  3. nRF5 action!
nRF5 action!
1.9k Posts 49 Posters 2.1m Views 44 Watching
  • alowhumA
    alowhumA
    alowhum
    I turned a ST-Link v2 into a Black Magic Probe using this guide.
    The Black Magic Probe creates two virtual serial ports. One to program over, and another one. Can that second one be used to listen to Serial output from the NRF52? If so, how can that be set up?
    NeverDieN nagelcN 2 Replies Last reply
    • alowhumA alowhum
      @alowhum Doesn't answer your question, but I use just regular FTDI to listen to the serial output from the nRF5. So, there's always that for you to fall back on.
      • alowhumA alowhum
        nagelcN
        nagelcN
        nagelc
        @alowhum I'm using a BMP that I made from a STM32 Blue Pill. The Serial works just fine.
        Set a TX pin on your NRF5 in the MyBoardNFR5.h file. Connect it to the RX pin on your BMP. The default pins are TX (PA.2) and RX (PA.3). So if you connect PA.3 on your programmer to the TX pin you select on the NRF5, you should have what you need.
        To program, select the lower number serial port.
        To see serial output, select the higher number serial port for your serial monitor.
        • alowhumA
          alowhumA
          alowhum
          @nagelc I am using a ST-Link V2 that I turned into a BMP. So i don't have a RX pin on that. But I do have these pins left:
          • RST
          • SWIM
          So you suppose any of these two pins are now RX?
          nagelcN T 2 Replies Last reply
          • T Toyman
            @neverdie I was thinking about that, but that's not gonna work. Why? The bootloader that accepts OTA has a private key. The key in the software should match the key.
            #1555
            @toyman Looks like a DIY watch, using one of the very small nRF52 modules and a small OLED screen (or maybe ePaper?) would be fairly easy to design and put together.
            https://www.aliexpress.com/item/Free-shipping-Latest-Big-time-wearable-devices-DIY-electronic-watch-programmable-watch-FOR-ARDUINO/32309696848.html?spm=2114.search0104.3.43.6855283fBpRmHN&ws_ab_test=searchweb0_0,searchweb201602_5_10152_10065_10151_5711320_10344_10068_10130_10324_10342_10547_10325_10343_10546_10340_10341_10548_10698_10545_10697_10696_10084_5722520_10083_10618_10307_5711220_10059_5722620_5722920_308_5722720_5722820_100031_10103_441_10624_10623_10622_10621_10620-10152,searchweb201603_25,ppcSwitch_5&algo_expid=e4147df1-7362-4700-8575-4d5fa986cd9a-6&algo_pvid=e4147df1-7362-4700-8575-4d5fa986cd9a&transAbTest=ae803_1&priceBeautifyAB=0
            Making it aesthetically pleasing is probably much harder! Still, maybe a DIY bridge would tide you over until a more proper watch is available for conversion. Interestingly, it looks like they made their case from stacked pieces of laser cut acrylic.
            Unfortunately, theirs is impractically large:
            • alowhumA alowhum
              • RST
              • SWIM
              nagelcN
              nagelcN
              nagelc
              @alowhum Reset seems unlikely. Maybe SWIM. You could try it.
              If you can follow the trace back to the microprocessor, then you could figure out which pin it is. Then you could change to that pin in the BMP files, recompile, reload . . .. . Not sure it's worth all that experimentation when you can just use an FTDI as @NeverDie does.
                Is this an alternative programmer or is it STM32 only? https://www.aliexpress.com/store/product/CJMCU-JLINK-Support-for-SWD-s-JLINK-Simplified-Edition-Supports-STM32-SWD-Debugging-3-Wire/1245924_32792177272.html
                  @gohan J-Link is in the list of supported programmers at https://github.com/sandeepmistry/arduino-nRF5 so it should work
                  • alowhumA alowhum
                    • RST
                    • SWIM
                    Toyman
                    @alowhum just buy a real Blue Pill (around $2) and convert it into BMP.
                    Then you''ll get both a programmer and an USB-serial that you can use to get data from NRF52 UART
                    Nca78N 1 Reply Last reply
                    • T Toyman
                      @toyman said in nRF5 Bluetooth action!:
                      Thank you for this idea, I didn't receive my STM32 (got lost somewhere in transit) but I have 2 unused blue pills, I'll try that tomorrow.
