716 Posts 111 Posters 703.2k Views 93 Watching
  • M Mister_ik
    @sundberg84 I just finished my first battery sensor node based on the Easy PCB Rev 9. I have two questions i hope you can help me with:
    The first is about the battery measurement. Because i didn't have a 0.1 uf lying around i used an 0.2 uf capacitor. I am using the following script to measure the battery.
       // Calculate the battery in %
    Do i need to change anything in the formula? Because i getting reading around the 130%
    Requesting temperature...DONE
    Temperatuur : 26.62 Degrees C
    11935 TSF:MSG:SEND,25-25-0-0,s=5,c=1,t=0,pt=7,l=5,sg=0,ft=0,st=OK:26.6
    Battery percent: 131 %
    Battery Voltage: 3.35 V
    Sleep...
    12945 MCO:SLP:MS=900000,SMS=0,I1=0,M1=1,I2=254,M2=1
    12955 TSF:TDI:TSL
    If i use the following method:
       int batteryPcntNEW = sensorValue / 10;
       Serial.print(batteryPcntNEW);
    I am getting: (this is expected, because batteries are new)
    Battery percent: 99 %
    Sleep...
    12955 TSF:TDI:TSL
    My second question is about casing: any tips on which case to use which fit your board and a battery pack? and is as small as possible? Do you perhaps have links of your favourite (Chinese) sellers?
    sundberg84S
    sundberg84S
    #578
    @Nca78 thanks for the help/answer. 😀 About the case I'm using some plastic electronic cases from my hardware shop but @ openhardware you will find some links to 3d projects.
    Let us know @Mister_ik if you need anything else.
      mickecarlsson
      No sign of the new revision yet:
      • M mickecarlsson
        sundberg84S
        sundberg84S
        @mickecarlsson - not on the RFM69 version, no. PCBway has updated the NRF24 version so a good sign.
        Something went wrong with the update of the RFM69 version so I had to activate it 21hours ago:
        Lets hope PCBway picks this up today.
        • sundberg84S sundberg84
          mickecarlsson
          @sundberg84
          OK, good news. I will check it tomorrow and hopefully order a batch (or two).
            mickecarlsson
            Still no rev 6 on itead or pcbway for rfm69 version :-(
            • M mickecarlsson
              sundberg84S
              sundberg84S
              @mickecarlsson no something went wrong so Rev 5 is ok to order! This is easy rev 10!
              • ร
                ร
                รอเรือ
                wrote on last edited by รอเรือ
                #584
                Hello @sundberg84
                What if feeding a Pro Mini 3.3V (EasyPCB Nrf24l01+ edition rev 10) with regulated power on RAW. (I have 5 VDC). I guess I can feed the radio via the VCC terminal instead of using an external voltage regulator. Can the EasyPCB be used in such a setup?
                Edit: To answer my own question. I should RTFM :facepunch:
                It states clearly that:
                "(If you are using regulated 3.3v, use 5v instructions but skip the voltage regulator and bypass this with a jumper between Vin and Vout"
                Thanks anyway!
                franz-unixF 1 Reply Last reply
                  mhkid
                  wrote on last edited by mhkid
                  #585
                  • ร รอเรือ
                    Hello @sundberg84
                    Thanks anyway!
                    franz-unixF
                    franz-unixF
                    franz-unix
                    @รอเร-อ I have a similar need, but not exactly the same.
                    My power route is:
                    18650 Lipo (2.7 - 4.2 V) -> TP4056 (charger) -> Booster (5V) -> Raw pin of pro mini 3.3V -> Vcc of pro mini 3.3V -> Radio (NRF24)
                    In my case the easy newbie pcb is not directly suitable because the Vout of the Booster is connected to Vcc instead of raw.
                    So my idea is to use a modified version of the easy newbie pcb with the schematic posted here
                    in order to have more flexibility in the power options.
                    Actually I don't have the skills to design a pcb, but maybe, if the idea is good, someone else could design it.
                    This schematic is compatible with all the power options actually supported by the easy newbie pcb, and supports also new possibility, simply changing a couple of jumpers
                    • Nca78N
                      Hello @franz-unix, can't you just bend the output pin of the booster at 90° and solder a wire from it to the raw pin ?
                      • franz-unixF
                        franz-unixF
                        franz-unix
                        @nca78 Yes it should work.
                        If I connect the output of the tp4056 to the gnd and reg input of the screw terminal of the easy newbie pcb and then I run a wire from the Vout of the booster to the raw input of the screw terminal, the final result is also quite clean and it is not necessary to solder the wire directly on the pro mini.
                        I think that, in this case, the reg jumper must be NOT shortened.
                        • Z
                          Z
                          zelen
                          I ordered 10 PCBs using "Order from PCBWay" button. It only asked me about PayPal card and din't require any registration on PCBWay. So, everything looks good, PayPal transaction is completed. Can somebody tell me please how can I track it? Probably I'm missing tracking option somewhere... Thank you!
                          P.S.
                          Cant wait to try it out. :)
                          • Z zelen
                            P.S.
                            sundberg84S
                            sundberg84S
                            @zelen I'm not sure. You didn't receive any email? I normally get a email once they are finished and shipped with tracking.
                            Z 1 Reply Last reply
                            • Z
                              Z
                              zelen
                                Z
                                Z
                                zelen
                                @sundberg84 thank you for clarification. I expected email right after making an order. So, I will wait for finishing production and shipment.
                                • H
                                  H
                                  Harrdy
                                  I use some of old rev8 boards. I have noticed that I use a ceramic capacitor instead of an electric capacitor compared to the images for the battery measurement. Does it matter? Or should I replace the ceramic capacitor (104) with an electric capacitor?
                                  sundberg84S gohanG 2 Replies Last reply
                                  • H Harrdy
                                    sundberg84S
                                    sundberg84S
                                    @harrdy should work just fine.
                                    • H Harrdy
                                      @harrdy remember to take a few readings and average out the battery value
                                      • manosM
                                        manosM
                                        manos
                                        Hello @sundberg84, I would like to buy the Easy/Newbie PCB for MySensors but I have a few questions
                                        I want to use it the 5V Arduino Pro mini not the 3V version
                                        I also want to use the battery monitor
                                        Is it ok or should I modify "something"
                                        Also all the pcbs have the battery "expansion: or not?
                                        Thanks, Emmanuel
                                          Why would you want to use the 5v arduino on batteries?
