716 Posts 111 Posters 703.2k Views 93 Watching
  • sundberg84S
    sundberg84S
    #568
    Thanks guys! (@scalz @gohan @dbemowsk !)
    I think I will relocate the booster... should have thought about that before.
    The NRF antenna goes outside the PCB just like rev 9 so no ground plain for the antenna in normal cases. I might revert it back to allow the PCB to be in range for all directions. Good point.
    I will start with to swap extra and booster to get as much space in between the antenna and inductor.
    • sundberg84S
      sundberg84S
      Something like this...
      • dbemowskD
        dbemowskD
        Would something like this be possible? It would give users that little bit of extra room in the proto area.
        • sundberg84S
          sundberg84S
          Hi all!
          This has now been update to Rev 10.
          New revision has been sent to PCB manufacturer but It will take some days for them to update their Gerber. (When you order, make sure it says M.Rev 6!
          Openhardware page has been updated, let me know if you find anything strange.
          RFM69 version will be updated soon as well.
          • A
            APL2017
            Can you please share design of version 9 of the Easy PCB NRF24 edition. I bought 10 pieces a while ago but just decided to use couple. Thank you.
            • A APL2017
              sundberg84S
              sundberg84S
              #573
              @apl2017 what kind of info are you looking for ? Schematics ?
              • A
                APL2017
                Just schematic and board layout, exactly what you placed, if possible in a bit better resolution. Thanks a lot!
                • A APL2017
                  sundberg84S
                  sundberg84S
                  @apl2017 traveling for my work until next week but will post then.
                    Mister_ik
                    @sundberg84 I just finished my first battery sensor node based on the Easy PCB Rev 9. I have two questions i hope you can help me with:
                    The first is about the battery measurement. Because i didn't have a 0.1 uf lying around i used an 0.2 uf capacitor. I am using the following script to measure the battery.
                       // Calculate the battery in %
                    Do i need to change anything in the formula? Because i getting reading around the 130%
                    Requesting temperature...DONE
                    Temperatuur : 26.62 Degrees C
                    11935 TSF:MSG:SEND,25-25-0-0,s=5,c=1,t=0,pt=7,l=5,sg=0,ft=0,st=OK:26.6
                    Battery percent: 131 %
                    Battery Voltage: 3.35 V
                    Sleep...
                    12945 MCO:SLP:MS=900000,SMS=0,I1=0,M1=1,I2=254,M2=1
                    12955 TSF:TDI:TSL
                    If i use the following method:
                       int batteryPcntNEW = sensorValue / 10;
                       Serial.print(batteryPcntNEW);
                    I am getting: (this is expected, because batteries are new)
                    Battery percent: 99 %
                    Sleep...
                    12955 TSF:TDI:TSL
                    My second question is about casing: any tips on which case to use which fit your board and a battery pack? and is as small as possible? Do you perhaps have links of your favourite (Chinese) sellers?
                    Nca78N sundberg84S 2 Replies Last reply
                    • M Mister_ik
                      Sleep...
                      12955 TSF:TDI:TSL
                      Sleep...
                      12955 TSF:TDI:TSL
                      @mister_ik said in 💬 Easy/Newbie PCB for MySensors:
                      Hello, this is normal as your maximum voltage is set at 3V, while initial voltage of an alkaline AA/AAA cell can be a bit over 1.6V. But voltage will quickly drop toward 1.5V (much faster than remaining capacity), so the best instead of changing the maximum voltage is to check the value of batteryPcnt and if it's over 100, just set it to 100.
                      Make sure the VBAT_PER_BITS makes you read a voltage that matches the voltage you read with your multimeter, else fix it. Each Atmega is different so you need to calibrate each board.
                      For the capacitor it's not a problem, it's just made to stabilize the voltage as it's very sensible to electrical noise. Twice the value will be good enough for this job :)
                      • M Mister_ik
                        Sleep...
                        12955 TSF:TDI:TSL
                        Sleep...
                        12955 TSF:TDI:TSL
                        sundberg84S
                        sundberg84S
                        #578
                        @Nca78 thanks for the help/answer. 😀 About the case I'm using some plastic electronic cases from my hardware shop but @ openhardware you will find some links to 3d projects.
                        Let us know @Mister_ik if you need anything else.
                          mickecarlsson
                          No sign of the new revision yet:
                          • M mickecarlsson
                            sundberg84S
                            sundberg84S
                            @mickecarlsson - not on the RFM69 version, no. PCBway has updated the NRF24 version so a good sign.
                            Something went wrong with the update of the RFM69 version so I had to activate it 21hours ago:
                            Lets hope PCBway picks this up today.
                            • sundberg84S sundberg84
                              mickecarlsson
                              @sundberg84
                              OK, good news. I will check it tomorrow and hopefully order a batch (or two).
                                mickecarlsson
                                Still no rev 6 on itead or pcbway for rfm69 version :-(
                                • M mickecarlsson
                                  sundberg84S
                                  sundberg84S
                                  @mickecarlsson no something went wrong so Rev 5 is ok to order! This is easy rev 10!
                                  • ร
                                    ร
                                    รอเรือ
                                    wrote on last edited by รอเรือ
                                    #584
                                    Hello @sundberg84
                                    What if feeding a Pro Mini 3.3V (EasyPCB Nrf24l01+ edition rev 10) with regulated power on RAW. (I have 5 VDC). I guess I can feed the radio via the VCC terminal instead of using an external voltage regulator. Can the EasyPCB be used in such a setup?
                                    Edit: To answer my own question. I should RTFM :facepunch:
                                    It states clearly that:
                                    "(If you are using regulated 3.3v, use 5v instructions but skip the voltage regulator and bypass this with a jumper between Vin and Vout"
                                    Thanks anyway!
                                    franz-unixF 1 Reply Last reply
                                      mhkid
                                      wrote on last edited by mhkid
                                      #585
                                      • ร รอเรือ
                                        Hello @sundberg84
                                        Thanks anyway!
                                        franz-unixF
                                        franz-unixF
                                        franz-unix
                                        @รอเร-อ I have a similar need, but not exactly the same.
                                        My power route is:
                                        18650 Lipo (2.7 - 4.2 V) -> TP4056 (charger) -> Booster (5V) -> Raw pin of pro mini 3.3V -> Vcc of pro mini 3.3V -> Radio (NRF24)
                                        In my case the easy newbie pcb is not directly suitable because the Vout of the Booster is connected to Vcc instead of raw.
                                        So my idea is to use a modified version of the easy newbie pcb with the schematic posted here
                                        in order to have more flexibility in the power options.
                                        Actually I don't have the skills to design a pcb, but maybe, if the idea is good, someone else could design it.
                                        This schematic is compatible with all the power options actually supported by the easy newbie pcb, and supports also new possibility, simply changing a couple of jumpers
                                        • Nca78N
                                          Hello @franz-unix, can't you just bend the output pin of the booster at 90° and solder a wire from it to the raw pin ?
