  3. nRF5 action!
nRF5 action!
1.9k Posts 49 Posters 2.1m Views 44 Watching
  • korttomaK korttoma
    I guess this is why I cant get LPCOMP to work on the device.
    Eight input options (AIN0 to AIN7)
    I would have to use the analog inputs because pin 28 is just a general purpose I/O pin.
    @korttoma using MySensors NRF5 boards you should be able to assign one AINx pin to physical pin 28.
    The index you need to put in the code is the AIN index not the pin number.
    korttomaK 1 Reply Last reply
    • Nca78N Nca78
      korttomaK
      korttomaK
      korttoma
      @nca78 sorry but I cannot figure out how to do this. Should I do it in the MyBoardNRF5.cpp, MyBoardNRF5.h or in the sketch?
      • Tomas
      Nca78N 1 Reply Last reply
        wrote on last edited by Nca78
        #1466
        @korttoma sorry I said stupid things as I'm a beginner too, you can't reassign analog inputs and LPCOMP to different pins on NRF5 chips.
        • Nca78N Nca78
          korttomaK
          korttomaK
          korttoma
          @nca78 it is ok, I think I will have to set up a test system with a different device with witch I can measure current consumption, attach serial logging and then try to fiddle with the code. I'm flying in the dark with this bluetooth beacon device since I cannot access any pins.
          • Tomas
            @toyman Correct. You can review the schematic for this project: https://www.openhardware.io/view/472/Ebyte-nRF52832-Prototyping-Board
            Toyman
            @neverdie thx. Why don't you have a capacitor between DEC4 to GND? I can see only 2 inductors, while Nordic power guidelines prescribe an LC filter between DCC and DEC, ie inductors and a capacitor. nrf52dk also has it.
            • T Toyman
              #1469
              @toyman I guess I made an error then. Thanks for pointing that out. In general, I haven't gotten much feedback on the PCB's that I've posted, so any feedback is always appreciated. :)
              O YveauxY 2 Replies Last reply
                O
                O
                Omemanti
                @neverdie Question is, did the DC/DC still work without the cap?
                • O Omemanti
                  #1471
                  @omemanti said in nRF5 Bluetooth action!:
                  I believe it did. If you look at: https://www.openhardware.io/view/471/Ebyte-nRF52832-Small-Breakout-Board
                  which has the inductors soldered on, I believe that is the one that I tested. Enough time has passed though that I can't be 100% sure now. I made a number of different variations, and I didn't post all of them.
                  O 1 Reply Last reply
                    O
                    O
                    Omemanti
                    wrote on last edited by Omemanti
                    #1472
                    @neverdie said in nRF5 Bluetooth action!:
                    I used your schematic for a PCB I ordered yesterday :), did saw the post about the cap until it was too late :(
                    part of the game!
                    Edit: according to your post https://forum.mysensors.org/topic/6961/nrf5-bluetooth-action/797 it did work
                    • Nca78N Nca78
                      @korttoma have you tried the code @NeverDie put together using the LPCOMP ? With a QFAAH0 (which I believe is the same version than QFABC0, but with 256K flash) he went down to something like 4µA.
                      From the document you link, anomaly 70, it will be necessary to add an extra wait of 36us after that line, it's strange that @NeverDie never had any problem with it. Or maybe I misunderstand the document :)
                      void activateLpComp() {
                      Test code from @NeverDie using LPCOMP is here:
                      https://forum.mysensors.org/topic/6961/nrf5-bluetooth-action/1307
                      I will try it on my board (using a module with QFAAH0) tomorrow, if power consumption is as low as expected I'll try on the beacon board.
                      [Edit] Just checked quickly my "beacon" board and it's using a QFAAH1 chip (made in 2017), so the test might not be relevant...
                      @nca78 said in nRF5 Bluetooth action!:
                      @NeverDie I have tried the sketch nearly unchanged (only changed to lines because I use pin P0.01 so AIN2) and my current consumption is a bit over 30uA, do you have any idea of what I should check ? (I tried with both versions 0.1 and 0.3 of MySensors NRF5 boards).
                      At the moment my board only has a led and a DRV5032FB (<<1uA) in addition to the nrf51 module.
                      NeverDieN Nca78N 2 Replies Last reply
                      • T
                        Toyman
                        Just to close the loop on DC-DC:
                        http://infocenter.nordicsemi.com/index.jsp?topic=%2Fcom.nordic.infocenter.nrf52832.ps.v1.1%2Fpower.html&anchor=concept
                        Figure 2
                        • Nca78N Nca78
                          Have you tried disabling serial?
                            Your code does it.
                              Unsure then.
                              • Nca78N Nca78
                                Ok, case closed, it was just because the SWD pins were still connected to my NRF52 DK. When I just connect VCC and GND it's down to something a bit below 5uA. I'm using a multimeter and DK is at 2.8V so real consumption will be a bit higher. But it should give me a battery life around 1year for my bedroom doors, so I'll just use my nrf51 modules for that and move to the more interesting nrf52.
                                • Nca78N Nca78
                                  korttomaK
                                  korttomaK
                                  korttoma
                                  @nca78 would you mind sharing your sketch files for your door sensors?
