  3. [SOLVED] MY_RFM69_NEW_DRIVER, SensebenderGW, SensebenderMicro
9 Posts 4 Posters 2.6k Views 3 Watching
  • korttomaK
    korttomaK
    korttoma
    I can't seem to get the NEW RFM69 driver to work. I have a SensebenderGW and a SensebenderMicro. It seems to work just fine with the old driver, so if I comment out the following line it works nicely:
    #define MY_RFM69_NEW_DRIVER
    GW sketch:
     * Version 1.0 - Henrik EKblad
     * LED purposes:
    #define SN "EthGW/RFM69 Rele Button"
    #define SV "1.5"
    //#define MY_RADIO_NRF24
    //#define MY_RADIO_NRF5_ESB
    #define MY_RADIO_RFM69
    #define MY_RFM69_FREQUENCY RFM69_433MHZ
    #define MY_RFM69_ATC_MODE_DISABLED
    #define MY_IS_RFM69HW
    //#define MY_RFM69_NETWORKID 105
    //#define MY_RF69_SPI_CS 29
    #define MY_DEBUG_VERBOSE_RFM69
    #define MY_BAUD_RATE 38400
    #define MY_GATEWAY_W5100
    //#define MY_W5100_SPI_EN 4
    // radio on the same spi bus.
    #define MY_SOFTSPI
    #ifndef MY_RF24_CE_PIN
    #define MY_RF24_CE_PIN 5
    #ifndef MY_RF24_CS_PIN
    #define MY_RF24_CS_PIN 6
    // Enable UDP communication
    //#define MY_USE_UDP  // If using UDP you need to set MY_CONTROLLER_IP_ADDRESS below
    #define MY_IP_ADDRESS 192,168,1,100
    #define MY_PORT 5003
    #define MY_MAC_ADDRESS 0xDE, 0xAD, 0xBE, 0xFE, 0xFE, 0xED
    // Enable inclusion mode
    // Set blinking period
    // Flash leds on rx/tx/err
    #if defined(MY_USE_UDP)
    #include <EthernetUdp.h>
    #include <Ethernet.h>
    #define RELAY_ON 0                      // switch around for ACTIVE LOW / ACTIVE HIGH relay
    #define RELAY_OFF 1
    #define noRelays 4                     //2-4
    const int relayPin[] = {MYSX_D5_PWM, MYSX_D6_PWM, MYSX_D9_A3, MYSX_D10_A4};       //  switch around pins to your desire
    const int buttonPin[] = {MYSX_D1_DFM, MYSX_D2_DTM, MYSX_D3_INT, MYSX_D4_INT};   //  switch around pins to your desire
    class Relay             // relay class, store all relevant data (equivalent to struct)
      public:
        int buttonPin;                   // physical pin number of button
        int relayPin;             // physical pin number of relay
        boolean relayState;               // relay status (also stored in EEPROM)
    Relay Relays[noRelays];
    Bounce debouncer[noRelays];
    MyMessage msg[noRelays];
      wait(100);
      for (int i = 0; i < noRelays; i++) {
        Relays[i].buttonPin = buttonPin[i];              // assign physical pins
        msg[i].type = V_LIGHT;
        wait(100);
        Relays[i].relayState = loadState(i);                               // retrieve last values from EEPROM
        digitalWrite(Relays[i].relayPin, Relays[i].relayState ? RELAY_ON : RELAY_OFF); // and set relays accordingly
        send(msg[i].set(Relays[i].relayState ? true : false));                 // make controller aware of last status
        wait(50);
        debouncer[i].interval(30);
        wait(50);
      sendSketchInfo(SN, SV);
      wait(100);
        present(i, S_LIGHT);                               // present sensor to gateway
      wait(100);
      for (byte i = 0; i < noRelays; i++) {
        if (debouncer[i].update()) {
          if ( value == LOW) {
            // save sensor state in EEPROM (location == sensor number)
            saveState( i, Relays[i].relayState );
      //wait(20);
      if (message.sender == 0) {
          if (message.sensor < noRelays) {          // check if message is valid for relays..... previous line  [[[ if (message.sensor <=noRelays){ ]]]
            digitalWrite(Relays[message.sensor].relayPin, Relays[message.sensor].relayState ? RELAY_ON : RELAY_OFF); // and set relays accordingly
            saveState( message.sensor, Relays[message.sensor].relayState ); // save sensor state in EEPROM (location == sensor number)
      wait(20);
    SensebenderMicro sketch:
     * Version 1.0 - Thomas Bowman Mørch
     * Version 1.3 - Thomas Bowman Mørch
     * Improved transmission logic, eliminating spurious transmissions (when temperatuere / humidity fluctuates 1 up and down between measurements)
     * Added OTA boot mode, need to hold A1 low while applying power. (uses slightly more power as it's waiting for bootloader messages)
     * Version 1.4 - Thomas Bowman Mørch
     * Corrected division in the code deciding whether to transmit or not, that resulted in generating an integer. Now it's generating floats as expected.
