  3. nRF5 action!
nRF5 action!
1.9k Posts 49 Posters 2.1m Views 44 Watching
  • alowhumA alowhum
    @Omemanti I didn't realise the nRF52-DK was a hardware device. I thought it was a software program.
    On the picture you provided (thanks!), are pin 6 and 8 connected to a serial port to read what's going on? Your ground is connected in a different place than mine (I connect it next to the VCC pin). I suspect both those side-pins near the antenna, at the top, where you have soldered something, are ground too, right?
    O
    O
    Omemanti
    @alowhum said in nRF5 Bluetooth action!:
    The nrf52 dev kit= > NRF52 Dev kit
    To connect the DK to a module :
    DK Ebyte module
    GND(detect) => GND
    SWDIO => SWDIO
    SWDCLK => SWCLK
    VTG => 3,3V
    3,3V => 3,3V
    GND =>GND
    select J-link and there you go.
    I used Pin 6 and 8 to connect to a FTDI to read out the serial. Since you can tell the sketch where to put the RX and TX I just connected them to 6 & 8.
    the Ebyte module has multiple GND connections, I messed the one next to the VCC up so I connected them next to the antenna. Just because I was easy ;)
    Indeed!
    • alowhumA
      alowhumA
      alowhum
      JLinkExe gives me this:
      WARNING: RESET (pin 15) high, but should be low. Please check target hardware.
      I already had some signs these EByte modules have a reset issue. As it they are constantly being reset. This points to that again. hmm.
      O 1 Reply Last reply
      • alowhumA alowhum
        O
        O
        Omemanti
        wrote on last edited by Omemanti
        #1611
        @alowhum
        Hey, sorry, I'm not familiar with your error messages.
        Can you please sum everything up what you did so far and what your setup looks like (pic)
        • Drivers
        • Libraries
        • what software you use
        • Number of modules you tested
        • etc
        just to retrace your steps ( It might be useful to post it in a separate topic to keep this one cleaner ) => https://forum.mysensors.org/category/5/troubleshooting
        • Nca78N
          wrote on last edited by Nca78
          #1612
          For those interested, NRF52840 is already available on AliExpress from HolyIOT, it's the revision 1 of the chip, too bad they put a chip antenna :(
          https://www.aliexpress.com/store/product/Nordic-nRF52840-Bluetooth-module-grid-development-board-BLE5-0-Bluetooth-serial-low-power-voice-long-distance/420533_32868365660.html
          [Edit] They also have the most compact NRF24 compatible gateway ever, for 10$ :o
          https://www.aliexpress.com/store/product/Nordic-nRF52832-BLE-4-0-4-2-5-0-USB-UART-BLE-dongle-for-computer/420533_32862480389.html
            #1613
            Looks as though there is also a new DK for the nRF52840 as well:
            https://www.digikey.com/product-detail/en/nordic-semiconductor-asa/NRF52840-DK/1490-1072-ND/8593726
            just not in stock.
            Looks like HolyIOT is ahead of the curve on this chip.
            JokgiJ 1 Reply Last reply
            • alowhumA
              alowhumA
              alowhum
              @nca78 said in nRF5 Bluetooth action!:
              Cool!
              Nca78N 1 Reply Last reply
              • alowhumA alowhum
                Cool!
                Cool!
                If you buy one, buy the "black" version, it's a bit bigger but it's because it has a PCB antenna, range will be better.
                • Nca78N Nca78
                  Cool!
                  Toyman
                  @nca78 I don't recognize any LDO on the PCB while it has USB power supply. How is 5V converted to 3.3v?
                  alowhumA 1 Reply Last reply
                  • T Toyman
                    alowhumA
                    alowhumA
                    alowhum
                    @toyman said in nRF5 Bluetooth action!:
                    I was wondering the exact same thing!
                      small internal dcdc converter
                      • alowhumA alowhum
                        Look at bottom of page 6 and top left of "schematic" on page 9 of the CP2104 datasheet. It can supply up to 100mA.
                        https://www.silabs.com/documents/public/data-sheets/cp2104.pdf
                          Can someone please provide a link to the module being discussed? I tried looking on Aliexpress, and I don't see anything which matches.
                            #1621
                            @neverdie it's this link, in the description on aliexpress you can see the internal PCB "module"
                            T NeverDieN 2 Replies Last reply
                            • Nca78N Nca78
                              Toyman
                              @nca78 Got it. So it's kinda Arduino Nano, but nrf52-based.
                              • Nca78N Nca78
                                https://www.digikey.com/product-detail/en/tag-connect-llc/TC2030-CLIP/TC2030-CLIP-ND/2605371
                                ? Plug of nails?
                                  ? Plug of nails?
                                  Toyman
                                  @neverdie https://www.aliexpress.com/store/product/Nordic-nRF52832-BLE-4-0-4-2-5-0-USB-UART-BLE-dongle-for-computer/420533_32862480389.html
                                    I dropped "Bluetooth" from the title of this thread because the thread instead evolved into the MySensors alternative to Bluetooth.
                                    • alowhumA
                                      alowhumA
                                      alowhum
                                      How hard, or how much work, would it be to create a version of the MySensors gateway that works on one of those dongles?
                                      • alowhumA alowhum
                                        Toyman
                                        @alowhum my understaning, it should work out of the box
                                        • alowhumA
                                          alowhumA
                                          alowhum
                                          Really? So something like:
                                          • Upload gateway sketch to it (how?)
                                          • Select "serial connection" in Domoticz?
