  3. Radio setup give: "check wires"
94 Posts 17 Posters 74.4k Views 3 Watching
  • axillentA axillent
    @olaeke said:
    @axillent And me! I started the thread so I have got 10 of the them, maybe something for the MySensors museum!
    hm. are the + is missing on top of the nordic chip?
    it can be probably still used for mysensors in case of:
    • switching data rate to 1Mbs or 2MBs (old version do not support 250Kbs - default to 1.4)
    • comment out "check wires" check inside Mysensors library
    O
    O
    olaeke
    @axillent Yes there is no + on those.
    I have tried using them but without success. I couldn't get them to work at all on the gateway but if I replaced the gateway with + variant and non + on the node then it "almost" worked. I couldn't get the "Auto Id" function to work. I think it has something with Ack to do, i will remember that I have read somewhere that the hardware ack is only implemented in the + variant.
    • eimisE
      eimisE
      eimis
      I'am a new one on this forum, and I've stepped on the same rake like others. So there are some recommendations for other newbies and questions for developers:
      1. I've wasted some hours because this library uses serial baud rate 115200, not 9600, what is default for other projects - it should be mentioned in proper place, sorry, if it is, but I've not noticed it.
      2. Next step for all users, that want to use this great project, should be sketch that outputs NRF24L01 version: my history is, that I've bought 10 NRF's from the same seller (alice***) 2-3 months ago, on chips there is "+" sign, but sketch says, that there is NRF24L01 without "+" :(
      3. What to do for those unlucky, that bought wrong version: maybe it's possible to use these modules with some restrictions, while right modules will arrive? I saw recommendations about sensor node to change speed and comment out while()1) after "check cables", but what to do for gateway node?
      4. I'm not a geek developer, maybe it is possible to use #define SOFTSPI in main sketch, before including other libraries? It would be simpler, than editing file RF24_config.h for gateway node and sensor node?
      hekH 1 Reply Last reply
      • eimisE eimis
        It is mentioned at a few places on the main site. Anywhere particular place it is missing?
        Unfortunately the Arduino IDE build system is f**cked up and does not allow this. But I agree that DEBUG and SOFTSPI would had been great to add in the sketch itself.
        eimisE 1 Reply Last reply
          eimisE
          eimisE
          eimis
          I've started from "Building Ethernet Gateway" and finished on "MQTT Gateway", as I use OpenHAB as Controller.
          • m26872M
            m26872M
            m26872
            wrote on last edited by m26872
            #78
            Hm what's this? I haven't had time to test it yet, but it looks very suspicious. I'm pretty sure I ordered via MyS store on Jan 10 (soon after the Ali-links just were introduced). Is it worth the hassle to test or should I throw it straight into the garbage and order a new batch from a proven supplier (which one)?
            Bought it from here.
            axillentA slartiS 2 Replies Last reply
            • m26872M m26872
              axillentA
              axillentA
              axillent
              @m26872 this is most probably based on a Chinese clone of the nordic chip
              it could probably work
              At least nobody will charge you for the try :)
              sense and drive
              • m26872M m26872
                slartiS
                slartiS
                slarti
                @m26872 Didn't work for me. Please tell me how you do.
                "One is never alone with a rubber duck"
                axillentA 1 Reply Last reply
                • slartiS slarti
                  axillentA
                  axillentA
                  axillent
                  @slarti start from the RF24 example named GettingStarted
                  connect wires according to hek's instruction http://www.mysensors.org/build/connect_radio
                  sense and drive
                  slartiS 1 Reply Last reply
                    slartiS
                    slartiS
                    slarti
                    @axillent I tried it and it worked with the modules but none of the MySensors example sketches work with them. Thread about it.
                    • slartiS slarti
                      axillentA
                      axillentA
                      axillent
                      @slarti what is the output from printDetails ?
                      is your chip recognized as NRF24L01+ or just NRF24L01?
                      sense and drive
                        slartiS
                        slartiS
                        slarti
                        @axillent That's the funny thing, they were recognized as NRF24L01+ but still refuse to work. I don't get "check wires". I just don't get anything.
                        • slartiS slarti
                          axillentA
                          axillentA
                          axillent
                          @slarti getting nothing is already something)
                          GettingStarted can be used to connect two arduinos. Have you tested this? You told that examples are working.
                          sense and drive
                            wrote on last edited by hek
                            #86
                            Might be possible to tweak initialization to get them to work. If someone has too much time on their hands this could be added as a new RFM73 driver in the development branch.
                            http://forum.mysensors.org/topic/300/rfm73-experience/14
                              slartiS
                              slartiS
                              slarti
                              @axillent Yes, the pingpong sketch from @olaeke works after I import the MySensors library to the sketch and comment out
                              //#include "nRF24L01.h" //#include "RF24.h"
                              and
                              #define MINIMAL from RF24_config.h
                              None of the "normal" examples work or give anything over serial.
                              axillentA O 2 Replies Last reply
                              • slartiS slarti
                                and
                                axillentA
                                axillentA
                                axillent
                                @slarti it is probably a limited set of configurable parameters are allowed for your chip
                                you can investigate this but no success guaranteed
                                sense and drive
                                • slartiS
                                  slartiS
                                  slarti
                                  We'll know tomorrow or the day after as I found a Finnish guy with some radios that should be either the real thing or the SI24R1 -clone that should work.
                                  • m26872M
                                    m26872M
                                    m26872
                                    Thank you for the info. I never inteded to develop any driver so I will simply buy a new batch with more care this time.
                                    • slartiS slarti
                                      and
                                      O
                                      O
                                      olaeke
                                      @slarti You can test to set a static id on the sensor in the gw.begin like;
                                      gw.begin(NULL, 25);
                                      this sample set id fixed to 25 on this node. At least that was one of my problem with this radios, but my advice is to by new radios the cost is so smal compared to the effort. However it is the shiping that is the problem.
                                      • O olaeke
                                        gw.begin(NULL, 25);
                                        slartiS
                                        slartiS
                                        slarti
                                        @olaeke Thanks, made it easy to test the new radios I got today.
                                        If someone in Europe needs to get radios fast, try this guy in Finland. He advertises the radios as NRF24L01, but they are in fact NRF24L01+.
                                        O 1 Reply Last reply
                                        • slartiS slarti
                                          O
                                          O
                                          olaeke
                                          @slarti HaHa so in China they sell NRF24L01+. and you get NRF24L01 but in Finland they sell NRF24L01 and you get NRF24L01+. :)
