  3. nRF5 action!
nRF5 action!
1.9k Posts 49 Posters 2.1m Views 44 Watching
  • alowhumA alowhum
    @neverdie said in nRF5 Bluetooth action!:
    nRF52 DK
    Which hardware programmer do you use with that?
    I find many of these software packages, like Segger's JLink stuff, are made for Windows (I'm on a mac).
    O
    O
    Omemanti
    @alowhum by programmer you mean in something like the Arduino ide? That's what I use ( I both use the nrf52dk =>j-link aswell the st-link v2 => st-link)
    • alowhumA
      alowhumA
      alowhum
      #1608
      @Omemanti I didn't realise the nRF52-DK was a hardware device. I thought it was a software program.
      On the picture you provided (thanks!), are pin 6 and 8 connected to a serial port to read what's going on? Your ground is connected in a different place than mine (I connect it next to the VCC pin). I suspect both those side-pins near the antenna, at the top, where you have soldered something, are ground too, right?
      O 1 Reply Last reply
      • alowhumA alowhum
        O
        O
        Omemanti
        @alowhum said in nRF5 Bluetooth action!:
        The nrf52 dev kit= > NRF52 Dev kit
        To connect the DK to a module :
        DK Ebyte module
        GND(detect) => GND
        SWDIO => SWDIO
        SWDCLK => SWCLK
        VTG => 3,3V
        3,3V => 3,3V
        GND =>GND
        select J-link and there you go.
        I used Pin 6 and 8 to connect to a FTDI to read out the serial. Since you can tell the sketch where to put the RX and TX I just connected them to 6 & 8.
        the Ebyte module has multiple GND connections, I messed the one next to the VCC up so I connected them next to the antenna. Just because I was easy ;)
        Indeed!
        • alowhumA
          alowhumA
          alowhum
          JLinkExe gives me this:
          WARNING: RESET (pin 15) high, but should be low. Please check target hardware.
          I already had some signs these EByte modules have a reset issue. As it they are constantly being reset. This points to that again. hmm.
          • alowhumA alowhum
            O
            O
            Omemanti
            wrote on last edited by Omemanti
            #1611
            @alowhum
            Hey, sorry, I'm not familiar with your error messages.
            Can you please sum everything up what you did so far and what your setup looks like (pic)
            • Drivers
            • Libraries
            • what software you use
            • Number of modules you tested
            • etc
            just to retrace your steps ( It might be useful to post it in a separate topic to keep this one cleaner ) => https://forum.mysensors.org/category/5/troubleshooting
            • Nca78N
              wrote on last edited by Nca78
              #1612
              For those interested, NRF52840 is already available on AliExpress from HolyIOT, it's the revision 1 of the chip, too bad they put a chip antenna :(
              https://www.aliexpress.com/store/product/Nordic-nRF52840-Bluetooth-module-grid-development-board-BLE5-0-Bluetooth-serial-low-power-voice-long-distance/420533_32868365660.html
              [Edit] They also have the most compact NRF24 compatible gateway ever, for 10$ :o
              https://www.aliexpress.com/store/product/Nordic-nRF52832-BLE-4-0-4-2-5-0-USB-UART-BLE-dongle-for-computer/420533_32862480389.html
                #1613
                Looks as though there is also a new DK for the nRF52840 as well:
                https://www.digikey.com/product-detail/en/nordic-semiconductor-asa/NRF52840-DK/1490-1072-ND/8593726
                just not in stock.
                Looks like HolyIOT is ahead of the curve on this chip.
                JokgiJ 1 Reply Last reply
                • alowhumA
                  alowhumA
                  alowhum
                  @nca78 said in nRF5 Bluetooth action!:
                  Cool!
                  Nca78N 1 Reply Last reply
                  • alowhumA alowhum
                    Cool!
                    Cool!
                    If you buy one, buy the "black" version, it's a bit bigger but it's because it has a PCB antenna, range will be better.
                    • Nca78N Nca78
                      Cool!
                      Toyman
                      @nca78 I don't recognize any LDO on the PCB while it has USB power supply. How is 5V converted to 3.3v?
                      alowhumA 1 Reply Last reply
                      • T Toyman
                        alowhumA
                        alowhumA
                        alowhum
                        @toyman said in nRF5 Bluetooth action!:
                        I was wondering the exact same thing!
                          small internal dcdc converter
                          • alowhumA alowhum
                            Look at bottom of page 6 and top left of "schematic" on page 9 of the CP2104 datasheet. It can supply up to 100mA.
                            https://www.silabs.com/documents/public/data-sheets/cp2104.pdf
                              Can someone please provide a link to the module being discussed? I tried looking on Aliexpress, and I don't see anything which matches.
                                #1621
                                @neverdie it's this link, in the description on aliexpress you can see the internal PCB "module"
                                T NeverDieN 2 Replies Last reply
                                • Nca78N Nca78
                                  Toyman
                                  @nca78 Got it. So it's kinda Arduino Nano, but nrf52-based.
                                  • Nca78N Nca78
                                    https://www.digikey.com/product-detail/en/tag-connect-llc/TC2030-CLIP/TC2030-CLIP-ND/2605371
                                    ? Plug of nails?
                                      ? Plug of nails?
                                      Toyman
                                      @neverdie https://www.aliexpress.com/store/product/Nordic-nRF52832-BLE-4-0-4-2-5-0-USB-UART-BLE-dongle-for-computer/420533_32862480389.html
                                        I dropped "Bluetooth" from the title of this thread because the thread instead evolved into the MySensors alternative to Bluetooth.
                                        • alowhumA
                                          alowhumA
                                          alowhum
                                          How hard, or how much work, would it be to create a version of the MySensors gateway that works on one of those dongles?
