1.1k Posts 105 Posters 792.9k Views 98 Watching
    @petewill is it battery powered? Can you share the code?
    sundberg84S
    sundberg84S
    #397
    @petewill , @gohan I use the same as @mfalkvidd and its pretty much a PC fan with the wires to a 9v battery.... been thinking for a long time to make a more permanent sollution with a tubes from outside....
    • mfalkviddM
      #398
      Today's test was to see if the regular reed switches can be closed by the magnetic field created by a 1A current.
      I got an opportunity to try out my recently USB power meter and adjustable load.
      Since I am not sure how the reed switch is mounted inside the sensor, I tried different orientations but nothing triggered the sensor. I also tried 2A but that wasn't enough either.
      I need a non-invasive way to know if (how much) current is flowing in a DC cable. I was hoping the reed switch would be an easy way. My next hope is something like a SCT-013, unless someone has suggestions for other sensors. Requirements: 6-48V DC. 0.5-10A. I only need to know if the circuit is consuming >0.5A, no need for an exact measurement.
      gohanG NeverDieN 2 Replies Last reply
        @mfalkvidd Hall sensor?
          #400
          @gohan SCT-013 is a hall-based sensor I think. I was looking for more specific that just the type of sensor.
            @mfalkvidd said in What did you build today (Pictures) ?:
            No, it's only a current transformer, and you possibly need (at least) a burden resistor to measure the current. Ofcourse we already have a thread on it ;-)
            • YveauxY Yveaux
              @yveaux yes I've read that thread and I would choose one of the sct-013 variants that already contains a burden resistor.
                #403
                @mfalkvidd Didn't you play with electromagnets when you were a kid? At least try coiling the wire and maybe putting a metal core inside it. Use a lot of coils. The more the better. Then maybe your reed-type switch would have a chance of seeing enough magnetism to trigger it.
                gohanG mfalkviddM 2 Replies Last reply
                  @neverdie wouldn't that choke the current passing through the coil? He said he needs 6-48V DC. 0.5-10A
                  • petewillP
                    petewillP
                    petewill
                    wrote on last edited by petewill
                    #405
                    @NeverDie The wires are there in case I need to upload a new bootloader. This sensor one of the first ones I have done where the Arduino isn't easily removable and I wanted to try to make it a little easier in case I had to change it.
                    I used an original Prusa I3 MK2 to do the printing. This is in ABS (because I didn't have any white PLA) so the print is a little rougher than if it was done with PLA.
                    @dbemowsk Thanks! No, my son didn't help with the case design (yet). It was from a previous project that I slightly modified. My son is 6 so he doesn't really have the attention span to do too much yet. I'm hoping that doing little parts of a project will be fun for him and eventually turn into full projects. :)
                    @mfalkvidd & @sundberg84 Thanks. I guess I need to rig something up if he is going to be helping me more often...
                    @gohan No, it's not battery powered. I didn't want to have to deal with changing batteries and there is a power outlet right near the location he wanted it. Here is the code:
                      REVISION HISTORY
                      Version 1.0 - PeteWill
                    #define SKETCH_NAME "Controller"
                    #define SKETCH_VERSION "1.0"
                    //Child (sensor) name that will be sent to gateway
                    #define CONTROLLER_CHILD_NAME "Room Control"
                    #define MY_DEBUG //MySensors debug messages
                    #define LOCAL_DEBUG //Code specific debug messages
                    #define MY_RF24_PA_LEVEL RF24_PA_HIGH //Options: RF24_PA_MIN, RF24_PA_LOW, RF24_PA_HIGH, RF24_PA_MAX
                    #define MY_RF24_CHANNEL  76
                    #define MY_NODE_ID 1  //Manually set the node ID here. Comment out to auto assign
                    #define SCENE_CHILD_ID 0
                    #define BAUD_RATE 57600
                    #ifdef LOCAL_DEBUG
                    #define dbg(...)   Serial.print(__VA_ARGS__)
                    #define dbgln(...) Serial.println(__VA_ARGS__)
                    #define dbg(x)
                    #define dbgln(x)
                    //Button Pins -- Arduino Digital I/O pin button is connected to
                    #define BLIND_UP_PIN 5
                    #define BLIND_STOP_PIN 4
                    #define BLIND_DOWN_PIN 3
                    #define LIGHT_ON_PIN 8
                    #define LIGHT_OFF_PIN 7
                    #define EXTRA_BUTTON_PIN 6
                    #define LED_PIN A0 //Pin for the LED transistor
                    #define FLASH_TIME 300 //Amount of time to flash the LED (in milliseconds)
                    #define ARRAY_SIZE(x) (sizeof(x)/sizeof(x[0]))
                    uint8_t ledOn = 0;
                    uint32_t ledMillis; //Used for tracking the LED flash time
                    //The sceneNum array corresponds with the buttonPins array so if a button pin is read, it will send the scene number to the gateway
                    int sceneNum[] = {0, 1, 2, 3, 4, 5};
                    uint8_t buttonPins[] = {
                      BLIND_UP_PIN,
                      BLIND_STOP_PIN,
                      BLIND_DOWN_PIN,
                      LIGHT_ON_PIN,
                      LIGHT_OFF_PIN,
                      EXTRA_BUTTON_PIN
                    //Debouncer is used for the buttons.  Need to have the same number as the total buttons.