     * Simplified detection for OTA bootloader, now detecting if MY_OTA_FIRMWARE_FEATURE is defined. If this is defined sensebender automaticly waits 300mS after each transmission
     * Moved Battery status messages, so they are transmitted together with normal sensor updates (but only every 60th minute)
    // Define a static node address, remove if you want auto address assignment
    #define MY_NODE_ID 17
    //#define MY_IS_RFM69HW
    //#define MY_RFM69_IRQ_PIN 2  // Default in lib is using D2 for common Atmel 328p (mini pro, nano, uno etc.). Uncomment it and set the pin you're using. Note for Atmel 328p, Mysensors, and regarding Arduino core implementation D2 or D3 are only available. But for advanced mcus like Atmel SAMD (Arduino Zero etc.), Esp8266 you will need to set this define for the corresponding pin used for IRQ
    //#define MY_RFM69_IRQ_NUM MY_RFM69_IRQ_PIN // Temporary define (will be removed in next radio driver revision). Needed if you want to change the IRQ pin your radio is connected. So, if your radio is connected to D3/INT1, value is 1 (INT1). For others mcu like Atmel SAMD, Esp8266, value is simply the same as your RF69_IRQ_PIN
    //#define MY_RFM69_SPI_CS 10 // If using a different CS pin for the SPI bus. Use MY_RFM69_CS_PIN for the development branch.
    // Enable to support OTA for this node (needs DualOptiBoot boot-loader to fully work)
    #include <SI7021.h>
    #ifndef MY_OTA_FIRMWARE_FEATURE
    #include "drivers/SPIFlash/SPIFlash.cpp"
    #include <EEPROM.h>
    #include <sha204_lib_return_codes.h>
    #include <sha204_library.h>
    #include <RunningAverage.h>
    //#include <avr/power.h>
    // Uncomment the line below, to transmit battery voltage as a normal sensor value
    //#define BATT_SENSOR    199
    #define RELEASE "1.4"
    #define AVERAGES 2
    // Child sensor ID's
    #define CHILD_ID_TEMP  1
    #define CHILD_ID_HUM   2
    // How many milli seconds should we wait for OTA?
    #define OTA_WAIT_PERIOD 300
    #define FORCE_TRANSMIT_INTERVAL 30
    #define HUMI_TRANSMIT_THRESHOLD 0.4
    #define TEMP_TRANSMIT_THRESHOLD 0.2
    // Pin definitions
    #define TEST_PIN       A0
    #define LED_PIN        A2
    #define ATSHA204_PIN   17 // A3
    const int sha204Pin = ATSHA204_PIN;
    SI7021 humiditySensor;
    SPIFlash flash(8, 0x1F65);
    // Sensor messages
    #ifdef BATT_SENSOR
    MyMessage msgBatt(BATT_SENSOR, V_VOLTAGE);
    // Global settings
    int measureCount = 0;
    int sendBattery = 0;
    boolean isMetric = true;
    boolean highfreq = true;
    boolean transmission_occured = false;
    float lastTemperature = -100;
    int lastHumidity = -100;
    long lastBattery = -100;
     * Setup code
      pinMode(LED_PIN, OUTPUT);
      digitalWrite(LED_PIN, LOW);
      Serial.print(RELEASE);
      Serial.flush();
      // First check if we should boot into test mode
      pinMode(TEST_PIN,INPUT);
      digitalWrite(TEST_PIN, HIGH); // Enable pullup
      if (!digitalRead(TEST_PIN)) testMode();
      // Make sure that ATSHA204 is not floating
      pinMode(ATSHA204_PIN, INPUT);
      digitalWrite(ATSHA204_PIN, HIGH);
      digitalWrite(TEST_PIN,LOW);
      digitalWrite(LED_PIN, HIGH);
      humiditySensor.begin();
      Serial.flush();
      isMetric = getControllerConfig().isMetric;
      Serial.print(F("isMetric: ")); Serial.println(isMetric);
      raHum.clear();
      sendTempHumidityMeasurements(false);
      sendBattLevel(false);
    #ifdef MY_OTA_FIRMWARE_FEATURE
      Serial.println("OTA FW update enabled");
    void presentation()  {
      sendSketchInfo("Sensebender Micro", RELEASE);
      present(CHILD_ID_TEMP,S_TEMP);
