  3. nRF5 action!
nRF5 action!
  • Nca78N
    wrote on last edited by Nca78
    #1612
    For those interested, NRF52840 is already available on AliExpress from HolyIOT, it's the revision 1 of the chip, too bad they put a chip antenna :(
    https://www.aliexpress.com/store/product/Nordic-nRF52840-Bluetooth-module-grid-development-board-BLE5-0-Bluetooth-serial-low-power-voice-long-distance/420533_32868365660.html
    [Edit] They also have the most compact NRF24 compatible gateway ever, for 10$ :o
    https://www.aliexpress.com/store/product/Nordic-nRF52832-BLE-4-0-4-2-5-0-USB-UART-BLE-dongle-for-computer/420533_32862480389.html
      #1613
      Looks as though there is also a new DK for the nRF52840 as well:
      https://www.digikey.com/product-detail/en/nordic-semiconductor-asa/NRF52840-DK/1490-1072-ND/8593726
      just not in stock.
      Looks like HolyIOT is ahead of the curve on this chip.
      JokgiJ 1 Reply Last reply
      • alowhumA
        alowhumA
        alowhum
        @nca78 said in nRF5 Bluetooth action!:
        Cool!
        Nca78N 1 Reply Last reply
        • alowhumA alowhum
          Cool!
          @alowhum said in nRF5 Bluetooth action!:
          Cool!
          If you buy one, buy the "black" version, it's a bit bigger but it's because it has a PCB antenna, range will be better.
          • Nca78N Nca78
            Cool!
            Toyman
            @nca78 I don't recognize any LDO on the PCB while it has USB power supply. How is 5V converted to 3.3v?
            alowhumA 1 Reply Last reply
            • T Toyman
              alowhumA
              alowhumA
              alowhum
              @toyman said in nRF5 Bluetooth action!:
              I was wondering the exact same thing!
                small internal dcdc converter
                • alowhumA alowhum
                  Look at bottom of page 6 and top left of "schematic" on page 9 of the CP2104 datasheet. It can supply up to 100mA.
                  https://www.silabs.com/documents/public/data-sheets/cp2104.pdf
                    Can someone please provide a link to the module being discussed? I tried looking on Aliexpress, and I don't see anything which matches.
                      #1621
                      @neverdie it's this link, in the description on aliexpress you can see the internal PCB "module"
                      T NeverDieN 2 Replies Last reply
                      • Nca78N Nca78
                        Toyman
                        @nca78 Got it. So it's kinda Arduino Nano, but nrf52-based.
                        • Nca78N Nca78
                          https://www.digikey.com/product-detail/en/tag-connect-llc/TC2030-CLIP/TC2030-CLIP-ND/2605371
                          ? Plug of nails?
                            ? Plug of nails?
                            Toyman
                            @neverdie https://www.aliexpress.com/store/product/Nordic-nRF52832-BLE-4-0-4-2-5-0-USB-UART-BLE-dongle-for-computer/420533_32862480389.html
                              I dropped "Bluetooth" from the title of this thread because the thread instead evolved into the MySensors alternative to Bluetooth.
                              • alowhumA
                                alowhumA
                                alowhum
                                How hard, or how much work, would it be to create a version of the MySensors gateway that works on one of those dongles?
                                • alowhumA alowhum
                                  Toyman
                                  @alowhum my understaning, it should work out of the box
                                  • alowhumA
                                    alowhumA
                                    alowhum
                                    Really? So something like:
                                    • Upload gateway sketch to it (how?)
                                    • Select "serial connection" in Domoticz?
                                    • alowhumA alowhum
                                      @alowhum You'd still need a programmer
                                        Toyman
                                        @neverdie ...and some nifty soldering skills in order to connect to SWDIO/SWDCLK pads
                                          i don't think you need extraordinary soldering skills, pads on bottom looks easy ;) (pretty sure these are the programming pads)
                                          The right question, imho, would be: can you expect from this dongle the range you would expect from a gateway ?? regarding chip antenna performance and maybe its gnd counterpoise..
                                          T JokgiJ 2 Replies Last reply
