  3. [solved] !TSM:FPAR:NO REPLY if using #define MY_RFM69_NEW_DRIVER
6 Posts 3 Posters 2.1k Views 3 Watching
  • alexsh1A Offline
    alexsh1A Offline
    alexsh1
    I am using Sensebender GW with RFM69HW and I have the following setting:
     * Version 1.0 - Henrik EKblad
     * LED purposes:
    //#define MY_RADIO_NRF24
    //#define MY_RADIO_NRF5_ESB
    #define MY_RADIO_RFM69
    //#define MY_RADIO_RFM95
    #define MY_RFM69_ATC_MODE_DISABLED
    #define MY_IS_RFM69HW
    #define MY_RFM69_FREQUENCY RFM69_868MHZ
    #define MY_RFM69_NETWORKID 99
    #define MY_DEBUG_VERBOSE_RFM69
    #define MY_GATEWAY_W5100
    //Signing
    #define MY_SIGNING_ATSHA204
    //#define MY_W5100_SPI_EN 4
    // radio on the same spi bus.
    #define MY_SOFTSPI
    #ifndef MY_RF24_CE_PIN
    #define MY_RF24_CE_PIN 5
    #ifndef MY_RF24_CS_PIN
    #define MY_RF24_CS_PIN 6
    // Enable UDP communication
    //#define MY_USE_UDP  // If using UDP you need to set MY_CONTROLLER_IP_ADDRESS below
    #define MY_IP_ADDRESS 10,1,1,130
    #define MY_PORT 5003
    #define MY_MAC_ADDRESS 0x90, 0xA2, 0xDA, 0x0E, 0xFC, 0xBD
    // Enable inclusion mode
    // Set blinking period
    // Flash leds on rx/tx/err
    #if defined(MY_USE_UDP)
    #include <EthernetUdp.h>
    #include <Ethernet.h>
    The same setting are for the sensor (rfm69W):
    //Signing
    uint32_t SLEEP_TIME = 900000;  // sleep time between reads (seconds * 1000 milliseconds)
    int oldBatteryPcnt = 0;
    	analogReference(INTERNAL1V1);
    	analogReference(INTERNAL);
    	sendSketchInfo("Battery Meter", "1.0");
    	// get the battery Voltage
    #ifdef MY_DEBUG
    	Serial.println(sensorValue);
    #ifdef MY_DEBUG
    	Serial.print(batteryV);
    	Serial.println(" V");
    	Serial.print(batteryPcnt);
    	Serial.println(" %");
    		// Power up radio after sleep
    		oldBatteryPcnt = batteryPcnt;
    	sleep(SLEEP_TIME);
    If I remove
    all works fine. Both the GW and the sensor are running MySensors v2.2.0, but tried v2.3.0-alpha with the same results sadly.
    Any idea what the problem may be please?
    • alexsh1A Offline
      alexsh1A Offline
      alexsh1
      Solved! The GW radio turned down to be non-H so I have to remove #define MY_IS_RFM69HW to work fine. In case of the old driver, GW and the sensor were tested on the same laptop, i.e. close to each other and hence they worked even with MY_IS_RFM69HW option.
      • alexsh1A alexsh1
        @alexsh1 great work, thanks for reporting back.
        alexsh1A 1 Reply Last reply
          alexsh1A Offline
          alexsh1A Offline
          alexsh1
          @mfalkvidd I have come across many times when RFM69 radio is soldered and it is very hard to tell specifics - H or non-H. I was 100% sure I had an H version :((
            If you look carefully the HW pcb you will notice 3 small 3 pins black components that are not present in the W version. That way it is easier to understand which is which
              alexsh1A Offline
              alexsh1A Offline
              alexsh1
              @gohan Yeah, after hours of troubleshooting there is always someone one learns :)))
              11.9k
              113.3k