      present(CHILD_ID_HUM,S_HUM);
    #ifdef BATT_SENSOR
      present(BATT_SENSOR, S_POWER);
     *  Main loop function
      measureCount ++;
      sendBattery ++;
      bool forceTransmit = false;
        highfreq = false;
      if (measureCount > FORCE_TRANSMIT_INTERVAL) { // force a transmission
        forceTransmit = true;
        measureCount = 0;
    /*  if (sendBattery > 60)
         sendBattLevel(forceTransmit); // Not needed to send battery info that often
         sendBattery = 0;
      if (transmission_occured) {
          wait(OTA_WAIT_PERIOD);
      sleep(MEASURE_INTERVAL);
     * Sends temperature and humidity from Si7021 sensor
     * Parameters
    void sendTempHumidityMeasurements(bool force)
      bool tx = force;
      raHum.addValue(data.humidityPercent);
      float diffTemp = abs(lastTemperature - (isMetric ? data.celsiusHundredths : data.fahrenheitHundredths)/100.0);
      Serial.print(F("TempDiff :"));Serial.println(diffTemp);
      Serial.print(F("HumDiff  :"));Serial.println(diffHum);
      if (isnan(diffHum)) tx = true;
      if (diffTemp > TEMP_TRANSMIT_THRESHOLD) tx = true;
      if (diffHum > HUMI_TRANSMIT_THRESHOLD) tx = true;
      if (tx) {
        measureCount = 0;
        float temperature = (isMetric ? data.celsiusHundredths : data.fahrenheitHundredths) / 100.0;
        Serial.print("T: ");Serial.println(temperature);
        Serial.print("H: ");Serial.println(humidity);
        send(msgTemp.set(temperature,1));
        send(msgHum.set(humidity));
        lastHumidity = humidity;
        transmission_occured = true;
        if (sendBattery > 60) {
         sendBattLevel(true); // Not needed to send battery info that often
         sendBattery = 0;
     * Parameters
      if (force) lastBattery = -1;
      long vcc = readVcc();
      if (vcc != lastBattery) {
        lastBattery = vcc;
    #ifdef BATT_SENSOR
        float send_voltage = float(vcc)/1000.0f;
        send(msgBatt.set(send_voltage,3));
        // Calculate percentage
        long percent = vcc / 14.0;
        sendBatteryLevel(percent);
    long readVcc() {
     * Verify all peripherals, and signal via the LED if any problems.
    void testMode()
      uint8_t ret_code;
      byte tests = 0;
      digitalWrite(LED_PIN, HIGH); // Turn on LED.
      Serial.println(F(" - TestMode"));
      Serial.println(F("Testing peripherals!"));
      Serial.flush();
      Serial.print(F("-> SI7021 : "));
      Serial.flush();
      if (humiditySensor.begin())
        Serial.println(F("ok!"));
        tests ++;
        Serial.println(F("failed!"));
      Serial.flush();
      Serial.print(F("-> Flash : "));
      Serial.flush();
      if (flash.initialize())
        tests ++;
      Serial.flush();
      Serial.print(F("-> SHA204 : "));
      Serial.flush();
      if (ret_code != SHA204_SUCCESS)
        Serial.print(F("Failed to wake device. Response: ")); Serial.println(ret_code, HEX);
      Serial.flush();
      if (ret_code == SHA204_SUCCESS)
        ret_code = sha204.getSerialNumber(rx_buffer);
          Serial.print(F("Failed to obtain device serial number. Response: ")); Serial.println(ret_code, HEX);
          Serial.print(F("Ok (serial : "));
          for (int i=0; i<9; i++)
            if (rx_buffer[i] < 0x10)
            Serial.print(rx_buffer[i], HEX);
          Serial.println(")");
          tests ++;
      Serial.flush();
      Serial.println(F("Test finished"));
      if (tests == 3)
        Serial.println(F("Selftest ok!"));
        while (1) // Blink OK pattern!
          delay(200);
          delay(200);
        Serial.println(F("----> Selftest failed!"));
        while (1) // Blink FAILED pattern! Rappidly blinking..
