  3. nRF5 action!
nRF5 action!
1.9k Posts 49 Posters 2.1m Views 44 Watching
    @toyman I guess I made an error then. Thanks for pointing that out. In general, I haven't gotten much feedback on the PCB's that I've posted, so any feedback is always appreciated. :)
    O
    O
    Omemanti
    @neverdie Question is, did the DC/DC still work without the cap?
    • O Omemanti
      #1471
      @omemanti said in nRF5 Bluetooth action!:
      I believe it did. If you look at: https://www.openhardware.io/view/471/Ebyte-nRF52832-Small-Breakout-Board
      which has the inductors soldered on, I believe that is the one that I tested. Enough time has passed though that I can't be 100% sure now. I made a number of different variations, and I didn't post all of them.
      O 1 Reply Last reply
        O
        O
        Omemanti
        wrote on last edited by Omemanti
        #1472
        @neverdie said in nRF5 Bluetooth action!:
        I used your schematic for a PCB I ordered yesterday :), did saw the post about the cap until it was too late :(
        part of the game!
        Edit: according to your post https://forum.mysensors.org/topic/6961/nrf5-bluetooth-action/797 it did work
        • Nca78N Nca78
          @korttoma have you tried the code @NeverDie put together using the LPCOMP ? With a QFAAH0 (which I believe is the same version than QFABC0, but with 256K flash) he went down to something like 4µA.
          From the document you link, anomaly 70, it will be necessary to add an extra wait of 36us after that line, it's strange that @NeverDie never had any problem with it. Or maybe I misunderstand the document :)
          void activateLpComp() {
          Test code from @NeverDie using LPCOMP is here:
          https://forum.mysensors.org/topic/6961/nrf5-bluetooth-action/1307
          I will try it on my board (using a module with QFAAH0) tomorrow, if power consumption is as low as expected I'll try on the beacon board.
          [Edit] Just checked quickly my "beacon" board and it's using a QFAAH1 chip (made in 2017), so the test might not be relevant...
          @nca78 said in nRF5 Bluetooth action!:
          @NeverDie I have tried the sketch nearly unchanged (only changed to lines because I use pin P0.01 so AIN2) and my current consumption is a bit over 30uA, do you have any idea of what I should check ? (I tried with both versions 0.1 and 0.3 of MySensors NRF5 boards).
          At the moment my board only has a led and a DRV5032FB (<<1uA) in addition to the nrf51 module.
          NeverDieN Nca78N 2 Replies Last reply
          • T
            Toyman
            Just to close the loop on DC-DC:
            http://infocenter.nordicsemi.com/index.jsp?topic=%2Fcom.nordic.infocenter.nrf52832.ps.v1.1%2Fpower.html&anchor=concept
            Figure 2
            • Nca78N Nca78
              Have you tried disabling serial?
              Nca78N 1 Reply Last reply
                Your code does it.
                  Unsure then.
                  • Nca78N Nca78
                    Ok, case closed, it was just because the SWD pins were still connected to my NRF52 DK. When I just connect VCC and GND it's down to something a bit below 5uA. I'm using a multimeter and DK is at 2.8V so real consumption will be a bit higher. But it should give me a battery life around 1year for my bedroom doors, so I'll just use my nrf51 modules for that and move to the more interesting nrf52.
                    korttomaK 1 Reply Last reply
                    • Nca78N Nca78
                      korttomaK
                      korttomaK
                      korttoma
                      @nca78 would you mind sharing your sketch files for your door sensors?
                      As I'm not a programmer and not so good at programing I usually rely on example code to get anything done. More examples gives me more understanding how things should be done.
                      • Tomas
                      • korttomaK korttoma
                        @korttoma sure I will when I make them next week, I just tested with LFCOMP script from neverdie at the moment.
                          #1481
                          I actually think you were correct in your design, @NeverDie ;-)
                          A while ago part of the e73-2g4m04s schematic was posted on this forum:
                          Clearly the inductors to use the DC/DC converter are not connected to DCC. There is however a capacitor C17 from DEC4 to GND.
