-2-0-0,s=0,c=1,t=1,pt=7,l=5,sg=0,ft=0,st=OK:998.0
                        H: 998.00
                        957
                        Child ID 2Battery Voltage: 3.22 V
                        Battery Percent: 95 %
                        3690 TSF:MSG:SEND,2-2-0-0,s=255,c=3,t=0,pt=1,l=1,sg=0,ft=0,st=OK:95
                        3698 MCO:SLP:MS=60000,SMS=0,I1=255,M1=255,I2=255,M2=255
                        3704 TSF:TDI:TSL
                        3706 MCO:SLP:WUP=-1
                        3708 TSF:TRI:TSB
                        3815 TSF:MSG:SEND,2-2-0-0,s=1,c=1,t=0,pt=7,l=5,sg=0,ft=0,st=OK:998.0
                        T: 998.00
                        3932 TSF:MSG:SEND,2-2-0-0,s=0,c=1,t=1,pt=7,l=5,sg=0,ft=0,st=OK:998.0
                        H: 998.00
                        955
                        Child ID 2Battery Voltage: 3.21 V
                        4442 MCO:SLP:MS=60000,SMS=0,I1=255,M1=255,I2=255,M2=255
                        4452 TSF:TDI:TSL
                        4454 MCO:SLP:WUP=-1
                        4456 TSF:TRI:TSB
                        4560 TSF:MSG:SEND,2-2-0-0,s=1,c=1,t=0,pt=7,l=5,sg=0,ft=0,st=OK:998.0
                        T: 998.00
                        4673 TSF:MSG:SEND,2-2-0-0,s=0,c=1,t=1,pt=7,l=5,sg=0,ft=0,st=OK:998.0
                        H: 998.00
                        953
                        5185 MCO:SLP:MS=60000,SMS=0,I1=255,M1=255,I2=255,M2=255
                        5193 TSF:TDI:TSL
                        5195 MCO:SLP:WUP=-1
                        5197 TSF:TRI:TSB
                        5304 TSF:MSG:SEND,2-2-0-0,s=1,c=1,t=0,pt=7,l=5,sg=0,ft=0,st=OK:998.0
                        T: 998.00
                        5416 TSF:MSG:SEND,2-2-0-0,s=0,c=1,t=1,pt=7,l=5,sg=0,ft=0,st=OK:998.0
                        H: 998.00
                        952
                        Child ID 2Battery Voltage: 3.20 V
                        5926 MCO:SLP:MS=60000,SMS=0,I1=255,M1=255,I2=255,M2=255
                        5935 TSF:TDI:TSL
                        5939 MCO:SLP:WUP=-1
                        5941 TSF:TRI:TSB
                        6045 TSF:MSG:SEND,2-2-0-0,s=1,c=1,t=0,pt=7,l=5,sg=0,ft=0,st=OK:998.0
                        T: 998.00
                        6158 TSF:MSG:SEND,2-2-0-0,s=0,c=1,t=1,pt=7,l=5,sg=0,ft=0,st=OK:998.0
                        H: 998.00
                        952
                        6670 MCO:SLP:MS=60000,SMS=0,I1=255,M1=255,I2=255,M2=255
                        6678 TSF:TDI:TSL
                        6680 MCO:SLP:WUP=-1
                        6682 TSF:TRI:TSB
                        6789 TSF:MSG:SEND,2-2-0-0,s=1,c=1,t=0,pt=7,l=5,sg=0,ft=0,st=OK:998.0
                        T: 998.00
                        6901 TSF:MSG:SEND,2-2-0-0,s=0,c=1,t=1,pt=7,l=5,sg=0,ft=0,st=OK:998.0
                        H: 998.00
                        952
                        7411 MCO:SLP:MS=60000,SMS=0,I1=255,M1=255,I2=255,M2=255
                        7419 TSF:TDI:TSL
                        7424 MCO:SLP:WUP=-1
                        7426 TSF:TRI:TSB
                        7530 TSF:MSG:SEND,2-2-0-0,s=1,c=1,t=0,pt=7,l=5,sg=0,ft=0,st=OK:998.0
                        T: 998.00
                        7643 TSF:MSG:SEND,2-2-0-0,s=0,c=1,t=1,pt=7,l=5,sg=0,ft=0,st=OK:998.0
                        H: 998.00
                        952
                        8155 MCO:SLP:MS=60000,SMS=0,I1=255,M1=255,I2=255,M2=255
                        8163 TSF:TDI:TSL
                        8165 MCO:SLP:WUP=-1
                        8167 TSF:TRI:TSB
                        8273 TSF:MSG:SEND,2-2-0-0,s=1,c=1,t=0,pt=7,l=5,sg=0,ft=0,st=OK:998.0
                        T: 998.00
                        8388 TSF:MSG:SEND,2-2-0-0,s=0,c=1,t=1,pt=7,l=5,sg=0,ft=0,st=OK:998.0
                        H: 998.00
                        955
                        8898 MCO:SLP:MS=60000,SMS=0,I1=255,M1=255,I2=255,M2=255
                        8908 TSF:TDI:TSL
                        8910 MCO:SLP:WUP=-1
                        8912 TSF:TRI:TSB
                        9021 TSF:MSG:SEND,2-2-0-0,s=1,c=1,t=0,pt=7,l=5,sg=0,ft=0,st=OK:998.0
                        T: 998.00
                        9132 TSF:MSG:SEND,2-2-0-0,s=0,c=1,t=1,pt=7,l=5,sg=0,ft=0,st=OK:998.0
                        H: 998.00
                        948
                        Child ID 2Battery Voltage: 3.19 V