    Debug log from GW:
    1346 MCO:BGN:STP
    2256 MCO:BGN:INIT OK,TSP=1
    900040 TSF:SAN:OK
    Debug log from Node:
     __  __       ____
            |___/                      2.2.0
    16 MCO:BGN:INIT NODE,CP=RPNNA---,VER=2.2.0
    26 TSM:INIT
    28 TSF:WUR:MS=0
    30 RFM69:INIT
    30 RFM69:INIT:PIN,CS=10,IQP=2,IQN=0
    36 RFM69:PTX:LEVEL=5 dBm
    38 TSM:INIT:TSP OK
    40 TSM:INIT:STATID=17
    43 TSF:SID:OK,ID=17
    45 TSM:FPAR
    47 RFM69:SWR:SEND,TO=255,RETRY=0
    53 TSF:MSG:SEND,17-17-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
    2062 !TSM:FPAR:NO REPLY
    2064 TSM:FPAR
    2066 RFM69:SWR:SEND,TO=255,RETRY=0
    2072 TSF:MSG:SEND,17-17-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
    4081 !TSM:FPAR:NO REPLY
    4083 TSM:FPAR
    4085 RFM69:SWR:SEND,TO=255,RETRY=0
    4091 TSF:MSG:SEND,17-17-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
    6103 !TSM:FPAR:NO REPLY
    6105 TSM:FPAR
    6107 RFM69:SWR:SEND,TO=255,RETRY=0
    6113 TSF:MSG:SEND,17-17-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
    8122 !TSM:FPAR:FAIL
    8124 TSM:FAIL:CNT=1
    8126 TSM:FAIL:DIS
    8128 TSF:TDI:TSL
    8128 RFM69:RSL
    18132 TSM:FAIL:RE-INIT
    18135 TSM:INIT
    18137 RFM69:INIT
    18139 RFM69:INIT:PIN,CS=10,IQP=2,IQN=0
    18143 RFM69:PTX:LEVEL=5 dBm
    18147 TSM:INIT:TSP OK
    18149 TSM:INIT:STATID=17
    18151 TSF:SID:OK,ID=17
    18153 TSM:FPAR
    18155 RFM69:SWR:SEND,TO=255,RETRY=0
    18163 TSF:MSG:SEND,17-17-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
    20172 !TSM:FPAR:NO REPLY
    20174 TSM:FPAR
    20176 RFM69:SWR:SEND,TO=255,RETRY=0
    20183 TSF:MSG:SEND,17-17-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
    22192 !TSM:FPAR:NO REPLY
    22194 TSM:FPAR
    22196 RFM69:SWR:SEND,TO=255,RETRY=0
    22202 TSF:MSG:SEND,17-17-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
    24211 !TSM:FPAR:NO REPLY
    24213 TSM:FPAR
    24215 RFM69:SWR:SEND,TO=255,RETRY=0
    24221 TSF:MSG:SEND,17-17-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
    26230 !TSM:FPAR:FAIL
    26232 TSM:FAIL:CNT=2
    26234 TSM:FAIL:DIS
    26236 TSF:TDI:TSL
    26238 RFM69:RSL
    36243 TSM:FAIL:RE-INIT
    36245 TSM:INIT
    36247 RFM69:INIT
    36249 RFM69:INIT:PIN,CS=10,IQP=2,IQN=0
    36253 RFM69:PTX:LEVEL=5 dBm
    36257 TSM:INIT:TSP OK
    36259 TSM:INIT:STATID=17
    36261 TSF:SID:OK,ID=17
    36263 TSM:FPAR
    36265 RFM69:SWR:SEND,TO=255,RETRY=0
    36274 TSF:MSG:SEND,17-17-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
    40302 !TSM:FPAR:NO REPLY
    40304 TSM:FPAR
    40306 RFM69:SWR:SEND,TO=255,RETRY=0
    40312 TSF:MSG:SEND,17-17-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
    42323 !TSM:FPAR:NO REPLY
    42326 TSM:FPAR
    42328 RFM69:SWR:SEND,TO=255,RETRY=0
    42334 TSF:MSG:SEND,17-17-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
    44343 !TSM:FPAR:FAIL
    44345 TSM:FAIL:CNT=3
    44347 TSM:FAIL:DIS
    44349 TSF:TDI:TSL
    44351 RFM69:RSL
    54355 TSM:FAIL:RE-INIT
    54358 TSM:INIT
    54360 RFM69:INIT
    54362 RFM69:INIT:PIN,CS=10,IQP=2,IQN=0
