1.1k Posts 105 Posters 792.9k Views 98 Watching
    @mfalkvidd Hall sensor?
    #400
    @gohan SCT-013 is a hall-based sensor I think. I was looking for more specific that just the type of sensor.
      @mfalkvidd said in What did you build today (Pictures) ?:
      No, it's only a current transformer, and you possibly need (at least) a burden resistor to measure the current. Ofcourse we already have a thread on it ;-)
      • YveauxY Yveaux
        @yveaux yes I've read that thread and I would choose one of the sct-013 variants that already contains a burden resistor.
          Today's test was to see if the regular reed switches can be closed by the magnetic field created by a 1A current.
          I got an opportunity to try out my recently USB power meter and adjustable load.
          Since I am not sure how the reed switch is mounted inside the sensor, I tried different orientations but nothing triggered the sensor. I also tried 2A but that wasn't enough either.
          I need a non-invasive way to know if (how much) current is flowing in a DC cable. I was hoping the reed switch would be an easy way. My next hope is something like a SCT-013, unless someone has suggestions for other sensors. Requirements: 6-48V DC. 0.5-10A. I only need to know if the circuit is consuming >0.5A, no need for an exact measurement.
          #403
          @mfalkvidd Didn't you play with electromagnets when you were a kid? At least try coiling the wire and maybe putting a metal core inside it. Use a lot of coils. The more the better. Then maybe your reed-type switch would have a chance of seeing enough magnetism to trigger it.
          gohanG mfalkviddM 2 Replies Last reply
            @neverdie wouldn't that choke the current passing through the coil? He said he needs 6-48V DC. 0.5-10A
            • petewillP
              petewillP
              petewill
              wrote on last edited by petewill
              #405
              @NeverDie The wires are there in case I need to upload a new bootloader. This sensor one of the first ones I have done where the Arduino isn't easily removable and I wanted to try to make it a little easier in case I had to change it.
              I used an original Prusa I3 MK2 to do the printing. This is in ABS (because I didn't have any white PLA) so the print is a little rougher than if it was done with PLA.
              @dbemowsk Thanks! No, my son didn't help with the case design (yet). It was from a previous project that I slightly modified. My son is 6 so he doesn't really have the attention span to do too much yet. I'm hoping that doing little parts of a project will be fun for him and eventually turn into full projects. :)
              @mfalkvidd & @sundberg84 Thanks. I guess I need to rig something up if he is going to be helping me more often...
              @gohan No, it's not battery powered. I didn't want to have to deal with changing batteries and there is a power outlet right near the location he wanted it. Here is the code:
                REVISION HISTORY
                Version 1.0 - PeteWill
              #define SKETCH_NAME "Controller"
              #define SKETCH_VERSION "1.0"
              //Child (sensor) name that will be sent to gateway
              #define CONTROLLER_CHILD_NAME "Room Control"
              #define MY_DEBUG //MySensors debug messages
              #define LOCAL_DEBUG //Code specific debug messages
              #define MY_RF24_PA_LEVEL RF24_PA_HIGH //Options: RF24_PA_MIN, RF24_PA_LOW, RF24_PA_HIGH, RF24_PA_MAX
              #define MY_RF24_CHANNEL  76
              #define MY_NODE_ID 1  //Manually set the node ID here. Comment out to auto assign
              #define SCENE_CHILD_ID 0
              #define BAUD_RATE 57600
              #ifdef LOCAL_DEBUG
              #define dbg(...)   Serial.print(__VA_ARGS__)
              #define dbgln(...) Serial.println(__VA_ARGS__)
              #define dbg(x)
              #define dbgln(x)
              //Button Pins -- Arduino Digital I/O pin button is connected to
              #define BLIND_UP_PIN 5
              #define BLIND_STOP_PIN 4
              #define BLIND_DOWN_PIN 3
              #define LIGHT_ON_PIN 8
              #define LIGHT_OFF_PIN 7
              #define EXTRA_BUTTON_PIN 6
              #define LED_PIN A0 //Pin for the LED transistor
              #define FLASH_TIME 300 //Amount of time to flash the LED (in milliseconds)
              #define ARRAY_SIZE(x) (sizeof(x)/sizeof(x[0]))
              uint8_t ledOn = 0;
              uint32_t ledMillis; //Used for tracking the LED flash time
              //The sceneNum array corresponds with the buttonPins array so if a button pin is read, it will send the scene number to the gateway
              int sceneNum[] = {0, 1, 2, 3, 4, 5};
              uint8_t buttonPins[] = {
                BLIND_UP_PIN,
                BLIND_STOP_PIN,
                BLIND_DOWN_PIN,
                LIGHT_ON_PIN,
                LIGHT_OFF_PIN,
                EXTRA_BUTTON_PIN
              //Debouncer is used for the buttons.  Need to have the same number as the total buttons.
