1.1k Posts 105 Posters 802.0k Views 98 Watching
  • petewillP petewill
    My son and I finally finished his first MySensors project- a remote control for his room. He wasn't too interested but you have to start somewhere right...? :)
    Question for you all... what are you doing (if anything) to vent the fumes from soldering? I haven't really been worried about it in the past but it makes me nervous with my son doing it with me.
    Anyway, here are the pictures.
    @petewill said in What did you build today (Pictures) ?:
    I have a Hakko 493 clone, it has a carbon filter to absorb the smoke (or most of it) so it doesn't smell too much in the room when I need to solder for a long time and I can't open the windows. I don't have a link because I bought it in my local shop (it was cheaper than AliExpress + shipping), but you can easily find similar models or clones of the FA400 by searching "smoke absorber" on AliExpress.
    petewillP 1 Reply Last reply
      @neverdie said in What did you build today (Pictures) ?:
      @mfalkvidd Didn't you play with electromagnets when you were a kid? At least try coiling the wire and maybe putting a metal core inside it. Use a lot of coils. The more the better. Then maybe your reed-type switch would have a chance of seeing enough magnetism to trigger it.
      Yes, but that would unfortunately completely defeat my purpose. The device should be easy to install (I can't expect the end-user to coil their cable) and work with cables that are designed for >10A which means they will be too thick to coil. I understand that I did not mention all aspects of the use case in my post though so thanks anyway.
      #408
      @mfalkvidd
      I had a similar requirement recently, which was determining when my CNC was finished. I decided to measure the current to decide that. It's 24VDC and might have a current as high as 6amp in a theoretical worst case, but as little as 0.5a when moving just one of the stepper motors. So, what I came up with was this, which I've tested and it works:
      Basically, it uses six 5-watt 3 ohm resistors in parallel to create a 1/2-ohm sense resistor, which an arduino then measures the voltage drop across by just doing an analog read from an analog GPIO pin across a voltage divider. I don't really know your use-case, but maybe you could adapt it for your application? You can ignore the LoRa module, which in my case I use to send out a signal to a remote receiver inside my house that the CNC print job (in the garage) is done.
      • sundberg84S
        sundberg84S
        #409
        I made a MysX template for anyone who wants to create a MysX board to any EasyPCB in KiCadd.
        Found here: https://github.com/sundberg84/HomeAutomation/tree/master/MysX template EasyPCB
        • Nca78N Nca78
          petewillP
          petewillP
          petewill
          @nca78 thanks! I'll check that out.
            Today I made and assembled a board which instantiates the schematic I posted above two days ago on this thread:
            Basically, it sends a wireless signal as soon as the CNC machine finishes its work.
            gohanG 1 Reply Last reply
              My old Yamaha YSP-1100 soundbar just decided to die.
              After some searching I found the problematic capacitor. A 22uF 600V had dropped to 6uF....
              1_1519064477580_20180219_191926.jpg !
                @hek How did you find the faulty capacitor?
                  @NeverDie, well, I started my trouble shooting with a lucky google search. For old devices like this, you are often not the first person experiencing a problem.
                    I had a good laugh when examining the other board. Is this a normal solution for remote-in?
                    YveauxY dbemowskD 2 Replies Last reply
                      @hek said in What did you build today (Pictures) ?:
                      DIY optocoupler?
                        dbemowskD
                        dbemowskD
                        @hek If this is for a sound bar, I know on some older stereos they had a remote signal out that you could tie into other components in the system. Maybe it's something like that.
                          @neverdie could you achieve something similar with a sonoff pow measuring the whole cnc power consumption?
                            #419
                            @gohan I don't know, as I'm not familiar with Sonoff, or how sensitive it is.
                              It's a WiFi power meter with a relay to turn off the load, so you could set a rule on controller that if measured power goes below a certain amount it will notify something
                                #421
                                It's a very good suggestion. If I wasn't already done, I'd try it. If it works, the Sonoff would be simpler and less effort.
                                • sundberg84S
                                  sundberg84S
                                  #422
                                  Another hour on my... whatever it is.
                                  Anyone that can recommend a open source router (hardware) or cheap hardware for pfsense which isn't that big and draws that watt amount.
                                    WHat do you need a PC for?
                                      sundberg84S
                                      sundberg84S
                                      #424
                                      @gohan it's a pc with my intention to run pfsense (open source router) but it is old and draws to much power for my taste.
                                      • E
                                        E
                                        executivul
                                        wrote on last edited by executivul
                                        #425
                                        How much power does that pc draw?
                                        Mine:
                                        Asrock Q1900B-ITX + pico 12V to atx psu + PCIE Intel Nic 2/4 Gbit ports + SSD can run on 20W or less, but I believe the J1900 Celeron lacks AES for VPN if you care about it.
                                        HP DL 380 G7 2xL5640 hex core, 144GB Ram, 4xGbit Nics, SSD, 90W at idle (99.9% of time) and pfsense is only one of the VMs I constantly run, besides OH2, Ubiquity controller, Nextcloud. The ability to snapshot a development VM, or fork (clone) it is a killer feature for me.
                                        Another DL 380 G7 in standby is drawing 15W.
                                        Phu*ck I have some old shitty switches that draw 30-40W, not to mention security cameras, 300-500Wh during the night for all my crazy home automation&security.
                                        • sundberg84S sundberg84
                                          @sundberg84 not cheap but 15W (at max load): https://www.aliexpress.com/item/Pfsense-Hardware-Qotom-Barebone-Mini-PC-Nano-itx-Core-i7-4500U-Fanless-Mini-Computer-X86-Router/32799048185.html
                                          Cheaper alternatives:
                                          https://www.aliexpress.com/store/product/2015-new-arrival-direct-selling-bay-trail-J1800-mini-pc-windows-8-1-Qotom-linux-2G/108231_32285025655.html max 10W
                                          https://www.netgate.com/solutions/pfsense/sg-1000.html 2.5W idle