    54366 RFM69:PTX:LEVEL=5 dBm
    54370 TSM:INIT:TSP OK
    54372 TSM:INIT:STATID=17
    54374 TSF:SID:OK,ID=17
    54376 TSM:FPAR
    54378 RFM69:SWR:SEND,TO=255,RETRY=0
    54386 TSF:MSG:SEND,17-17-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
    56395 !TSM:FPAR:NO REPLY
    56397 TSM:FPAR
    56399 RFM69:SWR:SEND,TO=255,RETRY=0
    56406 TSF:MSG:SEND,17-17-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
    58415 !TSM:FPAR:NO REPLY
    58417 TSM:FPAR
    58419 RFM69:SWR:SEND,TO=255,RETRY=0
    58425 TSF:MSG:SEND,17-17-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
    60434 !TSM:FPAR:NO REPLY
    60436 TSM:FPAR
    60438 RFM69:SWR:SEND,TO=255,RETRY=0
    60444 TSF:MSG:SEND,17-17-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
    62453 !TSM:FPAR:FAIL
    62455 TSM:FAIL:CNT=4
    62457 TSM:FAIL:DIS
    62459 TSF:TDI:TSL
    62461 RFM69:RSL
    72466 TSM:FAIL:RE-INIT
    72468 TSM:INIT
    72470 RFM69:INIT
    72472 RFM69:INIT:PIN,CS=10,IQP=2,IQN=0
    72476 RFM69:PTX:LEVEL=5 dBm
    72480 TSM:INIT:TSP OK
    72482 TSM:INIT:STATID=17
    72484 TSF:SID:OK,ID=17
    72486 TSM:FPAR
    72488 RFM69:SWR:SEND,TO=255,RETRY=0
    72497 TSF:MSG:SEND,17-17-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
    74506 !TSM:FPAR:NO REPLY
    74508 TSM:FPAR
    74510 RFM69:SWR:SEND,TO=255,RETRY=0
    74516 TSF:MSG:SEND,17-17-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
    76525 !TSM:FPAR:NO REPLY
    76527 TSM:FPAR
    76529 RFM69:SWR:SEND,TO=255,RETRY=0
    76535 TSF:MSG:SEND,17-17-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
    78546 !TSM:FPAR:NO REPLY
    78548 TSM:FPAR
    78551 RFM69:SWR:SEND,TO=255,RETRY=0
    78557 TSF:MSG:SEND,17-17-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
    80566 !TSM:FPAR:FAIL
    80568 TSM:FAIL:CNT=5
    80570 TSM:FAIL:DIS
    80572 TSF:TDI:TSL
    80574 RFM69:RSL
    90578 TSM:FAIL:RE-INIT
    90580 TSM:INIT
    90583 RFM69:INIT
    90585 RFM69:INIT:PIN,CS=10,IQP=2,IQN=0
    90589 RFM69:PTX:LEVEL=5 dBm
    90593 TSM:INIT:TSP OK
    90595 TSM:INIT:STATID=17
    90597 TSF:SID:OK,ID=17
    90599 TSM:FPAR
    90601 RFM69:SWR:SEND,TO=255,RETRY=0
    90609 TSF:MSG:SEND,17-17-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
    92618 !TSM:FPAR:NO REPLY
    92620 TSM:FPAR
    92622 RFM69:SWR:SEND,TO=255,RETRY=0
    92653 TSF:MSG:SEND,17-17-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
    94662 !TSM:FPAR:NO REPLY
    94664 TSM:FPAR
    94666 RFM69:SWR:SEND,TO=255,RETRY=0
    94672 TSF:MSG:SEND,17-17-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
    96684 !TSM:FPAR:NO REPLY
    96686 TSM:FPAR
    96688 RFM69:SWR:SEND,TO=255,RETRY=0
    96694 TSF:MSG:SEND,17-17-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
    98703 !TSM:FPAR:FAIL
    98705 TSM:FAIL:CNT=6
    @scalz Is there some trick to use the NEW Driver since it works fine using the old?
    Using Arduino IDE 1.8.5
    Arduino AVR Boards 1.6.11
    MySensors AVR Boards 1.0.1
    Arduino SAMD Boards 1.6.17
    MySensors SAMD Boards 1.0.5
    MySensors Lib 2.2.0
    • Tomas
