1.1k Posts 105 Posters 796.0k Views 98 Watching
  • sundberg84S sundberg84
    Today I had the ladder so I could get on the roof so while there I changed batteries on my rain node.
    @sundberg84 But what did you build today? ;-)
    • YveauxY Yveaux
      sundberg84S
      sundberg84S
      @yveaux nothing that I can post here unfortunately... only a ladder for my cat 😂 non automated.
      Nca78N 1 Reply Last reply
      • nagelcN
        nagelcN
        nagelc
        wrote on last edited by nagelc
        #627
        It's a breakout for a Fanstel BT832 (NRF52832). Two experiments with this board, still a work in progress:
        • I wondered if it would be possible to hand solder to the LGA pads on the back of the BT832 using small plated thru holes (6 solder spots middle left in the first picture). Two pads connected. The rest did not. About what I expected.
        • Using just the microprocessor of the BT832 to make a LoRa node. (NRF5 radio turned off). So far the Ra-01 is not initializing. Edit (10/8). The RA-01 now initializes. I needed to update the pin assignments in MyBoardNRF5.h.
          Just pretend you have automated your cat. We can't control from here.
          • vladimirV
            vladimirV
            vladimir
            Colleagues!
            I am writing in this thread, because here are the most active users of the forum and the system MySensors.:raised_hands:
            Perhaps you can help me with the solution of my problem: Improvement Xiaomi smart kettle (I need help!)
            Maybe you had similar projects...
            Then, I can finally publish a new project in this thread. :v:
            • vladimirV vladimir
              Colleagues!
              #630
              @vladimir please don't crosspost. Everybody is able to see the latest messages, so there is no need to point to your post from multiple threads.
              vladimirV 1 Reply Last reply
              • YveauxY Yveaux
                vladimirV
                vladimirV
                vladimir
                @yveaux Excuse me. I promise not to do it again!:man-gesturing-ok:
                • sundberg84S
                  sundberg84S
                  #632
                  @Nca78 Well, i automated my cat door.
                  • Andrew MaynardA
                    Andrew MaynardA
                    Andrew Maynard
                    The rules are simple - keep it simple with one picture (or a few) with a small text including a small exp
                    sick of breadboard so made the gateway more permanent. added a nice dc plug to it after pic
                    • sundberg84S
                      sundberg84S
                      #634
                      Playing with how small I could create a EasyPCB if I only used SMD components and footprints for both RFM69 and Nrf24l01+... including MysX, Signing, Flash offcourse... and a coincell...
                      tbowmoT monteM 2 Replies Last reply
                        tbowmoT
                        tbowmoT
                        tbowmo
                        @sundberg84
                        cool, what dimensions are you down to now?
                        btw. what happened to the trace in lower right corner (the one that runs by the ISP connector)?
                        • tbowmoT tbowmo
                          @sundberg84
                          sundberg84S
                          sundberg84S
                          #636
                          @tbowmo - Thanks!! :) 42mm diameter (round, but the 3d view doesnt show that).
                          The track - well, it seems like I can only get KiCad to make 45dgr tracks... need to investigate it its possible to make other tracks...
                          O 1 Reply Last reply
                            monteM
                            monteM
                            monte
                            @sundberg84 you can also use smd crystal. They are cheaply available on aliexpress. Are you using 0603 caps and resistors?
                            • monteM monte
                              sundberg84S
                              sundberg84S
                              @monte - 0805 res/caps, (for me easy to solder, while 0603 is possible but start to get hard).
                              I was thinking about SMD crystal but left it since i couldnt find a common size. Do you know a good size for SMD crystal (with multiple brands?) like 0805 or a good searchword? I found HC-49S but they are the same size as the ones with pins.
                              monteM 1 Reply Last reply
                                O
                                O
                                Omemanti
                                wrote on last edited by Omemanti
                                #639
                                @sundberg84 "well, it seems like I can only get KiCad to make 45dgr tracks"
                                References => General Settings => Limit graphics lines to 45 degrees
                                • bjacobseB
                                  bjacobseB
                                  bjacobse
                                  I recently hacked my Assa Abloy/Yale smart lock as it could only turn +-90° created a new washer ring, so it now can turn infinitely so it is usable to use a lock
                                  The needed 3D stl file or Freecad drawing is to be found here:
                                  https://www.thingiverse.com/thing:3155286
                                    @Yveaux - Yes, as long as you don't tell her ;)
                                    N
                                    N
                                    Nina Baines
                                    What an inspiring thread!
                                      monteM
                                      monteM
                                      monte
                                      @sundberg84 I've bought these 5032 crystals: https://www.aliexpress.com/item/Free-shipping-20pcs-16-000MHZ-16mhz-20pF-2Pin-5032-smd-quartz-resonator-Crystal/32821974003.html but there are plentiful other offers on aliexspress and/or ebay. This 5032 package seems to be the most common. There is another package with the same size but with 4 pins 2 of which are not connected, I bought them from my local distributor, while was waiting a package from aliexpress. But those with 4 pins are harder to solder (obviously) and I don't see any pros of using them.
                                      The most suitable for hand soldering and easiest to find are these: 0_1540201979487_2014022559267404.jpg
                                      According to this image the ones I have are TX5 and TG5.
                                      • sundberg84S
                                        sundberg84S
                                        Im getting so tired of soldering extra wires and stuff so today im doing a "MysX to All common sensors breakout board"...
                                        Dont know if this will work... but worth a shot.
                                        • alowhumA
                                          alowhumA
                                          alowhum
                                          #644
                                          @sundberg84 If I'm honest some of those sensors seem 'old' to me.
                                          • I usually go for the BEM280 instead of the BMP085 and DHT22. It's so cheap now.
                                          • I never use pulse soil sensors, only the capacitive kind, as they last much longer and don't pollute the soil.
                                          In fact, I always make all my sensors with the Nano Wireless Expansion Board, which is about $2. You can simply plug in the NRF24 into it.
                                          https://www.aliexpress.com/item/Free-shipping-Nano-328P-IO-wireless-sensor-expansion-board-for-XBEE-and-NRF24L01-Socket-for-arduino/32264665470.html
                                          sundberg84S Nca78N 2 Replies Last reply