                    Bounce debouncer[] = {
                      Bounce(),
                      Bounce(),
                      Bounce(),
                      Bounce(),
                      Bounce(),
                      Bounce()
                    //used to keep track of previous values contact sensor values
                    uint8_t buttonPrev[] = {1, 1, 1, 1, 1, 1};
                    MyMessage scene(SCENE_CHILD_ID, V_SCENE_ON);
                    void before()
                    #ifdef LOCAL_DEBUG
                      Serial.begin(BAUD_RATE);
                      present(SCENE_CHILD_ID, S_SCENE_CONTROLLER, CONTROLLER_CHILD_NAME);
                      //Set up Pins
                      for (int i = 0; i < ARRAY_SIZE(buttonPins); i++) {
                        // Setup the pins
                        pinMode(buttonPins[i], INPUT_PULLUP);
                        debouncer[i].attach(buttonPins[i]);
                        debouncer[i].interval(100);
                        dbg(F("Set up contact Pin: "));
                        dbgln(buttonPins[i]);
                      pinMode(LED_PIN, OUTPUT);
                      uint32_t currentMillis = millis();
                        debouncer[i].update();
                        // Get the update value
                        uint8_t value = debouncer[i].read();
                        if (value != buttonPrev[i]) {
                          dbg(F("Value is for sensor #"));
                          dbg(buttonPins[i]);
                          dbg(F(" is "));
                          dbgln(value);
                          if (value == 0)
                            //Button is pressed send scene value
                            send(scene.set(sceneNum[i]));
                            ledOn = 1;
                            ledMillis = currentMillis;
                          buttonPrev[i] = value;
                      if (ledOn)
                        digitalWrite(LED_PIN, HIGH);
                        if (currentMillis - ledMillis > FLASH_TIME)
                          ledOn = 0;
                          digitalWrite(LED_PIN, LOW);
                      @neverdie said in What did you build today (Pictures) ?:
                      Yes, but that would unfortunately completely defeat my purpose. The device should be easy to install (I can't expect the end-user to coil their cable) and work with cables that are designed for >10A which means they will be too thick to coil. I understand that I did not mention all aspects of the use case in my post though so thanks anyway.
                      • petewillP petewill
                        My son and I finally finished his first MySensors project- a remote control for his room. He wasn't too interested but you have to start somewhere right...? :)
                        Question for you all... what are you doing (if anything) to vent the fumes from soldering? I haven't really been worried about it in the past but it makes me nervous with my son doing it with me.
                        Anyway, here are the pictures.
                        @petewill said in What did you build today (Pictures) ?:
                        I have a Hakko 493 clone, it has a carbon filter to absorb the smoke (or most of it) so it doesn't smell too much in the room when I need to solder for a long time and I can't open the windows. I don't have a link because I bought it in my local shop (it was cheaper than AliExpress + shipping), but you can easily find similar models or clones of the FA400 by searching "smoke absorber" on AliExpress.
                        petewillP 1 Reply Last reply
                          #408
                          @mfalkvidd
                          I had a similar requirement recently, which was determining when my CNC was finished. I decided to measure the current to decide that. It's 24VDC and might have a current as high as 6amp in a theoretical worst case, but as little as 0.5a when moving just one of the stepper motors. So, what I came up with was this, which I've tested and it works:
                          Basically, it uses six 5-watt 3 ohm resistors in parallel to create a 1/2-ohm sense resistor, which an arduino then measures the voltage drop across by just doing an analog read from an analog GPIO pin across a voltage divider. I don't really know your use-case, but maybe you could adapt it for your application? You can ignore the LoRa module, which in my case I use to send out a signal to a remote receiver inside my house that the CNC print job (in the garage) is done.
                          • sundberg84S
                            sundberg84S
                            #409
                            I made a MysX template for anyone who wants to create a MysX board to any EasyPCB in KiCadd.
                            Found here: https://github.com/sundberg84/HomeAutomation/tree/master/MysX template EasyPCB
                            • Nca78N Nca78
                              petewillP
                              petewillP
                              petewill
                              @nca78 thanks! I'll check that out.
                                Today I made and assembled a board which instantiates the schematic I posted above two days ago on this thread:
                                Basically, it sends a wireless signal as soon as the CNC machine finishes its work.
                                gohanG 1 Reply Last reply
                                  My old Yamaha YSP-1100 soundbar just decided to die.
                                  After some searching I found the problematic capacitor. A 22uF 600V had dropped to 6uF....
                                  1_1519064477580_20180219_191926.jpg !
                                    @hek How did you find the faulty capacitor?
                                      @NeverDie, well, I started my trouble shooting with a lucky google search. For old devices like this, you are often not the first person experiencing a problem.
                                        I had a good laugh when examining the other board. Is this a normal solution for remote-in?
                                        YveauxY dbemowskD 2 Replies Last reply
                                          @hek said in What did you build today (Pictures) ?:
                                          DIY optocoupler?
