  3. nRF5 action!
nRF5 action!
  • T
    Toyman
    • Nca78N Nca78
      @korttoma said in nRF5 Bluetooth action!:
      @nca78 still not getting anywhere with this. Would you mind ziping your sketch folder, then I should have all the correct files (right?). If I still have issues to compile I must be missing some library or are using the wrong version of something.
      Sure, but unfortunately I cannot upload a zip file here, please send me your email by private message.
      Ok here is a google drive link, it should be easier:
      https://drive.google.com/open?id=1IhLIx0nHd5KZR9dJ9qA0-_SMGmjEpbKj
      korttomaK
      korttomaK
      korttoma
      @nca78 I have now measured the current consumption of the small bluetooth beacon device (N51822 QFABC0) using your code and the results are encouraging.
      With your code I get around 4uA sleep current compared to 800-4000uA with my old code :D
      Measurements done with an Micro (nano) ampere meter (double) that has not been calibrated against a reliable meter so do not take the measured values so seriously but more as a comparison.
      Device
      • Tomas
      Nca78N 1 Reply Last reply
      • korttomaK korttoma
        Device
        @korttoma I was going to ask you for some news. This is great news as it confirms the problem is solved even with older versions of the chip.
        Time to start work on a clean library...
        PS: I think you will have a reliable measurement with a simple multimeter, as the nrf51 by default is using an internal LDO, whether you feed it with 3.3V or (3.3V - burden voltage) in the end the chip will run at the same 1.8V voltage and use the same current. Of course it won't be the case if you have extra sensors on the board but it's not the case here.
        • Nca78N Nca78
          Toyman
          @nca78 BTW, HolyIoT makes a similar beacon but nrf52 based. Should be much more energy efficient. The price is about $7
          • Mars WarriorM
            Mars WarriorM
            Mars Warrior
            I see a lot of nice assembled PCB's on this forum, and just out of curiosity, but do you guys do your own SMT assembly?
            I looked at the PCBA options, but just a small batch of 10 PCB's starts somewhere around $140 excluding components.
            It would save me I think a lot of work, but on the other hand it feels expensive...
            My ebyte modules & STM32 programmers are on there way from AliExpress, so no problem in that area.
            T 2 Replies Last reply
            • Mars WarriorM Mars Warrior
              Toyman
              @mars-warrior it depends on quantities of both PCBs and components on the PCBs.
              If you have lets say 10 pcbs with 20 components and potentially will have to do it again, the best bet is get a small oven (kitchen type) with PID regulator.
              If you just need 2-3 pcbs with 5-6 componets, hot air gun is your choice.
              In my current project, I solder ebyte module by hand (very easy) and then LED, resisttors and capacitors with hot air and solder paste.
              Looks pretty neat.
              Mars WarriorM 1 Reply Last reply
              • T Toyman
                Looks pretty neat.
                Mars WarriorM
                Mars WarriorM
                Mars Warrior
                @toyman Thanx for that info!
                Never worked (yet) with a hot air station/pencil.
                Found some reviews here: https://wiki.ezvid.com/best-soldering-stations. Both the Kendal 853D and the Ayyue 968+ are stations I can afford to buy. I assume the cheaper ones ($50) are the ones to avoid...
                Looking at some youtube vids about this subject, it seems doable, even for a novice like me ;-)
                Of course, any recomendations about hot air stations are appreciated!
                  Toyman
                  @mars-warrior
                  something like this:
                  https://store.reflowster.com/products/reflowster
                    140$ it is quite expensive compared with a simple small oven
                    https://www.youtube.com/watch?v=mjfnpjvw9jY
                      Toyman
                      @gohan I am not telling you to buy this. Just a direction.
                      I've created a PID sous vide machine. It's relatively easy project. SMD oven is absolutely the same. All you need is Arduino, thermoprobe and a relay.
                      • alowhumA
                        alowhumA
                        alowhum
                        Quick question: when programming the eByte module (or any module really):
                        Should I select "reset enable or not? What does that do exactly?
                        Should I select clock: "Crystal oscillator" for the eByte module?
                        • alowhumA alowhum
                          @alowhum "Reset enable" determines whether pin21 acts as a reset pin or not.
                          • alowhumA alowhum
                            #1576
                            @alowhum IIRC, the crystal oscillator is only required by Bluetooth. For everything else, the internal resonator is sufficient.
                            S 1 Reply Last reply
                            • alowhumA
                              alowhumA
                              alowhum
                              I received two new eByte modules. I can't even connect to either one, both with BMP or ST-Link V2. Very strange. I'm going to try not powering them from the USB stick but from a second 3.3v source.
                              • alowhumA alowhum
                                Toyman
                                @alowhum did you manage to flash them?