                          The Nordic reference schematic shows the missing L2 and L3, but capacitor C10 is actually present in the e73-2g4m04s (the mentioned C17, albeit only 100nF instead of 1.0uF in the reference):
                          Therefore I think your breakout is correct, as only the inductors between DCC and DEC4 need to be added to match the reference schematic :+1:
                          • YveauxY Yveaux
                            @yveaux :)
                              @Mika what is your experience regarding battery consumption on these?
                              LINK
                              I put together a sketch witch seems to work fine but one CR2032 just lasts a couple of days.
                              Sketch:
                              // Define a static node address, remove if you want auto address assignment
                              //#define MY_NODE_ID 26                                                          // Kök
                              #define MY_NODE_ID 27                                                          // Test device
                              #define MY_RADIO_NRF5_ESB
                              #define SN "NRF5 Scene"
                              #define SV "1.0"
                              #define CHILD_ID_SCENE 1
                              // PIN for the buttons
                              byte buttonOne = 28;
                              //Bounce debouncer[NUMBUTTONS];
                              int buttonOneoldValue;
                              // Pin definitions
                              #define DIGITAL_INPUT_INT 28   // The digital input you attached your interrupt  (Only 2 and 3 generates interrupt!)
                              // Sensor messages
                              MyMessage msgOn(CHILD_ID_SCENE, V_SCENE_ON);
                              // Global settings
                              uint16_t SceneOne = 0;
                              uint16_t SceneTwo = 1;
                              void blinkityBlink(uint8_t repetitions) {
                                  wait(20);
                                  wait(100);
                                  wait(20);
                                  if (x<(repetitions-1)) {  //skip waiting at the end of the final repetition
                                    wait(500);
                               * Setup code
                                blinkityBlink(2);  //signify power-up and start of operations
                                hwPinMode(DIGITAL_INPUT_INT, INPUT_PULLUP);
                                  /// Make input & enable pull-up resistors on switch pins
                                hwPinMode(buttonOne, INPUT_PULLUP);
                                buttonOneoldValue = -1;
                                sendBattLevel();
                              void presentation()  {
                                sendSketchInfo(SN, SV);
                                //present the scene controller to gateway
                                wait(10);
                                present(CHILD_ID_SCENE, S_SCENE_CONTROLLER);
                                wait(10);
                               *  Main loop function
                                // Check for button activity
                                int value = digitalRead(buttonOne);
                                if (value != buttonOneoldValue)
                                    // Send in the new value
                                    if (value == LOW)
                                      send(msgOn.set(SceneOne));
                                      wait(20);
                                      send(msgOn.set(SceneTwo));
                                      sendBattLevel();
                                    buttonOneoldValue = value;
                                sleep(digitalPinToInterrupt(DIGITAL_INPUT_INT), CHANGE, 0);
                               * Parameters
                              void sendBattLevel()
                                  long vcc = hwCPUVoltage();
                                  // Calculate percentage
                                  vcc = vcc - 1800; // subtract 1.9V from vcc, as this is the lowest voltage we will operate at
                                  long percent = vcc / 14.0;
                                  sendBatteryLevel(percent);
                              I noticed that the chip sais:
                              N51822
                              QFABC0
                              1646UU
                              QFAB translates to 16kB RAM, 128kB flash and I can not even select this option in the arduino IDE. Can this be the problem?
                              @d00616 refer to his document for some high current consumption issue but I'm not sure what to do with the info.
                              Is there something wrong with my sketch or is there just an old crappy chip on the device??
                              @korttoma said in nRF5 Bluetooth action!:
                              LINK
                              N51822
                              QFABC0
                              1646UU
                              So I tried your code with a more recent version of the chip and I have a power consumption around 1mA.
                              This is not surprising because in fact issue 39 seems to not be completely fixed, if I believe this link:
                              https://devzone.nordicsemi.com/f/nordic-q-a/577/current-consumption-when-using-rtc-ppi-and-gpiote#post-id-18533
                              "The third revision hardware of the nRF51 has a solution for the GPIOTE OUT tasks, which has very low current consumption (<1uA). The third revision nRF51 hardware will be released in a few days. The third revision hardware still does not have a solution for the GPIOTE IN events, they still consume high current, so for low current applications, use the GPIOTE PORT event instead or the app_button libary."
