  3. nRF5 action!
nRF5 action!
1.9k Posts 49 Posters 2.1m Views 44 Watching
  • O
    O
    Omemanti
    wrote on last edited by Omemanti
    #1603
    @alowhum
    maybe a very stupid question, but did you check all the wires and after that if your computer uses the right drivers.
    I took me quite a while to figure this out myself. Especially the driver part messes things up. Errors everywhere that referred to different problems, but after I used Zadig they all disappeared.
    • Mars WarriorM Mars Warrior
      @alowhum, you seem to need Jlink Commander:
      @toyman said in nRF5 Bluetooth action!:
      @alowhum I intentionally asked you because I know the problem exists.
      You need to erase the chip via Jlink Commander. Neither nrfjprog nor anything alse will work (AFAIK)
      Actually, it was @NeverDie who found it in the beginning of his quest with nrf52. "The thing that started it all" (c)
      Furthermore, It would be nice to have a small step-by-step guide to unlock and then program the ebyte module.
      @Omemanti and @NeverDie are using these modules, so should be able to write something up that works for other ppl ;-)
      (My ebyte modules are still on their way)
      #1604
      @mars-warrior said in nRF5 Bluetooth action!:
      As I've said many times previoiusly, I use the nRF52 DK to program external modules, and it's what I recommend for noobs because it's relatively hassle free. If you're able to use the $2 st-link v2 programmer then great, my hat's off to you. If not, I recommend the nRF52 DK rather than get frustrated and give up.
      alowhumA 1 Reply Last reply
        alowhumA
        alowhumA
        alowhum
        @neverdie said in nRF5 Bluetooth action!:
        nRF52 DK
        Which hardware programmer do you use with that?
        I find many of these software packages, like Segger's JLink stuff, are made for Windows (I'm on a mac).
        gohanG O 2 Replies Last reply
        • alowhumA alowhum
          nRF52 DK
          @alowhum you can still install windows on it :sweat_smile:
          • alowhumA alowhum
            nRF52 DK
            O
            O
            Omemanti
            @alowhum by programmer you mean in something like the Arduino ide? That's what I use ( I both use the nrf52dk =>j-link aswell the st-link v2 => st-link)
            • alowhumA
              alowhumA
              alowhum
              #1608
              @Omemanti I didn't realise the nRF52-DK was a hardware device. I thought it was a software program.
              On the picture you provided (thanks!), are pin 6 and 8 connected to a serial port to read what's going on? Your ground is connected in a different place than mine (I connect it next to the VCC pin). I suspect both those side-pins near the antenna, at the top, where you have soldered something, are ground too, right?
              O 1 Reply Last reply
              • alowhumA alowhum
                O
                O
                Omemanti
                @alowhum said in nRF5 Bluetooth action!:
                The nrf52 dev kit= > NRF52 Dev kit
                To connect the DK to a module :
                DK Ebyte module
                GND(detect) => GND
                SWDIO => SWDIO
                SWDCLK => SWCLK
                VTG => 3,3V
                3,3V => 3,3V
                GND =>GND
                select J-link and there you go.
                I used Pin 6 and 8 to connect to a FTDI to read out the serial. Since you can tell the sketch where to put the RX and TX I just connected them to 6 & 8.
                the Ebyte module has multiple GND connections, I messed the one next to the VCC up so I connected them next to the antenna. Just because I was easy ;)
                Indeed!
                • alowhumA
                  alowhumA
                  alowhum
                  JLinkExe gives me this:
                  WARNING: RESET (pin 15) high, but should be low. Please check target hardware.
                  I already had some signs these EByte modules have a reset issue. As it they are constantly being reset. This points to that again. hmm.
                  • alowhumA alowhum
                    O
                    O
                    Omemanti
                    #1611
                    @alowhum
                    Hey, sorry, I'm not familiar with your error messages.
                    Can you please sum everything up what you did so far and what your setup looks like (pic)
                    • Drivers
                    • Libraries
                    • what software you use
                    • Number of modules you tested
                    • etc
                    just to retrace your steps ( It might be useful to post it in a separate topic to keep this one cleaner ) => https://forum.mysensors.org/category/5/troubleshooting
                    • Nca78N
                      wrote on last edited by Nca78
                      #1612
                      For those interested, NRF52840 is already available on AliExpress from HolyIOT, it's the revision 1 of the chip, too bad they put a chip antenna :(
                      https://www.aliexpress.com/store/product/Nordic-nRF52840-Bluetooth-module-grid-development-board-BLE5-0-Bluetooth-serial-low-power-voice-long-distance/420533_32868365660.html
                      [Edit] They also have the most compact NRF24 compatible gateway ever, for 10$ :o
                      https://www.aliexpress.com/store/product/Nordic-nRF52832-BLE-4-0-4-2-5-0-USB-UART-BLE-dongle-for-computer/420533_32862480389.html
                        #1613
                        Looks as though there is also a new DK for the nRF52840 as well:
                        https://www.digikey.com/product-detail/en/nordic-semiconductor-asa/NRF52840-DK/1490-1072-ND/8593726
                        just not in stock.
                        Looks like HolyIOT is ahead of the curve on this chip.
                        JokgiJ 1 Reply Last reply
                        • alowhumA
                          alowhumA
                          alowhum
                          @nca78 said in nRF5 Bluetooth action!:
                          Cool!
                          Nca78N 1 Reply Last reply
                          • alowhumA alowhum
                            Cool!
                            Cool!
                            If you buy one, buy the "black" version, it's a bit bigger but it's because it has a PCB antenna, range will be better.
                            • Nca78N Nca78
                              Cool!
                              Toyman
                              @nca78 I don't recognize any LDO on the PCB while it has USB power supply. How is 5V converted to 3.3v?
                              • T Toyman
                                alowhumA
                                alowhumA
                                alowhum
                                I was wondering the exact same thing!
                                  small internal dcdc converter
                                  • alowhumA alowhum
                                    Look at bottom of page 6 and top left of "schematic" on page 9 of the CP2104 datasheet. It can supply up to 100mA.
                                    https://www.silabs.com/documents/public/data-sheets/cp2104.pdf
                                      Can someone please provide a link to the module being discussed? I tried looking on Aliexpress, and I don't see anything which matches.
                                        #1621
                                        @neverdie it's this link, in the description on aliexpress you can see the internal PCB "module"
                                        T NeverDieN 2 Replies Last reply
                                        • Nca78N Nca78
                                          Toyman
                                          @nca78 Got it. So it's kinda Arduino Nano, but nrf52-based.