    • korttomaK
      korttomaK
      korttoma
      Tested with serial GW sketch on the SensebenderGW instead:
      GW log:
      0;255;3;0;9;670 RFM69:INIT
      0;255;3;0;9;685 RFM69:INIT:PIN,CS=30,IQP=32,IQN=32,RST=43
      0;255;3;0;9;695 RFM69:PTX:LEVEL=5 dBm
      0;255;0;0;18;2.2.0
      0;255;3;0;9;19524 RFM69:SWR:SEND,TO=17,RETRY=0
      0;255;3;0;9;19737 !RFM69:SWR:NACK
      0;255;3;0;9;19747 RFM69:SWR:SEND,TO=17,RETRY=1
      0;255;3;0;9;19767 RFM69:SWR:ACK,FROM=17,SEQ=1,RSSI=-61
      0;255;3;0;9;26296 RFM69:SWR:SEND,TO=17,RETRY=0
      0;255;3;0;9;26316 RFM69:SWR:ACK,FROM=17,SEQ=2,RSSI=-54
      0;255;3;0;9;27455 RFM69:SAC:SEND ACK,TO=17,RSSI=-60
      0;255;3;0;9;27472 RFM69:SWR:SEND,TO=17,RETRY=0
      0;255;3;0;9;27492 RFM69:SWR:ACK,FROM=17,SEQ=4,RSSI=-54
      0;255;3;0;9;27514 RFM69:SAC:SEND ACK,TO=17,RSSI=-60
      0;255;3;0;9;27526 RFM69:SWR:SEND,TO=17,RETRY=0
      0;255;3;0;9;27546 RFM69:SWR:ACK,FROM=17,SEQ=6,RSSI=-54
      0;255;3;0;9;27560 RFM69:SAC:SEND ACK,TO=17,RSSI=-60
      17;255;0;0;17;2.2.0
      0;255;3;0;9;27592 RFM69:SAC:SEND ACK,TO=17,RSSI=-60
      17;255;3;0;6;0
      0;255;3;0;9;29620 RFM69:SAC:SEND ACK,TO=17,RSSI=-61
      17;255;3;0;11;Sensebender Micro
      0;255;3;0;9;29654 RFM69:SAC:SEND ACK,TO=17,RSSI=-61
      17;255;3;0;12;1.4
      0;255;3;0;9;29686 RFM69:SAC:SEND ACK,TO=17,RSSI=-61
      17;1;0;0;6;
      0;255;3;0;9;29717 RFM69:SAC:SEND ACK,TO=17,RSSI=-60
      17;2;0;0;7;
      0;255;3;0;9;29750 RFM69:SAC:SEND ACK,TO=17,RSSI=-61
      0;255;3;0;9;29767 RFM69:SWR:SEND,TO=17,RETRY=0
      0;255;3;0;9;29787 RFM69:SWR:ACK,FROM=17,SEQ=14,RSSI=-54
      0;255;3;0;9;29831 RFM69:SAC:SEND ACK,TO=17,RSSI=-61
      17;1;1;0;0;28.1
      0;255;3;0;9;29863 RFM69:SAC:SEND ACK,TO=17,RSSI=-61
      17;2;1;0;1;25
      0;255;3;0;9;29897 RFM69:SAC:SEND ACK,TO=17,RSSI=-61
      17;255;3;0;0;101
      0;255;3;0;9;48872 RFM69:SWR:SEND,TO=17,RETRY=0
      0;255;3;0;9;48892 RFM69:SWR:ACK,FROM=17,SEQ=18,RSSI=-54
      0;255;3;0;9;50007 RFM69:SAC:SEND ACK,TO=17,RSSI=-61
      0;255;3;0;9;50024 RFM69:SWR:SEND,TO=17,RETRY=0
      0;255;3;0;9;50044 RFM69:SWR:ACK,FROM=17,SEQ=20,RSSI=-54
      0;255;3;0;9;50066 RFM69:SAC:SEND ACK,TO=17,RSSI=-61
      0;255;3;0;9;50078 RFM69:SWR:SEND,TO=17,RETRY=0
      0;255;3;0;9;50098 RFM69:SWR:ACK,FROM=17,SEQ=22,RSSI=-54
      0;255;3;0;9;50112 RFM69:SAC:SEND ACK,TO=17,RSSI=-61
      17;255;0;0;17;2.2.0
      0;255;3;0;9;50144 RFM69:SAC:SEND ACK,TO=17,RSSI=-61
      17;255;3;0;6;0
      0;255;3;0;9;52172 RFM69:SAC:SEND ACK,TO=17,RSSI=-61
      0;255;3;0;9;52206 RFM69:SAC:SEND ACK,TO=17,RSSI=-61
      17;255;3;0;12;1.4
      0;255;3;0;9;52238 RFM69:SAC:SEND ACK,TO=17,RSSI=-61
      17;1;0;0;6;
      0;255;3;0;9;52269 RFM69:SAC:SEND ACK,TO=17,RSSI=-61
      17;2;0;0;7;
      0;255;3;0;9;52302 RFM69:SAC:SEND ACK,TO=17,RSSI=-61
      0;255;3;0;9;52319 RFM69:SWR:SEND,TO=17,RETRY=0
      0;255;3;0;9;52532 !RFM69:SWR:NACK
      0;255;3;0;9;52574 RFM69:SWR:SEND,TO=17,RETRY=1
      0;255;3;0;9;52787 !RFM69:SWR:NACK
      0;255;3;0;9;52829 RFM69:SWR:SEND,TO=17,RETRY=2