                      "Conversion" process is easy to find: https://medium.com/@paramaggarwal/converting-an-stm32f103-board-to-a-black-magic-probe-c013cf2cc38c
                        #1561
                        Is the main (only?) advantage of the BMP that you have a single USB connection from your PC to your project instead of two (e.g. J-link plus an FTDI)? Or is there more to it that that?
                        • Nca78N Nca78
                          Toyman
                          @nca78 I used exactly this guide. Works like a charm.
                            Toyman
                            wrote on last edited by Toyman
                            #1563
                            @neverdie for us - yes. For other folks, I think the advantage is the number of targets it supports and the license. Equivalent Segger costs hundreds of $
                            BTW, Sandeep added BMP support into his core after I raised the issue :-)
                            • T
                              Toyman
                              • Nca78N Nca78
                                @korttoma said in nRF5 Bluetooth action!:
                                @nca78 still not getting anywhere with this. Would you mind ziping your sketch folder, then I should have all the correct files (right?). If I still have issues to compile I must be missing some library or are using the wrong version of something.
                                Sure, but unfortunately I cannot upload a zip file here, please send me your email by private message.
                                Ok here is a google drive link, it should be easier:
                                https://drive.google.com/open?id=1IhLIx0nHd5KZR9dJ9qA0-_SMGmjEpbKj
                                korttomaK
                                korttomaK
                                korttoma
                                @nca78 I have now measured the current consumption of the small bluetooth beacon device (N51822 QFABC0) using your code and the results are encouraging.
                                With your code I get around 4uA sleep current compared to 800-4000uA with my old code :D
                                Measurements done with an Micro (nano) ampere meter (double) that has not been calibrated against a reliable meter so do not take the measured values so seriously but more as a comparison.
                                Device
                                • Tomas
                                • korttomaK korttoma
                                  Device
                                  @korttoma I was going to ask you for some news. This is great news as it confirms the problem is solved even with older versions of the chip.
                                  Time to start work on a clean library...
                                  PS: I think you will have a reliable measurement with a simple multimeter, as the nrf51 by default is using an internal LDO, whether you feed it with 3.3V or (3.3V - burden voltage) in the end the chip will run at the same 1.8V voltage and use the same current. Of course it won't be the case if you have extra sensors on the board but it's not the case here.
                                  • Nca78N Nca78
                                    Toyman
                                    @nca78 BTW, HolyIoT makes a similar beacon but nrf52 based. Should be much more energy efficient. The price is about $7
                                    • Mars WarriorM
                                      Mars WarriorM
                                      Mars Warrior
                                      I see a lot of nice assembled PCB's on this forum, and just out of curiosity, but do you guys do your own SMT assembly?
                                      I looked at the PCBA options, but just a small batch of 10 PCB's starts somewhere around $140 excluding components.
                                      It would save me I think a lot of work, but on the other hand it feels expensive...
                                      My ebyte modules & STM32 programmers are on there way from AliExpress, so no problem in that area.
                                      • Mars WarriorM Mars Warrior
                                        Toyman
                                        @mars-warrior it depends on quantities of both PCBs and components on the PCBs.
                                        If you have lets say 10 pcbs with 20 components and potentially will have to do it again, the best bet is get a small oven (kitchen type) with PID regulator.
                                        If you just need 2-3 pcbs with 5-6 componets, hot air gun is your choice.
                                        In my current project, I solder ebyte module by hand (very easy) and then LED, resisttors and capacitors with hot air and solder paste.
                                        Looks pretty neat.
                                        Mars WarriorM 1 Reply Last reply
                                        • T Toyman
                                          Looks pretty neat.
                                          Mars WarriorM
                                          Mars WarriorM
                                          Mars Warrior
                                          @toyman Thanx for that info!
                                          Never worked (yet) with a hot air station/pencil.
                                          Found some reviews here: https://wiki.ezvid.com/best-soldering-stations. Both the Kendal 853D and the Ayyue 968+ are stations I can afford to buy. I assume the cheaper ones ($50) are the ones to avoid...
                                          Looking at some youtube vids about this subject, it seems doable, even for a novice like me ;-)
                                          Of course, any recomendations about hot air stations are appreciated!