                        Battery Percent: 94 %
                        9646 TSF:MSG:SEND,2-2-0-0,s=255,c=3,t=0,pt=1,l=1,sg=0,ft=0,st=OK:94
                        9654 MCO:SLP:MS=60000,SMS=0,I1=255,M1=255,I2=255,M2=255
                        9660 TSF:TDI:TSL
                        9662 MCO:SLP:WUP=-1
                        9664 TSF:TRI:TSB
                        9771 TSF:MSG:SEND,2-2-0-0,s=1,c=1,t=0,pt=7,l=5,sg=0,ft=0,st=OK:998.0
                        T: 998.00
                        9881 TSF:MSG:SEND,2-2-0-0,s=0,c=1,t=1,pt=7,l=5,sg=0,ft=0,st=OK:998.0
                        H: 998.00
                        952
                        10395 TSF:MSG:SEND,2-2-0-0,s=255,c=3,t=0,pt=1,l=1,sg=0,ft=0,st=OK:95
                        10403 MCO:SLP:MS=60000,SMS=0,I1=255,M1=255,I2=255,M2=255
                        10409 TSF:TDI:TSL
                        10412 MCO:SLP:WUP=-1
                        10414 TSF:TRI:TSB
                        10520 TSF:MSG:SEND,2-2-0-0,s=1,c=1,t=0,pt=7,l=5,sg=0,ft=0,st=OK:998.0
                        T: 998.00
                        10635 TSF:MSG:SEND,2-2-0-0,s=0,c=1,t=1,pt=7,l=5,sg=0,ft=0,st=OK:998.0
                        H: 998.00
                        953
                        11147 MCO:SLP:MS=60000,SMS=0,I1=255,M1=255,I2=255,M2=255
                        11155 TSF:TDI:TSL
                        Now in mqtt I can see the percentage as:
                        95
                        qos : 0, retain : false, cmd : publish, dup : false, topic : **mygateway1-out/2/255/3/0/0**, messageId : , length : 30, Raw payload : 5753```
                        But not the voltage?
                        • M Mr_sensor
                          2945 TSF:TDI:TSL
                          2947 MCO:SLP:WUP=-1
                          2949 TSF:TRI:TSB
                          T: 998.00
                          H: 998.00
                          957
                          3704 TSF:TDI:TSL
                          3706 MCO:SLP:WUP=-1
                          3708 TSF:TRI:TSB
                          T: 998.00
                          H: 998.00
                          955
                          4452 TSF:TDI:TSL
                          4454 MCO:SLP:WUP=-1
                          4456 TSF:TRI:TSB
                          T: 998.00
                          H: 998.00
                          953
                          5193 TSF:TDI:TSL
                          5195 MCO:SLP:WUP=-1
                          5197 TSF:TRI:TSB
                          T: 998.00
                          H: 998.00
                          952
                          5935 TSF:TDI:TSL
                          5939 MCO:SLP:WUP=-1
                          5941 TSF:TRI:TSB
                          T: 998.00
                          H: 998.00
                          952
                          6678 TSF:TDI:TSL
                          6680 MCO:SLP:WUP=-1
                          6682 TSF:TRI:TSB
                          T: 998.00
                          H: 998.00
                          952
                          7419 TSF:TDI:TSL
                          7424 MCO:SLP:WUP=-1
                          7426 TSF:TRI:TSB
                          T: 998.00
                          H: 998.00
                          952
                          8163 TSF:TDI:TSL
                          8165 MCO:SLP:WUP=-1
                          8167 TSF:TRI:TSB
                          T: 998.00
                          H: 998.00
                          955
                          8908 TSF:TDI:TSL
                          8910 MCO:SLP:WUP=-1
                          8912 TSF:TRI:TSB
                          T: 998.00
                          H: 998.00
                          948
                          9660 TSF:TDI:TSL
                          9662 MCO:SLP:WUP=-1
                          9664 TSF:TRI:TSB
                          T: 998.00
                          H: 998.00
                          952
                          10409 TSF:TDI:TSL
                          10414 TSF:TRI:TSB
                          T: 998.00
                          H: 998.00
                          953
                          11155 TSF:TDI:TSL
                          95
                          sundberg84S
                          sundberg84S
                          @mr_sensor good to hear its working.
