1.1k Posts 105 Posters 796.0k Views 98 Watching
  • vladimirV
    vladimirV
    vladimir
    Colleagues!
    I am writing in this thread, because here are the most active users of the forum and the system MySensors.:raised_hands:
    Perhaps you can help me with the solution of my problem: Improvement Xiaomi smart kettle (I need help!)
    Maybe you had similar projects...
    Then, I can finally publish a new project in this thread. :v:
    • vladimirV vladimir
      Colleagues!
      #630
      @vladimir please don't crosspost. Everybody is able to see the latest messages, so there is no need to point to your post from multiple threads.
      vladimirV 1 Reply Last reply
      • YveauxY Yveaux
        vladimirV
        vladimirV
        vladimir
        @yveaux Excuse me. I promise not to do it again!:man-gesturing-ok:
        • sundberg84S
          sundberg84S
          #632
          @Nca78 Well, i automated my cat door.
          • Andrew MaynardA
            Andrew MaynardA
            Andrew Maynard
            The rules are simple - keep it simple with one picture (or a few) with a small text including a small exp
            sick of breadboard so made the gateway more permanent. added a nice dc plug to it after pic
            • sundberg84S
              sundberg84S
              #634
              Playing with how small I could create a EasyPCB if I only used SMD components and footprints for both RFM69 and Nrf24l01+... including MysX, Signing, Flash offcourse... and a coincell...
              tbowmoT monteM 2 Replies Last reply
              • sundberg84S sundberg84
                tbowmoT
                tbowmoT
                tbowmo
                @sundberg84
                cool, what dimensions are you down to now?
                btw. what happened to the trace in lower right corner (the one that runs by the ISP connector)?
                • tbowmoT tbowmo
                  @sundberg84
                  sundberg84S
                  sundberg84S
                  #636
                  @tbowmo - Thanks!! :) 42mm diameter (round, but the 3d view doesnt show that).
                  The track - well, it seems like I can only get KiCad to make 45dgr tracks... need to investigate it its possible to make other tracks...
                  O 1 Reply Last reply
                    monteM
                    monteM
                    monte
                    @sundberg84 you can also use smd crystal. They are cheaply available on aliexpress. Are you using 0603 caps and resistors?
                    • monteM monte
                      sundberg84S
                      sundberg84S
                      @monte - 0805 res/caps, (for me easy to solder, while 0603 is possible but start to get hard).
                      I was thinking about SMD crystal but left it since i couldnt find a common size. Do you know a good size for SMD crystal (with multiple brands?) like 0805 or a good searchword? I found HC-49S but they are the same size as the ones with pins.
                      monteM 1 Reply Last reply
                        O
                        O
                        Omemanti
                        wrote on last edited by Omemanti
                        #639
                        @sundberg84 "well, it seems like I can only get KiCad to make 45dgr tracks"
                        References => General Settings => Limit graphics lines to 45 degrees
                        • bjacobseB
                          bjacobseB
                          bjacobse
                          I recently hacked my Assa Abloy/Yale smart lock as it could only turn +-90° created a new washer ring, so it now can turn infinitely so it is usable to use a lock
                          The needed 3D stl file or Freecad drawing is to be found here:
                          https://www.thingiverse.com/thing:3155286
                            @Yveaux - Yes, as long as you don't tell her ;)
                            N
                            N
                            Nina Baines
                            What an inspiring thread!
                              monteM
                              monteM
                              monte
                              @sundberg84 I've bought these 5032 crystals: https://www.aliexpress.com/item/Free-shipping-20pcs-16-000MHZ-16mhz-20pF-2Pin-5032-smd-quartz-resonator-Crystal/32821974003.html but there are plentiful other offers on aliexspress and/or ebay. This 5032 package seems to be the most common. There is another package with the same size but with 4 pins 2 of which are not connected, I bought them from my local distributor, while was waiting a package from aliexpress. But those with 4 pins are harder to solder (obviously) and I don't see any pros of using them.
                              The most suitable for hand soldering and easiest to find are these: 0_1540201979487_2014022559267404.jpg
                              According to this image the ones I have are TX5 and TG5.
                              • sundberg84S
                                sundberg84S
                                Im getting so tired of soldering extra wires and stuff so today im doing a "MysX to All common sensors breakout board"...
                                Dont know if this will work... but worth a shot.
                                • alowhumA
                                  alowhumA
                                  alowhum
                                  #644
                                  @sundberg84 If I'm honest some of those sensors seem 'old' to me.
                                  • I usually go for the BEM280 instead of the BMP085 and DHT22. It's so cheap now.
                                  • I never use pulse soil sensors, only the capacitive kind, as they last much longer and don't pollute the soil.
                                  In fact, I always make all my sensors with the Nano Wireless Expansion Board, which is about $2. You can simply plug in the NRF24 into it.
                                  https://www.aliexpress.com/item/Free-shipping-Nano-328P-IO-wireless-sensor-expansion-board-for-XBEE-and-NRF24L01-Socket-for-arduino/32264665470.html
                                  sundberg84S Nca78N 2 Replies Last reply
                                  • alowhumA alowhum
                                    sundberg84S
                                    sundberg84S
                                    @alowhum thanks for the reply!
                                    I used the sensor in MySensors build section, i somehow believe that is whats used the most. But that does not stop me from adding your suggestion for BEM280. That Wireless board looks great, but Im working with the MysX connector so thats why im making this board.
                                    • alowhumA alowhum
                                      wrote on last edited by Nca78
                                      #646
                                      @alowhum said in What did you build today (Pictures) ?:
                                      Unfortunately most of the cheap breakout boards found on AliExpress use clones with much worse specs than the original version
                                      But you can't really make battery-powered sensors with those ? The regulators are AMS1117 with 5mA typical quiescent current.
                                      • Nca78N Nca78
                                        monteM
                                        monteM
                                        monte
                                        @nca78 said in What did you build today (Pictures) ?:
                                        Could you be more specific? How exactly worth specs does they have. Was going to buy a bunch of them. Maybe there is some comparison or tests?
                                        • alowhumA
                                          alowhumA
                                          alowhum
                                          #648
                                          @sundberg84 yes, sorry about that, I realised too late that it's an expansion board.
                                          @Nca78 Thanks! That 5ma leak current was exactly the kind of info I needed about the board. I was wondering it if could be useful for battery powered things. None of my sensors are. Well, one - I used the BBC Micro:bit as a battery powered motion sensor.
                                          I guess not having a regulator on board is what makes the Arduino Pro Micro so good at being battery powered.
                                          Out of curiosity: if I attached the board to a Usb powerbank (say 10.000 Mah) to operate as an electricity led pulse sensor.. what would be an estimate for how long it would run?
                                          mfalkviddM gohanG 2 Replies Last reply