      0;255;3;0;9;52849 RFM69:SWR:ACK,FROM=17,SEQ=30,RSSI=-54
      0;255;3;0;9;52893 RFM69:SAC:SEND ACK,TO=17,RSSI=-61
      17;1;1;0;0;28.1
      0;255;3;0;9;52925 RFM69:SAC:SEND ACK,TO=17,RSSI=-61
      17;2;1;0;1;23
      0;255;3;0;9;52959 RFM69:SAC:SEND ACK,TO=17,RSSI=-61
      17;255;3;0;0;101
      0;255;3;0;9;116786 RFM69:SAC:SEND ACK,TO=17,RSSI=-54
      17;1;1;0;0;27.6
      0;255;3;0;9;116818 RFM69:SAC:SEND ACK,TO=17,RSSI=-54
      17;2;1;0;1;16
      0;255;3;0;9;180582 RFM69:SAC:SEND ACK,TO=17,RSSI=-56
      17;1;1;0;0;27.5
      0;255;3;0;9;180614 RFM69:SAC:SEND ACK,TO=17,RSSI=-56
      17;2;1;0;1;10
      Node log:
      __  __       ____
              |___/                      2.2.0
      26 TSM:INIT
      28 TSF:WUR:MS=0
      30 RFM69:INIT
      38 TSM:INIT:TSP OK
      43 TSF:SID:OK,ID=17
      45 TSM:FPAR
      950 RFM69:SAC:SEND ACK,TO=0,RSSI=-54
      956 TSF:MSG:READ,0-0-17,s=255,c=3,t=8,pt=1,l=1,sg=0:0
      962 TSF:MSG:FPAR OK,ID=0,D=1
      2062 TSM:FPAR:OK
      2062 TSM:ID
      2064 TSM:ID:OK
      2066 TSM:UPL
      2068 RFM69:SWR:SEND,TO=0,RETRY=0
      2086 RFM69:SWR:ACK,FROM=0,SEQ=3,RSSI=-61
      2091 TSF:MSG:SEND,17-17-0-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=0,st=OK:1
      2105 RFM69:SAC:SEND ACK,TO=0,RSSI=-54
      2111 TSF:MSG:READ,0-0-17,s=255,c=3,t=25,pt=1,l=1,sg=0:1
      2117 TSF:MSG:PONG RECV,HP=1
      2121 TSM:UPL:OK
      2121 TSM:READY:ID=17,PAR=0,DIS=1
      2125 RFM69:SWR:SEND,TO=0,RETRY=0
      2146 RFM69:SWR:ACK,FROM=0,SEQ=5,RSSI=-61
      2150 TSF:MSG:SEND,17-17-0-0,s=255,c=3,t=15,pt=6,l=2,sg=0,ft=0,st=OK:0100
      2158 RFM69:SAC:SEND ACK,TO=0,RSSI=-54
      2166 TSF:MSG:READ,0-0-17,s=255,c=3,t=15,pt=6,l=2,sg=0:0100
      2172 RFM69:SWR:SEND,TO=0,RETRY=0
      2193 RFM69:SWR:ACK,FROM=0,SEQ=7,RSSI=-61
      2197 TSF:MSG:SEND,17-17-0-0,s=255,c=0,t=17,pt=0,l=5,sg=0,ft=0,st=OK:2.2.0
      2205 RFM69:SWR:SEND,TO=0,RETRY=0
      2224 RFM69:SWR:ACK,FROM=0,SEQ=8,RSSI=-61
      2228 TSF:MSG:SEND,17-17-0-0,s=255,c=3,t=6,pt=1,l=1,sg=0,ft=0,st=OK:0
      4237 RFM69:SWR:SEND,TO=0,RETRY=0
      4259 RFM69:SWR:ACK,FROM=0,SEQ=9,RSSI=-61
      4263 TSF:MSG:SEND,17-17-0-0,s=255,c=3,t=11,pt=0,l=17,sg=0,ft=0,st=OK:Sensebender Micro
      4272 RFM69:SWR:SEND,TO=0,RETRY=0
      4292 RFM69:SWR:ACK,FROM=0,SEQ=10,RSSI=-61
      4296 TSF:MSG:SEND,17-17-0-0,s=255,c=3,t=12,pt=0,l=3,sg=0,ft=0,st=OK:1.4
      4304 RFM69:SWR:SEND,TO=0,RETRY=0
      4325 RFM69:SWR:ACK,FROM=0,SEQ=11,RSSI=-61
      4329 TSF:MSG:SEND,17-17-0-0,s=1,c=0,t=6,pt=0,l=0,sg=0,ft=0,st=OK:
      4337 RFM69:SWR:SEND,TO=0,RETRY=0
      4356 RFM69:SWR:ACK,FROM=0,SEQ=12,RSSI=-61
      4360 TSF:MSG:SEND,17-17-0-0,s=2,c=0,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
      4368 MCO:REG:REQ
      4370 RFM69:SWR:SEND,TO=0,RETRY=0
      4388 RFM69:SWR:ACK,FROM=0,SEQ=13,RSSI=-61
      4395 TSF:MSG:SEND,17-17-0-0,s=255,c=3,t=26,pt=1,l=1,sg=0,ft=0,st=OK:2
      4919 RFM69:SAC:SEND ACK,TO=0,RSSI=-54
      4925 TSF:MSG:READ,0-0-17,s=255,c=3,t=27,pt=1,l=1,sg=0:1
      4931 MCO:PIM:NODE REG=1
      4933 MCO:BGN:STP
      Sensebender Micro FW 1.4 - Online!
