  3. How to add support for SAM D51/Cortex M4?
3 Posts 2 Posters 2.7k Views 2 Watching
  • K
    K
    Karl-Heinz K
    my name is Karl-Heinz and I discovered MySensor a few days ago. I am very impressed and would like to use it for all my sensors.
    I have 8bit and 32bit MCUs.
    My latest MCU is an SAM D51 (Adafruit Itsybitsy M4).
    I can use it when I make a minor modification to MySensors/hal/architecture/SAMD/MyHwSAMD.cpp.
    When I try to compile Arduino IDE throws an error, that ADC is not defined in this context -> uint16_t hwCPUVoltage()
    I have not much experience with programming. Therefore I commented all code lines in uint16_t hwCPUVoltage() and added hardcoded "return 3.3;"
    Then I can compile at least what I tested so far for the SAM D51.
    Of course this is not a solution. Therefore I would like to ask what is the proper way to modify MySensors for use with the Cortex M4 processors.
    Thanks a lot and keep the good work going!!
    Sincerely
    Karl-Heinz
    • K Karl-Heinz K
      Sincerely
      Karl-Heinz
      A (still incomplete but) less inelegant solution is to
      return FUNCTION_NOT_SUPPORTED;
      As is done for esp32 for example: https://github.com/mysensors/MySensors/blob/6ffe29cb5fcfa33fa83133044c2d16ee45c66697/hal/architecture/ESP32/MyHwESP32.cpp#L119
      • K
        K
        Karl-Heinz K
        Hallo Mikael,
        thank you for your hint.
        I modified the hwCPUVoltage() part of MyHwSAMD.cpp like this. It works for me. Maybe it is not the best solution, however.
        Sincerely
        Karl-Heinz
        	#ifdef __SAMD51__
        	// disable ADC
        	while (ADC->STATUS.bit.SYNCBUSY);
        	ADC->CTRLA.bit.ENABLE = 0x00;
        	// internal 1V reference (default)
        	analogReference(AR_INTERNAL1V0);
        	// 12 bit resolution (default)
        	analogWriteResolution(12);
        	// MUXp 0x1B = SCALEDIOVCC/4 => connected to Vcc
        	ADC->INPUTCTRL.bit.MUXPOS = 0x1B ;
        	// enable ADC
        	ADC->CTRLA.bit.ENABLE = 0x01;
        	// start conversion
        	ADC->SWTRIG.bit.START = 1;
        	// clear the Data Ready flag
        	ADC->INTFLAG.bit.RESRDY = 1;
        	// start conversion again, since The first conversion after the reference is changed must not be used.
        	// waiting for conversion to complete
        	while (!ADC->INTFLAG.bit.RESRDY);
        	const uint32_t valueRead = ADC->RESULT.reg;
        	// disable ADC
        	return valueRead * 4;
        12.5k
