716 Posts 111 Posters 703.2k Views 93 Watching
    Mister_ik
    @sundberg84 I just finished my first battery sensor node based on the Easy PCB Rev 9. I have two questions i hope you can help me with:
    The first is about the battery measurement. Because i didn't have a 0.1 uf lying around i used an 0.2 uf capacitor. I am using the following script to measure the battery.
       // Calculate the battery in %
    Do i need to change anything in the formula? Because i getting reading around the 130%
    Requesting temperature...DONE
    Temperatuur : 26.62 Degrees C
    11935 TSF:MSG:SEND,25-25-0-0,s=5,c=1,t=0,pt=7,l=5,sg=0,ft=0,st=OK:26.6
    Battery percent: 131 %
    Battery Voltage: 3.35 V
    Sleep...
    12945 MCO:SLP:MS=900000,SMS=0,I1=0,M1=1,I2=254,M2=1
    12955 TSF:TDI:TSL
    If i use the following method:
       int batteryPcntNEW = sensorValue / 10;
       Serial.print(batteryPcntNEW);
    I am getting: (this is expected, because batteries are new)
    Battery percent: 99 %
    Sleep...
    12955 TSF:TDI:TSL
    My second question is about casing: any tips on which case to use which fit your board and a battery pack? and is as small as possible? Do you perhaps have links of your favourite (Chinese) sellers?
    Nca78N sundberg84S 2 Replies Last reply
    • M Mister_ik
      Sleep...
      12955 TSF:TDI:TSL
      Sleep...
      12955 TSF:TDI:TSL
      @mister_ik said in 💬 Easy/Newbie PCB for MySensors:
      Hello, this is normal as your maximum voltage is set at 3V, while initial voltage of an alkaline AA/AAA cell can be a bit over 1.6V. But voltage will quickly drop toward 1.5V (much faster than remaining capacity), so the best instead of changing the maximum voltage is to check the value of batteryPcnt and if it's over 100, just set it to 100.
      Make sure the VBAT_PER_BITS makes you read a voltage that matches the voltage you read with your multimeter, else fix it. Each Atmega is different so you need to calibrate each board.
      For the capacitor it's not a problem, it's just made to stabilize the voltage as it's very sensible to electrical noise. Twice the value will be good enough for this job :)
      • M Mister_ik
        Sleep...
        12955 TSF:TDI:TSL
        Sleep...
        12955 TSF:TDI:TSL
        sundberg84S
        sundberg84S
        #578
        @Nca78 thanks for the help/answer. 😀 About the case I'm using some plastic electronic cases from my hardware shop but @ openhardware you will find some links to 3d projects.
        Let us know @Mister_ik if you need anything else.
          mickecarlsson
          No sign of the new revision yet:
          • M mickecarlsson
            sundberg84S
            sundberg84S
            @mickecarlsson - not on the RFM69 version, no. PCBway has updated the NRF24 version so a good sign.
            Something went wrong with the update of the RFM69 version so I had to activate it 21hours ago:
            Lets hope PCBway picks this up today.
            • sundberg84S sundberg84
              mickecarlsson
              @sundberg84
              OK, good news. I will check it tomorrow and hopefully order a batch (or two).
                mickecarlsson
                Still no rev 6 on itead or pcbway for rfm69 version :-(
                • M mickecarlsson
                  sundberg84S
                  sundberg84S
                  @mickecarlsson no something went wrong so Rev 5 is ok to order! This is easy rev 10!
                  • ร
                    ร
                    รอเรือ
                    wrote on last edited by รอเรือ
                    #584
                    Hello @sundberg84
                    What if feeding a Pro Mini 3.3V (EasyPCB Nrf24l01+ edition rev 10) with regulated power on RAW. (I have 5 VDC). I guess I can feed the radio via the VCC terminal instead of using an external voltage regulator. Can the EasyPCB be used in such a setup?
                    Edit: To answer my own question. I should RTFM :facepunch:
                    It states clearly that:
                    "(If you are using regulated 3.3v, use 5v instructions but skip the voltage regulator and bypass this with a jumper between Vin and Vout"
                    Thanks anyway!
                    franz-unixF 1 Reply Last reply
                      mhkid
                      wrote on last edited by mhkid
                      #585
                      • ร รอเรือ
                        Hello @sundberg84
                        Thanks anyway!
                        franz-unixF
                        franz-unixF
                        franz-unix
                        @รอเร-อ I have a similar need, but not exactly the same.
                        My power route is:
                        18650 Lipo (2.7 - 4.2 V) -> TP4056 (charger) -> Booster (5V) -> Raw pin of pro mini 3.3V -> Vcc of pro mini 3.3V -> Radio (NRF24)
                        In my case the easy newbie pcb is not directly suitable because the Vout of the Booster is connected to Vcc instead of raw.
                        So my idea is to use a modified version of the easy newbie pcb with the schematic posted here
                        in order to have more flexibility in the power options.
                        Actually I don't have the skills to design a pcb, but maybe, if the idea is good, someone else could design it.
                        This schematic is compatible with all the power options actually supported by the easy newbie pcb, and supports also new possibility, simply changing a couple of jumpers
                        • Nca78N
                          Hello @franz-unix, can't you just bend the output pin of the booster at 90° and solder a wire from it to the raw pin ?
                          • franz-unixF
                            franz-unixF
                            franz-unix
                            @nca78 Yes it should work.
                            If I connect the output of the tp4056 to the gnd and reg input of the screw terminal of the easy newbie pcb and then I run a wire from the Vout of the booster to the raw input of the screw terminal, the final result is also quite clean and it is not necessary to solder the wire directly on the pro mini.
                            I think that, in this case, the reg jumper must be NOT shortened.
                            • Z
                              Z
                              zelen
                              I ordered 10 PCBs using "Order from PCBWay" button. It only asked me about PayPal card and din't require any registration on PCBWay. So, everything looks good, PayPal transaction is completed. Can somebody tell me please how can I track it? Probably I'm missing tracking option somewhere... Thank you!
                              P.S.
                              Cant wait to try it out. :)
                              • Z zelen
                                P.S.
                                sundberg84S
                                sundberg84S
                                @zelen I'm not sure. You didn't receive any email? I normally get a email once they are finished and shipped with tracking.
                                Z 1 Reply Last reply
                                • Z
                                  Z
                                  zelen
                                    Z
                                    Z
                                    zelen
                                    @sundberg84 thank you for clarification. I expected email right after making an order. So, I will wait for finishing production and shipment.
                                    • H
                                      H
                                      Harrdy
                                      I use some of old rev8 boards. I have noticed that I use a ceramic capacitor instead of an electric capacitor compared to the images for the battery measurement. Does it matter? Or should I replace the ceramic capacitor (104) with an electric capacitor?
                                      sundberg84S gohanG 2 Replies Last reply
                                      • H Harrdy
                                        sundberg84S
                                        sundberg84S
                                        @harrdy should work just fine.
                                        • H Harrdy
                                          @harrdy remember to take a few readings and average out the battery value