                                  As I'm not a programmer and not so good at programing I usually rely on example code to get anything done. More examples gives me more understanding how things should be done.
                                  • Tomas
                                    @korttoma sure I will when I make them next week, I just tested with LFCOMP script from neverdie at the moment.
                                      #1481
                                      I actually think you were correct in your design, @NeverDie ;-)
                                      A while ago part of the e73-2g4m04s schematic was posted on this forum:
                                      Clearly the inductors to use the DC/DC converter are not connected to DCC. There is however a capacitor C17 from DEC4 to GND.
                                      The Nordic reference schematic shows the missing L2 and L3, but capacitor C10 is actually present in the e73-2g4m04s (the mentioned C17, albeit only 100nF instead of 1.0uF in the reference):
                                      Therefore I think your breakout is correct, as only the inductors between DCC and DEC4 need to be added to match the reference schematic :+1:
                                      • YveauxY Yveaux
                                        @yveaux :)
                                          @Mika what is your experience regarding battery consumption on these?
                                          LINK
                                          I put together a sketch witch seems to work fine but one CR2032 just lasts a couple of days.
                                          Sketch:
                                          // Define a static node address, remove if you want auto address assignment
                                          //#define MY_NODE_ID 26                                                          // Kök
                                          #define MY_NODE_ID 27                                                          // Test device
                                          #define MY_RADIO_NRF5_ESB
                                          #define SN "NRF5 Scene"
                                          #define SV "1.0"
                                          #define CHILD_ID_SCENE 1
                                          // PIN for the buttons
                                          byte buttonOne = 28;
                                          //Bounce debouncer[NUMBUTTONS];
                                          int buttonOneoldValue;
                                          // Pin definitions
                                          #define DIGITAL_INPUT_INT 28   // The digital input you attached your interrupt  (Only 2 and 3 generates interrupt!)
                                          // Sensor messages
                                          MyMessage msgOn(CHILD_ID_SCENE, V_SCENE_ON);
                                          // Global settings
                                          uint16_t SceneOne = 0;
                                          uint16_t SceneTwo = 1;
                                          void blinkityBlink(uint8_t repetitions) {
                                              wait(20);
                                              wait(100);
                                              wait(20);
                                              if (x<(repetitions-1)) {  //skip waiting at the end of the final repetition
                                                wait(500);
                                           * Setup code
                                            blinkityBlink(2);  //signify power-up and start of operations
                                            hwPinMode(DIGITAL_INPUT_INT, INPUT_PULLUP);
                                              /// Make input & enable pull-up resistors on switch pins
                                            hwPinMode(buttonOne, INPUT_PULLUP);
                                            buttonOneoldValue = -1;
                                            sendBattLevel();
                                          void presentation()  {
                                            sendSketchInfo(SN, SV);
                                            //present the scene controller to gateway
                                            wait(10);
                                            present(CHILD_ID_SCENE, S_SCENE_CONTROLLER);
                                            wait(10);
                                           *  Main loop function
                                            // Check for button activity
                                            int value = digitalRead(buttonOne);
                                            if (value != buttonOneoldValue)
                                                // Send in the new value
                                                if (value == LOW)
                                                  send(msgOn.set(SceneOne));
                                                  wait(20);
                                                  send(msgOn.set(SceneTwo));
                                                  sendBattLevel();
                                                buttonOneoldValue = value;
                                            sleep(digitalPinToInterrupt(DIGITAL_INPUT_INT), CHANGE, 0);
                                           * Parameters
                                          void sendBattLevel()
                                              long vcc = hwCPUVoltage();
                                              // Calculate percentage
                                              vcc = vcc - 1800; // subtract 1.9V from vcc, as this is the lowest voltage we will operate at
                                              long percent = vcc / 14.0;
                                              sendBatteryLevel(percent);
                                          I noticed that the chip sais:
                                          N51822
                                          QFABC0
                                          1646UU
                                          QFAB translates to 16kB RAM, 128kB flash and I can not even select this option in the arduino IDE. Can this be the problem?
                                          @d00616 refer to his document for some high current consumption issue but I'm not sure what to do with the info.
                                          Is there something wrong with my sketch or is there just an old crappy chip on the device??
                                          @korttoma said in nRF5 Bluetooth action!:
                                          LINK
                                          N51822
                                          QFABC0
                                          1646UU
                                          So I tried your code with a more recent version of the chip and I have a power consumption around 1mA.
                                          This is not surprising because in fact issue 39 seems to not be completely fixed, if I believe this link:
                                          https://devzone.nordicsemi.com/f/nordic-q-a/577/current-consumption-when-using-rtc-ppi-and-gpiote#post-id-18533
                                          "The third revision hardware of the nRF51 has a solution for the GPIOTE OUT tasks, which has very low current consumption (<1uA). The third revision nRF51 hardware will be released in a few days. The third revision hardware still does not have a solution for the GPIOTE IN events, they still consume high current, so for low current applications, use the GPIOTE PORT event instead or the app_button libary."
                                          From what I see it was never fixed.
                                          korttomaK Nca78N 2 Replies Last reply
