1.1k Posts 105 Posters 792.9k Views 98 Watching
  • GertSandersG
    GertSandersG
    GertSanders
    So here is my contribution to this tread: a differential drive "brain". A work in progress:
    • dbemowskD
      dbemowskD
      Finally finished my 2.2.0 gateway and have it mounted in the new enclosure. It appears to be talking to my 2.0.0 sensors just fine.!
      dbemowskD 1 Reply Last reply
      • sundberg84S
        sundberg84S
        Another motion and led strip node.
        • sundberg84S
          sundberg84S
          ...and deployed.
          hekH nagelcN 2 Replies Last reply
          • sundberg84S sundberg84
            ...and deployed.
            @sundberg84
            Nice, maybe add a diffuser? I've found that greaseproof paper (smörpapper in Swedish) works pretty well.
            • GertSandersG GertSanders
              @gertsanders what is that?
                ...and deployed.
                nagelcN
                nagelcN
                nagelc
                @sundberg84 Nice. I was wondering if I had an use for these. Now I want them everywhere!
                • nagelcN nagelc
                  sundberg84S
                  sundberg84S
                  @nagelc - easy to hide, looks good and awsome as night-lights for the kids. Its also a bit woav factor connecting them to a motion detector so they lights up when someone walks by.
                  • bjacobseB
                    bjacobseB
                    bjacobse
                    #508
                    Bathroom controller. It consist of a relaybox with a HLK 5v power source, it's hidden in the closet. Then I have realy to light, nightlight, mirrorheat, and extraction fan
                    And then the controller it self it's a Wemos D1 Mini Pro, Si7021 Temp/Hum, sensor and a PIR HC-SR501
                    3D file is created with Freecad, STL files are available here:
                    https://www.thingiverse.com/thing:2890456
                    dbemowskD gohanG 2 Replies Last reply
                    • bjacobseB bjacobse
                      dbemowskD
                      dbemowskD
                      @bjacobse Nice project. I like the 3D printed wall box. have you given any thought of having separate control of the lights and extraction fan? The reason I ask is that it may be beneficial to use the temp/humidity sensor to determine when the fan runs or gets shut off based on room humidity. This would be useful to reduce the chance of mold brought on by excess humidity.
                      bjacobseB 1 Reply Last reply
                        @bjacobse don't you get false pir detections with the wemos that close to the pir sensor?
                        • dbemowskD dbemowsk
                          bjacobseB
                          bjacobseB
                          bjacobse
                          @dbemowsk Thank you
                          For now as it's in early stage, I use the left switch to switch on (when I goto shower)on manually the fan, mirror heat, fan, and light and nightlight for 10min.
                          the right switch is only to start the fan for 5 min
                          I have not yet added humidity to start extraction fan automatically, but yes I will add this to the ESPEASY, rules
                            bjacobseB
                            bjacobseB
                            bjacobse
                            @gohan
                            No, I have a fairly large electrolyte cap on power supply on the controller PCB, to stabilize the PIR/Wemod/si7021 power source.
                            Actually when the bathroom door is open, and someone walk by the bathroom, the PIR will detect this and switch ON the light. I could consider to update 3D print to add a "wall" to block PIR.
                            The idea is that this PIR potentially can be used to connect to burglaralarm (but again I need to verify that I dont get false PIR reading due to sunlight)
                              I was asking because quite some people had issues with the PIR being too close to the antenna as the antenna during transmission was inducing some noise that triggered the sensor so they needed to move them apart to solve the issue
                              • E
                                E
                                executivul
                                Depending on the number of simultaneously active relays and the weemos tx power requirements make sure you don't overheat the HLK module, fire hazzard.
                                My 8 relay board draws a whooping 500ma @5V when all of them are active.
                                  bjacobseB
                                  bjacobseB
                                  bjacobse
                                  @gohan thanks I didn't think of the RF transmission from Wemos should impact PIR sensor, I only have thought of the power ripple. how far distance should affect PIR? I think mine is approx 2 cm apart
                                  • E executivul
                                    bjacobseB
                                    bjacobseB
                                    bjacobse
                                    #516
                                    @executivul
                                    Good point, But I have looked at the power/current budget.
                                    I have 4 pcs relay, JQC-3FF 5V DC, spec: https://www.futurlec.com/Relays/JQC-3FF-05.shtml uses 0,36W each x 4 pcs = total 1,44W.
                                    Usage of Wemos D1 Mini Pro is unknown, at least there is no spec...https://wiki.wemos.cc/products:d1:d1_mini_pro#documentation let says it uses 1 W
                                    HLK01 is rated to provide 3W
                                    Should be all ok
                                      #517
                                      @bjacobse I had problems with ~3-4cm. Lots of false triggers on the pir. But if you are not experiencing false triggers your setup is probably fine.
                                      More info: https://forum.mysensors.org/post/78771
                                        bjacobseB
                                        bjacobseB
                                        bjacobse
                                        @mfalkvidd Thanks for the link to the post, I think I should upgrade and use aluminium foil as you done to make a GND shield around the PIR sensor
                                          dbemowskD
                                          dbemowskD
                                          So I have uploaded the 3D design files for my MySensors gateway case to thingiverse for anyone that is interested.
                                          https://www.thingiverse.com/thing:2904969
                                          I have included the OpenSCAD file used to generate the .stl files. I would be interested in seeing posts of other makes or remixes of the design.