                              From what I see it was never fixed.
                              korttomaK Nca78N 2 Replies Last reply
                                I'm seeing a special offer for this at 2€ with coupon https://www.aliexpress.com/item/nRF52832-2-4GHz-Wireless-rf-Module-CDSENET-E73-2G4M04S-SPI-SMD-rf-Receiver-transmitter-Bluetooth-Module/32819293925.html
                                Should i go ahead?
                                NeverDieN O 2 Replies Last reply
                                  Should i go ahead?
                                  @gohan Gee, I don't know. Can you really afford $2.55? ;)
                                    I don't know if it is a good one and I already have a bunch of stuff I bought still in the drawer :sweat_smile:
                                      @gohan For the price, it's good. I like Fanstel's better, but they have fewer exposed pins and cost more.
                                      • Nca78N Nca78
                                        LINK
                                        N51822
                                        QFABC0
                                        1646UU
                                        korttomaK
                                        korttomaK
                                        korttoma
                                        Thanks again for pointing out a possible solution but again I do not know how. I will just have to be patient and wait for someone to post an example of how to use one of the methods you mentioned.
                                        • Tomas
                                          smilvert
                                          I have started to test a NRF51822
                                          and I can upload to it with Arduino IDE but I want to use vim + platformio. And I think i'm quite close :)
                                          When I ran platformio upload --target upload
                                          GNU MCU Eclipse 64-bits Open On-Chip Debugger 0.10.0+dev-00392-gbe9ef0b0 (2018-01-12-14:56)
                                          Licensed under GNU GPL v2
                                          For bug reports, read
                                          0x4000
                                          adapter speed: 1000 kHz
                                          Info : Unable to match requested speed 1000 kHz, using 950 kHz
                                          Info : clock speed 950 kHz
                                          Info : using stlink api v2
                                          Info : Target voltage: 3.225841
                                          Info : nrf51.cpu: hardware has 4 breakpoints, 2 watchpoints
                                          Info : Listening on port 3333 for gdb connections
                                          xPSR: 0xc1000000 pc: 0x000021a4 msp: 0x20004000
                                          ** Programming Started **
                                          auto erase enabled
                                          Warn : Unknown device (HWID 0x000000d1)
                                          Warn : using fast async flash loader. This is currently supported
                                          Warn : only with ST-Link and CMSIS-DAP. If you have issues, add
                                          Warn : "set WORKAREASIZE 0" before sourcing nrf51.cfg/nrf52.cfg to disable it
                                          target halted due to breakpoint, current mode: Thread
                                          xPSR: 0x61000000 pc: 0x2000001e msp: 0x20004000
                                          wrote 33792 bytes from file .pioenvs/nrf51_dk/firmware.hex in 1.594509s (20.696 KiB/s)
                                          ** Programming Finished **
                                          ** Verify Started **
                                          xPSR: 0x61000000 pc: 0x2000002e msp: 0x20004000
                                          verified 32960 bytes in 0.236646s (136.015 KiB/s)
                                          ** Verified OK **
                                          ** Resetting Target **
                                          shutdown command invoked
                                          and the output in Arduino IDE looks like:
                                          Open On-Chip Debugger 0.10.0-dev-00254-g696fc0a (2016-04-09-12:07)
                                          debug_level: 0
                                          0x4000
                                          nrf51.cpu: target state: halted
                                          xPSR: 0xc1000000 pc: 0x0000251c msp: 0x20004000
                                          auto erase enabled
                                          wrote 31744 bytes from file /tmp/arduino_build_390477/Si7021_TemperatureNode_v007_voltage__version_7_board_.ino.hex in 1.500105s (20.665 KiB/s)
                                          verified 31580 bytes in 0.234860s (131.312 KiB/s)
                                          ** Verified OK **
                                          and my platfromio.ini looks like:
                                          [env:nrf51_dk]
                                          platform = nordicnrf51
                                          framework = arduino
                                          board = nrf51_dk
                                          upload_protocol = stlink
                                          Should I modify the nrf51_dk.cfg or can anyone see whats the problem is?