              Bounce debouncer[] = {
                Bounce(),
                Bounce(),
                Bounce(),
                Bounce(),
                Bounce(),
                Bounce()
              //used to keep track of previous values contact sensor values
              uint8_t buttonPrev[] = {1, 1, 1, 1, 1, 1};
              MyMessage scene(SCENE_CHILD_ID, V_SCENE_ON);
              void before()
              #ifdef LOCAL_DEBUG
                Serial.begin(BAUD_RATE);
                present(SCENE_CHILD_ID, S_SCENE_CONTROLLER, CONTROLLER_CHILD_NAME);
                //Set up Pins
                for (int i = 0; i < ARRAY_SIZE(buttonPins); i++) {
                  // Setup the pins
                  pinMode(buttonPins[i], INPUT_PULLUP);
                  debouncer[i].attach(buttonPins[i]);
                  debouncer[i].interval(100);
                  dbg(F("Set up contact Pin: "));
                  dbgln(buttonPins[i]);
                pinMode(LED_PIN, OUTPUT);
                uint32_t currentMillis = millis();
                  debouncer[i].update();
                  // Get the update value
                  uint8_t value = debouncer[i].read();
                  if (value != buttonPrev[i]) {
                    dbg(F("Value is for sensor #"));
                    dbg(buttonPins[i]);
                    dbg(F(" is "));
                    dbgln(value);
                    if (value == 0)
                      //Button is pressed send scene value
                      send(scene.set(sceneNum[i]));
                      ledOn = 1;
                      ledMillis = currentMillis;
                    buttonPrev[i] = value;
                if (ledOn)
                  digitalWrite(LED_PIN, HIGH);
                  if (currentMillis - ledMillis > FLASH_TIME)
                    ledOn = 0;
                    digitalWrite(LED_PIN, LOW);
                @neverdie said in What did you build today (Pictures) ?:
                Yes, but that would unfortunately completely defeat my purpose. The device should be easy to install (I can't expect the end-user to coil their cable) and work with cables that are designed for >10A which means they will be too thick to coil. I understand that I did not mention all aspects of the use case in my post though so thanks anyway.
                • petewillP petewill
                  My son and I finally finished his first MySensors project- a remote control for his room. He wasn't too interested but you have to start somewhere right...? :)
                  Question for you all... what are you doing (if anything) to vent the fumes from soldering? I haven't really been worried about it in the past but it makes me nervous with my son doing it with me.
                  Anyway, here are the pictures.
                  @petewill said in What did you build today (Pictures) ?:
                  I have a Hakko 493 clone, it has a carbon filter to absorb the smoke (or most of it) so it doesn't smell too much in the room when I need to solder for a long time and I can't open the windows. I don't have a link because I bought it in my local shop (it was cheaper than AliExpress + shipping), but you can easily find similar models or clones of the FA400 by searching "smoke absorber" on AliExpress.
                  petewillP 1 Reply Last reply
                    #408
                    @mfalkvidd
                    I had a similar requirement recently, which was determining when my CNC was finished. I decided to measure the current to decide that. It's 24VDC and might have a current as high as 6amp in a theoretical worst case, but as little as 0.5a when moving just one of the stepper motors. So, what I came up with was this, which I've tested and it works:
                    Basically, it uses six 5-watt 3 ohm resistors in parallel to create a 1/2-ohm sense resistor, which an arduino then measures the voltage drop across by just doing an analog read from an analog GPIO pin across a voltage divider. I don't really know your use-case, but maybe you could adapt it for your application? You can ignore the LoRa module, which in my case I use to send out a signal to a remote receiver inside my house that the CNC print job (in the garage) is done.
                    • sundberg84S
                      sundberg84S
                      #409
                      I made a MysX template for anyone who wants to create a MysX board to any EasyPCB in KiCadd.
                      Found here: https://github.com/sundberg84/HomeAutomation/tree/master/MysX template EasyPCB
                      • Nca78N Nca78
                        petewillP
                        petewillP
                        petewill
                        @nca78 thanks! I'll check that out.
                          Today I made and assembled a board which instantiates the schematic I posted above two days ago on this thread:
                          Basically, it sends a wireless signal as soon as the CNC machine finishes its work.
                          gohanG 1 Reply Last reply
                            My old Yamaha YSP-1100 soundbar just decided to die.
                            After some searching I found the problematic capacitor. A 22uF 600V had dropped to 6uF....
                            1_1519064477580_20180219_191926.jpg !
                              @hek How did you find the faulty capacitor?
                                @NeverDie, well, I started my trouble shooting with a lucky google search. For old devices like this, you are often not the first person experiencing a problem.
                                  I had a good laugh when examining the other board. Is this a normal solution for remote-in?
                                  YveauxY dbemowskD 2 Replies Last reply
                                    @hek said in What did you build today (Pictures) ?:
                                    DIY optocoupler?
                                      dbemowskD
                                      dbemowskD
                                      @hek If this is for a sound bar, I know on some older stereos they had a remote signal out that you could tie into other components in the system. Maybe it's something like that.
                                        @neverdie could you achieve something similar with a sonoff pow measuring the whole cnc power consumption?
                                          #419
                                          @gohan I don't know, as I'm not familiar with Sonoff, or how sensitive it is.
