  3. nRF5 action!
nRF5 action!
1.9k Posts 49 Posters 1.9m Views 44 Watching
  • alowhumA alowhum
    @nagelc I am using a ST-Link V2 that I turned into a BMP. So i don't have a RX pin on that. But I do have these pins left:
    • RST
    • SWIM
    So you suppose any of these two pins are now RX?
    nagelcN
    nagelcN
    nagelc
    @alowhum Reset seems unlikely. Maybe SWIM. You could try it.
    If you can follow the trace back to the microprocessor, then you could figure out which pin it is. Then you could change to that pin in the BMP files, recompile, reload . . .. . Not sure it's worth all that experimentation when you can just use an FTDI as @NeverDie does.
      Is this an alternative programmer or is it STM32 only? https://www.aliexpress.com/store/product/CJMCU-JLINK-Support-for-SWD-s-JLINK-Simplified-Edition-Supports-STM32-SWD-Debugging-3-Wire/1245924_32792177272.html
        @gohan J-Link is in the list of supported programmers at https://github.com/sandeepmistry/arduino-nRF5 so it should work
        • alowhumA alowhum
          • RST
          • SWIM
          Toyman
          @alowhum just buy a real Blue Pill (around $2) and convert it into BMP.
          Then you''ll get both a programmer and an USB-serial that you can use to get data from NRF52 UART
          Nca78N 1 Reply Last reply
          • T Toyman
            @toyman said in nRF5 Bluetooth action!:
            Thank you for this idea, I didn't receive my STM32 (got lost somewhere in transit) but I have 2 unused blue pills, I'll try that tomorrow.
            "Conversion" process is easy to find: https://medium.com/@paramaggarwal/converting-an-stm32f103-board-to-a-black-magic-probe-c013cf2cc38c
              #1561
              Is the main (only?) advantage of the BMP that you have a single USB connection from your PC to your project instead of two (e.g. J-link plus an FTDI)? Or is there more to it that that?
              • Nca78N Nca78
                Toyman
                @nca78 I used exactly this guide. Works like a charm.
                  Toyman
                  wrote on last edited by Toyman
                  #1563
                  @neverdie for us - yes. For other folks, I think the advantage is the number of targets it supports and the license. Equivalent Segger costs hundreds of $
                  BTW, Sandeep added BMP support into his core after I raised the issue :-)
                  • T
                    Toyman
                    • Nca78N Nca78
                      @korttoma said in nRF5 Bluetooth action!:
                      @nca78 still not getting anywhere with this. Would you mind ziping your sketch folder, then I should have all the correct files (right?). If I still have issues to compile I must be missing some library or are using the wrong version of something.
                      Sure, but unfortunately I cannot upload a zip file here, please send me your email by private message.
                      Ok here is a google drive link, it should be easier:
                      https://drive.google.com/open?id=1IhLIx0nHd5KZR9dJ9qA0-_SMGmjEpbKj
                      korttomaK
                      korttomaK
                      korttoma
                      @nca78 I have now measured the current consumption of the small bluetooth beacon device (N51822 QFABC0) using your code and the results are encouraging.
                      With your code I get around 4uA sleep current compared to 800-4000uA with my old code :D
                      Measurements done with an Micro (nano) ampere meter (double) that has not been calibrated against a reliable meter so do not take the measured values so seriously but more as a comparison.
                      Device
                      • Tomas
                      • korttomaK korttoma
                        Device
                        @korttoma I was going to ask you for some news. This is great news as it confirms the problem is solved even with older versions of the chip.
                        Time to start work on a clean library...
                        PS: I think you will have a reliable measurement with a simple multimeter, as the nrf51 by default is using an internal LDO, whether you feed it with 3.3V or (3.3V - burden voltage) in the end the chip will run at the same 1.8V voltage and use the same current. Of course it won't be the case if you have extra sensors on the board but it's not the case here.
                        • Nca78N Nca78
                          Toyman
                          @nca78 BTW, HolyIoT makes a similar beacon but nrf52 based. Should be much more energy efficient. The price is about $7
                          • Mars WarriorM
                            Mars WarriorM
                            Mars Warrior
                            I see a lot of nice assembled PCB's on this forum, and just out of curiosity, but do you guys do your own SMT assembly?
                            I looked at the PCBA options, but just a small batch of 10 PCB's starts somewhere around $140 excluding components.
                            It would save me I think a lot of work, but on the other hand it feels expensive...
                            My ebyte modules & STM32 programmers are on there way from AliExpress, so no problem in that area.
                            T 2 Replies Last reply
                            • Mars WarriorM Mars Warrior
                              Toyman
                              @mars-warrior it depends on quantities of both PCBs and components on the PCBs.
                              If you have lets say 10 pcbs with 20 components and potentially will have to do it again, the best bet is get a small oven (kitchen type) with PID regulator.
                              If you just need 2-3 pcbs with 5-6 componets, hot air gun is your choice.
                              In my current project, I solder ebyte module by hand (very easy) and then LED, resisttors and capacitors with hot air and solder paste.
                              Looks pretty neat.
                              Mars WarriorM 1 Reply Last reply
                              • T Toyman
                                Looks pretty neat.
                                Mars WarriorM
                                Mars WarriorM
                                Mars Warrior
                                @toyman Thanx for that info!
                                Never worked (yet) with a hot air station/pencil.
                                Found some reviews here: https://wiki.ezvid.com/best-soldering-stations. Both the Kendal 853D and the Ayyue 968+ are stations I can afford to buy. I assume the cheaper ones ($50) are the ones to avoid...
                                Looking at some youtube vids about this subject, it seems doable, even for a novice like me ;-)
                                Of course, any recomendations about hot air stations are appreciated!
                                  Toyman
                                  @mars-warrior
                                  something like this:
                                  https://store.reflowster.com/products/reflowster
                                    140$ it is quite expensive compared with a simple small oven
                                    https://www.youtube.com/watch?v=mjfnpjvw9jY
                                      Toyman
                                      @gohan I am not telling you to buy this. Just a direction.
                                      I've created a PID sous vide machine. It's relatively easy project. SMD oven is absolutely the same. All you need is Arduino, thermoprobe and a relay.
                                      • alowhumA
                                        alowhumA
                                        alowhum
                                        Quick question: when programming the eByte module (or any module really):
                                        Should I select "reset enable or not? What does that do exactly?
                                        Should I select clock: "Crystal oscillator" for the eByte module?
                                        • alowhumA alowhum
                                          @alowhum "Reset enable" determines whether pin21 acts as a reset pin or not.