                          It looks like you are only sending the % and not the voltage?
                          • D
                            dakipro
                            @Mr_sensor It happened to me once that capacitor was just shortening the circuit, it was a smd, but when I removed it and tested it it was constantly making shortage, thus the circuit was never working and luckily my power supply had a low enough protection.
                            I examined cap very closely, all looked fine, but internally it was not working fine.
                            Since most of us (well, me at least) are buying cheap components I made it a habit now to always measure every passive component before installation, partly eliminates one variable
                            • sundberg84S
                              sundberg84S
                              #516
                              A short sneak-peak on the upcoming revision...
                              Still a long way to go...
                              Rev 10 - Nrf24l01+ ed.
                              • Completley redesigned in KiCad.
                              • MysX location changed to accept more MysX boards and align like RFM version.
                              • Optional signing added
                              • Optional SPI flash added.
                              • Extra pins aligned to 2.45 vertical & horisontal
                              • Relocated Extra + Bat Measurer some to allow more space to booster
                              • Changed pull-up resistor from D3 to D5 to have one more pin for Interrupt
                              • Relocated D5 pullup, MysX and IRQ jumper some.
                              • Changed footprint (silk-screen) on capacitor to easier show Gnd/Pos side.
                              Need to change footprint on voltage regulator on both nrf and rfm edition back to a square and not a liniar one. (rev 9 change). Not intended to revert back.
                              Also a bit worried the 4,7uF cap os to far away from radio.
                              gohanG Nca78N 2 Replies Last reply
                                Putting it underneath the nrf24 module? I know it is not a "clean solution" but there would be still be unused space under the radio module
                                  sundberg84S
                                  sundberg84S
                                  @gohan - thanks, not what I want to do - I have descided to have optional/more advanced on bottom side. This is the core idea of the PCB. I might revert back to Rev 9 footprint and squeeze it in like prev. revision.
                                    maybe a smaller footprint for ceramic instead of electrolitic?
                                      Please don't do like that and follow the guideline for the MYSX connector (location was already wrong in previous versions and it's a bit annoying to make MYSX boards for Easy PCB):
                                      *"The MYSX connector should be placed close to the board edge with a 100 mil spacing from all edges. The footprint has a courtyard outline to emphasize this"
                                      I agree especially with other traces to cross before reaching the radio.
                                      • Nca78N Nca78
                                        sundberg84S
                                        sundberg84S
                                        #521
                                        @nca78 said in 💬 Easy/Newbie PCB for MySensors:
                                        I actually had a long discussion with @Anticimex which is the designer of MysX and he said it is not wrong. Can you please explain why it's wrong ?
                                        I was thinking pin 1 should go towards both vertical and horizontal edge of the pcb (that's why I asked him because I though It should go where the radio is) but he said the only rule is pin 1 should go towards the edge. I looked at the rules and that is what it said so I don't think I'm breaking any rules.
                                        The footprint has a courtyard outline to emphasize this.
                                        It should be oriented so that pin1 is always closest to the board edge parallel to the connector.
                                        This allows a daughter board designed using the same constraints to be facing back "inwards" over the motherboard
                                        Either way it has changed like less than 1mm
                                        If we can somehow get Anticimex to recommend and we can agree on a better placement I'm happy to re-think my design.
                                        If you thinks it's hard to create MysX boards for EasyPcb I have created a finished Kicad project with board outlines, connector and drill holes you can use as a template. Check it out on the project page.
                                        AnticimexA 1 Reply Last reply
                                          AnticimexA
                                          AnticimexA
                                          Anticimex
                                          #522
                                          @sundberg84 I cannot see anything wrong with the MYSX placement on that board.
                                          If one could pick freely, ideal placement of the connector would be in the middle of the board side to allow daughter boards to extend both "upward" and "downward".
                                          But the important rule is the one already cited, that pin1 is oriented to ensure daughterboard orientation relative to the motherboard and that there is spacing around the connector so that the daughterboard female connector does not come in contact with main board cirquitry.
                                          Also that the daughterboard does not protrude outside of the mainboard at least along the edge the connector is aligned to.
                                          Daughterboards in general should not be designed to be wider than the MYSX connector used for this reason (avoiding daughterboard protruding outside mainboard area) to allow a mainboard specific case to be reused with daughterboards mounted.
                                          Edit: if possible, try to move the components right next to the connector. (remember the 100mil spacing). The resistor below can probably be mounted on the reverse side.