                                • alowhumA
                                  alowhumA
                                  alowhum
                                  #1579
                                  @toyman No. I don't understand what's going on, as I was able to flash one succesfully before. I did find [this a bit unnerving].(https://devzone.nordicsemi.com/f/nordic-q-a/19943/nrf52832-unable-to-connect-to-the-target).
                                  Could it be that the EByte chips need the DCDC stuff before they can be connected to? Or that the exact moment on power-on (reset) matters?
                                  One thing I have found is that I had installed OpenOCD on my laptop to turn a ST-Link V2 into a Black Magic Probe. That version of OpenOCD was overruling the hacked version that Sandeep Mistry had created for the NRF5.
                                  But even with that removed, the problem remains this:
                                  "TARGET: nrf52.cpu - Not halted".
                                  Apparently this is a sign that the chips are protected. I was able to remove that protection before (by selecting "Burn Bootloader"), but it doesn't work now.
                                  • T Toyman
                                    #1580
                                    @alowhum said in nRF5 Bluetooth action!:
                                    No.
                                    • alowhumA alowhum
                                      @alowhum have you tried the menu item to write softdevice ? If I remember well it will unlock the chip and after that you will be allowed to write code to it.
                                      • O
                                        O
                                        Omemanti
                                        wrote on last edited by Omemanti
                                        #1582
                                        Hey,
                                        somehow I cant change the pins on my Ebyte module. Im trying to test with MockMysensors.
                                        I want te TX set to pin nr. P0.06
                                        I changed: MyBoardNRF.h and included nrf.h
                                        #define PIN_SERIAL_RX (8)
                                        #define PIN_SERIAL_TX (6)
                                        but somehow the TX pin stays P0.25.
                                        Can someone point me in the right direction?
                                        The node connects to the gateway, so thats also working.
                                        Seems like that if you put the MyBoardNRF5 files into the example map and you change some things in that file using the Arduino IDE, it doenst get uploaded. When I changed the MyBoardNRF5 file using Brackets it working as intended.
                                        • alowhumA
                                          alowhumA
                                          alowhum
                                          @Nca78 Thanks, but it didn't work either :-(
                                          Some notes from my adventures with the eByte module:
                                          I've been playing with OpenOCD and the ST-Link v2. The ST-Link V2 that I turned into a Black Magic Probe doesn't see the modules.
                                          I went into the Arduino's folder that has OpenOCD, created .cfg file, and then:
                                          ./openocd -d2 -f nrf52832.cfg
                                          This started the OpenOCD server. Then I opened another terminal window and did
                                          telnet localhost 4444
                                          Now I could manually issue some OpenOCD commands. The goal was to do a manual mass erase.
                                          Some OpenOCD commands and their output:
                                          flash probe 0        c Unknown device (HWID 0x00000000)
                                          > flash banks
                                          #0 : nrf52.flash (nrf51) at 0x00000000, size 0x00000000, buswidth 1, chipwidth 1
                                          #1 : nrf52.uicr (nrf51) at 0x10001000, size 0x00000000, buswidth 1, chipwidth 1
                                          > flash probe 1
                                          flash 'nrf51' found at 0x10001000
                                          > nrf51 mass_erase 0
                                          Target not halted
                                          This command actually resulted in OpenOCD ballooning to 8Gb in ram. Then after 5 minutes of seemingly being busy, I got the 'target not halted' command.
                                          > flash info 1
                                          #1 : nrf51 at 0x10001000, size 0x00000100, buswidth 1, chipwidth 1
                                          	#  0: 0x00000000 (0x100 0kB) not protected
                                          Target not halted
                                          error retrieving flash info
                                          Here is says "target not protected".
                                          > nrf52.cpu curstate
                                          reset
                                          Weird: the processor says it is in reset state? Could it be that it is not so much protected, but that it is constantly being reset? But then why is this with all the chips?
                                          Once the OpenOCD server is running I also tried getting into the chip with
                                          telnet localhost 3333
                                          But then I get "Error: attempted 'gdb' connection rejected"
                                          The OpenOCD documentation mentions the chip protection:
                                          Flash Driver: nrf5
                                          All members of the nRF51 microcontroller families from Nordic Semiconductor include internal flash and use ARM Cortex-M0 core. Also, the nRF52832 microcontroller from Nordic Semiconductor, which include internal flash and use an ARM Cortex-M4F core.
                                          flash bank $_FLASHNAME nrf5 0 0x00000000 0 0 $_TARGETNAME
                                          Some nrf5-specific commands are defined:
                                          Command: nrf5 mass_erase
                                          Erases the contents of the code memory and user information configuration registers as well. It must be noted that this command works only for chips that do not have factory pre-programmed region 0 code.
                                          http://www.openocd.org/doc/html/Flash-Commands.html
                                          I also got out my voltmeter. Pin 21 and pin 25 have 3v on them, the rest don't.
                                          YveauxY T M 3 Replies Last reply