      isMetric: 1
      TempDiff :128.10
      HumDiff  :123.00
      T: 28.10
      H: 23
      4962 RFM69:SWR:SEND,TO=0,RETRY=0
      4982 RFM69:SWR:ACK,FROM=0,SEQ=15,RSSI=-61
      4986 TSF:MSG:SEND,17-17-0-0,s=1,c=1,t=0,pt=7,l=5,sg=0,ft=0,st=OK:28.1
      4995 RFM69:SWR:SEND,TO=0,RETRY=0
      5015 RFM69:SWR:ACK,FROM=0,SEQ=16,RSSI=-61
      5019 TSF:MSG:SEND,17-17-0-0,s=2,c=1,t=1,pt=2,l=2,sg=0,ft=0,st=OK:23
      5029 RFM69:SWR:SEND,TO=0,RETRY=0
      5048 RFM69:SWR:ACK,FROM=0,SEQ=17,RSSI=-61
      5052 TSF:MSG:SEND,17-17-0-0,s=255,c=3,t=0,pt=1,l=1,sg=0,ft=0,st=OK:101
      5060 MCO:BGN:INIT OK,TSP=1
      TempDiff :0.05
      HumDiff  :0.00
      5083 MCO:SLP:MS=60000,SMS=0,I1=255,M1=255,I2=255,M2=255
      5091 TSF:TDI:TSL
      5091 RFM69:RSL
      5095 MCO:SLP:WUP=-1
      5097 TSF:TRI:TSB
      5099 RFM69:RSB
      TempDiff :0.51
      HumDiff  :3.50
      T: 27.59
      H: 16
      5122 RFM69:SWR:SEND,TO=0,RETRY=0
      5142 RFM69:SWR:ACK,FROM=0,SEQ=18,RSSI=-54
      5146 TSF:MSG:SEND,17-17-0-0,s=1,c=1,t=0,pt=7,l=5,sg=0,ft=0,st=OK:27.6
      5154 RFM69:SWR:SEND,TO=0,RETRY=0
      5175 RFM69:SWR:ACK,FROM=0,SEQ=19,RSSI=-54
      5179 TSF:MSG:SEND,17-17-0-0,s=2,c=1,t=1,pt=2,l=2,sg=0,ft=0,st=OK:16
      5187 MCO:SLP:MS=60000,SMS=0,I1=255,M1=255,I2=255,M2=255
      5193 TSF:TDI:TSL
      5193 RFM69:RSL
      5197 MCO:SLP:WUP=-1
      5199 TSF:TRI:TSB
      5201 RFM69:RSB
      TempDiff :0.08
      HumDiff  :3.00
      T: 27.51
      H: 10
      5224 RFM69:SWR:SEND,TO=0,RETRY=0
      5244 RFM69:SWR:ACK,FROM=0,SEQ=20,RSSI=-56
      5249 TSF:MSG:SEND,17-17-0-0,s=1,c=1,t=0,pt=7,l=5,sg=0,ft=0,st=OK:27.5
      5257 RFM69:SWR:SEND,TO=0,RETRY=0
      5277 RFM69:SWR:ACK,FROM=0,SEQ=21,RSSI=-56
      5281 TSF:MSG:SEND,17-17-0-0,s=2,c=1,t=1,pt=2,l=2,sg=0,ft=0,st=OK:10
      5289 MCO:SLP:MS=60000,SMS=0,I1=255,M1=255,I2=255,M2=255
      5296 TSF:TDI:TSL
      5296 RFM69:RSL
      5300 MCO:SLP:WUP=-1
      5302 TSF:TRI:TSB
      5304 RFM69:RSB
      TempDiff :0.11
      HumDiff  :0.00
      5324 MCO:SLP:MS=60000,SMS=0,I1=255,M1=255,I2=255,M2=255
      5330 TSF:TDI:TSL
      5332 RFM69:RSL
      Seems to work just fine so I guess there is something wrong with using the W5100/NEW_RFM69 GW code on the sensebender?
      Or did I make a mistake in the GW sketch that only affects the NEW RFM69 driver?
      • Tomas
        wrote on last edited by gohan
        I believe there are already other open topic about problems with W5100 and RFM69.
        Did you try commenting #define MY_RFM69_ATC_MODE_DISABLED ? While the node doesn't find parent, what do you seen on the GW log?
        korttomaK 1 Reply Last reply
          korttomaK
          korttomaK
          korttoma
          @gohan said in MY_RFM69_NEW_DRIVER, SensebenderGW, SensebenderMicro:
          W5100 and RFM69
          I do not believe that this is a W5100 and RFM69 issue since the old RFM69 driver works just fine.
          And yes I have also tried commenting the line you suggested. I believe that the issue is with running the new RFM69 driver on SAMD Board somehow.
          • Tomas
            @tekka , could it be a timing issue like I had on the raspberry?
            • korttomaK
              korttomaK
              korttoma
              Maybe @Anticimex has some thought about this? Did you try the RFM69/W5100 combination on the SensebenderGW with or without the "#define MY_RFM69_NEW_DRIVER"?
              • Tomas
              AnticimexA 1 Reply Last reply
              • korttomaK korttoma
                AnticimexA
                AnticimexA
                Anticimex
                @korttoma I have no RFM69 hardware and have not been involved in any driver development so I have absolutely no clue about this.
                • tekkaT
                  tekkaT
                  tekka
                  wrote on last edited by tekka
                  @korttoma @gohan Please try the lastest dev branch - I've rewritten the RFM69 driver with some major changes (in preparation of a new feature).
                  • tekkaT tekka
                    korttomaK
                    korttomaK
                    korttoma
                    @tekka updated the GW with the Dev branch Lib (2.2.1-alpha) and now it seems to be working! :D
                    update: Also updated the SensebenderMicro Node with the Dev branch Lib (2.2.1-alpha) and it is stil working :+1: thanks @tekka
                    • Tomas
